Possible to name a 'chunk' of code, then use its name?
Terry Pinnell
Wed, Feb 9, 2022 12:49 PM
Probably an embarrassingly obvious answer, but..
When building a model, say a shaft for a spindle, suppose I start with
subtracting a smaller cylinder from another. Developing that, the code can
soon get quite messy. Differences of differences and the like. Is there a
simple way to name my model, say 'Shaft', and then use that name in all
further editing?
Terry
Probably an embarrassingly obvious answer, but.. When building a model, say a shaft for a spindle, suppose I start with subtracting a smaller cylinder from another. Developing that, the code can soon get quite messy. Differences of differences and the like. Is there a simple way to name my model, say 'Shaft', and then use that name in all further editing? -- Terry
Wed, Feb 9, 2022 12:53 PM
Yes, make it a module called shaft and use shaft().
further editing?
Terry
Yes, make it a module called shaft and use shaft(). On Wed, 9 Feb 2022 at 12:50, Terry Pinnell <terrypingm@gmail.com> wrote: > Probably an embarrassingly obvious answer, but.. > > When building a model, say a shaft for a spindle, suppose I start with > subtracting a smaller cylinder from another. Developing that, the code can > soon get quite messy. Differences of differences and the like. Is there a > simple way to name my model, say 'Shaft', and then use that name in all > further editing? > > -- > Terry > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Wed, Feb 9, 2022 1:52 PM
Thanks nop head. Although I understand the greater fexibility of modules, I naively had in mind something much simpler. While still editing my code, say that subtraction on my two cylinders is done. I’d like to bracket that code, place my cursor at the start and type something like ‘Define shaftxyz:’ So that any future use of the string ‘shaftxyz’ (apart from this specific statement) would effectively replace that code. No decisions about future use, no decision whether parameters needed and if so what to call them. Just like my abbreviation ‘=tp’ to type my full name and address.
Terry
Terry
Thanks nop head. Although I understand the greater fexibility of modules, I naively had in mind something much simpler. While still editing my code, say that subtraction on my two cylinders is done. I’d like to bracket that code, place my cursor at the start and type something like ‘Define shaftxyz:’ So that any future use of the string ‘shaftxyz’ (apart from this specific statement) would effectively replace that code. No decisions about future use, no decision whether parameters needed and if so what to call them. Just like my abbreviation ‘=tp’ to type my full name and address. -- Terry > On 9 Feb 2022, at 12:53, nop head <nop.head@gmail.com> wrote: > >  > Yes, make it a module called shaft and use shaft(). > >> On Wed, 9 Feb 2022 at 12:50, Terry Pinnell <terrypingm@gmail.com> wrote: >> Probably an embarrassingly obvious answer, but.. >> >> When building a model, say a shaft for a spindle, suppose I start with subtracting a smaller cylinder from another. Developing that, the code can soon get quite messy. Differences of differences and the like. Is there a simple way to name my model, say 'Shaft', and then use that name in all further editing? >> >> -- >> Terry >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Wed, Feb 9, 2022 1:54 PM
Indeed.
Terry might need a bit more help to figure out the actual syntax:
module pipe (length, inner_diameter, wall_thickness)
rotate ([0,90,0])
difference () {
cylinder (d= inner_diameter + 2 * wall_thickness, h= length, center=true);
cylinder (d= inner_diameter + 0 * wall_thickness, h= length+2, center=true);
pipe (80, 10, 1);
rotate (90) pipe (60, 6, 1);
(For the record, I think of a shaft being solid. so I called it "pipe").
further editing?
Terry
On Wed, Feb 09, 2022 at 12:53:01PM +0000, nop head wrote: > Yes, make it a module called shaft and use shaft(). Indeed. Terry might need a bit more help to figure out the actual syntax: module pipe (length, inner_diameter, wall_thickness) { rotate ([0,90,0]) difference () { cylinder (d= inner_diameter + 2 * wall_thickness, h= length, center=true); cylinder (d= inner_diameter + 0 * wall_thickness, h= length+2, center=true); } } pipe (80, 10, 1); rotate (90) pipe (60, 6, 1); (For the record, I think of a shaft being solid. so I called it "pipe"). Roger. > On Wed, 9 Feb 2022 at 12:50, Terry Pinnell <terrypingm@gmail.com> wrote: > > > Probably an embarrassingly obvious answer, but.. > > > > When building a model, say a shaft for a spindle, suppose I start with > > subtracting a smaller cylinder from another. Developing that, the code can > > soon get quite messy. Differences of differences and the like. Is there a > > simple way to name my model, say 'Shaft', and then use that name in all > > further editing? > > > > -- > > Terry > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a is going up. -- Chris Hadfield about flying up the space shuttle.
Terry Pinnell
Wed, Feb 9, 2022 1:56 PM
But of course without actually entering the code! just the abbreviation
'shaftxyz'
On Wed, 9 Feb 2022 at 13:52, terrypingm@gmail.com terrypingm@gmail.com
Terry
further editing?
Terry
LargePrefPlaceholder-XKUz1MEJBwkOM
But of course without actually entering the code! just the abbreviation 'shaftxyz' On Wed, 9 Feb 2022 at 13:52, terrypingm@gmail.com <terrypingm@gmail.com> wrote: > Thanks nop head. Although I understand the greater fexibility of modules, > I naively had in mind something much simpler. While still editing my code, > say that subtraction on my two cylinders is done. I’d like to bracket that > code, place my cursor at the start and type something like ‘Define > shaftxyz:’ So that any future use of the string ‘shaftxyz’ (apart from this > specific statement) would effectively replace that code. No decisions about > future use, no decision whether parameters needed and if so what to call > them. Just like my abbreviation ‘=tp’ to type my full name and address. > > -- > Terry > > On 9 Feb 2022, at 12:53, nop head <nop.head@gmail.com> wrote: > >  > Yes, make it a module called shaft and use shaft(). > > On Wed, 9 Feb 2022 at 12:50, Terry Pinnell <terrypingm@gmail.com> wrote: > >> Probably an embarrassingly obvious answer, but.. >> >> When building a model, say a shaft for a spindle, suppose I start with >> subtracting a smaller cylinder from another. Developing that, the code can >> soon get quite messy. Differences of differences and the like. Is there a >> simple way to name my model, say 'Shaft', and then use that name in all >> further editing? >> >> -- >> Terry >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > -- LargePrefPlaceholder-XKUz1MEJBwkOM
Wed, Feb 9, 2022 1:59 PM
and address.
You're still asking for a subset of what modules do.
module mypipe () pipe (80, 10, 1);
In computer languages, it is best to make things general enough and
then let users decide if they want to use all features or not.
Terry
Terry
On Wed, Feb 09, 2022 at 01:52:04PM +0000, terrypingm@gmail.com wrote: > Thanks nop head. Although I understand the greater fexibility of > modules, I naively had in mind something much simpler. While still > editing my code, say that subtraction on my two cylinders is > done. I’d like to bracket that code, place my cursor at the start > and type something like ‘Define shaftxyz:’ So that any future > use of the string ‘shaftxyz’ (apart from this specific > statement) would effectively replace that code. No decisions about > future use, no decision whether parameters needed and if so what to > call them. Just like my abbreviation ‘=tp’ to type my full name > and address. You're still asking for a subset of what modules do. module mypipe () pipe (80, 10, 1); In computer languages, it is best to make things general enough and then let users decide if they want to use all features or not. Roger. > -- > Terry > > > On 9 Feb 2022, at 12:53, nop head <nop.head@gmail.com> wrote: > > > >  > > Yes, make it a module called shaft and use shaft(). > > > >> On Wed, 9 Feb 2022 at 12:50, Terry Pinnell <terrypingm@gmail.com> wrote: > >> Probably an embarrassingly obvious answer, but.. > >> > >> When building a model, say a shaft for a spindle, suppose I start with subtracting a smaller cylinder from another. Developing that, the code can soon get quite messy. Differences of differences and the like. Is there a simple way to name my model, say 'Shaft', and then use that name in all further editing? > >> > >> -- > >> Terry > >> _______________________________________________ > >> OpenSCAD mailing list > >> To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a is going up. -- Chris Hadfield about flying up the space shuttle.
Wed, Feb 9, 2022 2:00 PM
'shaftxyz'
That's what a library does.
include <poly.scad>
On Wed, Feb 09, 2022 at 01:56:16PM +0000, Terry Pinnell wrote: > But of course without actually entering the code! just the abbreviation > 'shaftxyz' That's what a library does. include <poly.scad> Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a is going up. -- Chris Hadfield about flying up the space shuttle.
Terry Pinnell
Wed, Feb 9, 2022 2:02 PM
Agreed, Roger, 'pipe'!
See also my reply to nop head which passed in the ether before I saw yours.
I certainly do intend to make more use of modules. But for my pretty modest
designs I'd still like something simpler as explained.
I might try a second best solution of using my Macro Exoress Pro
application.
Indeed.
rotate ([0,90,0])
difference () {
center=true);
center=true);
pipe (80, 10, 1);
can
there a
further editing?
Terry
Agreed, Roger, 'pipe'! See also my reply to nop head which passed in the ether before I saw yours. I certainly do intend to make more use of modules. But for my pretty modest designs I'd still like something simpler as explained. I might try a second best solution of using my Macro Exoress Pro application. On Wed, 9 Feb 2022 at 13:54, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: > On Wed, Feb 09, 2022 at 12:53:01PM +0000, nop head wrote: > > Yes, make it a module called shaft and use shaft(). > > > Indeed. > Terry might need a bit more help to figure out the actual syntax: > > module pipe (length, inner_diameter, wall_thickness) > { > rotate ([0,90,0]) > difference () { > cylinder (d= inner_diameter + 2 * wall_thickness, h= length, > center=true); > cylinder (d= inner_diameter + 0 * wall_thickness, h= length+2, > center=true); > } > } > > pipe (80, 10, 1); > rotate (90) pipe (60, 6, 1); > > > (For the record, I think of a shaft being solid. so I called it "pipe"). > > Roger. > > > > On Wed, 9 Feb 2022 at 12:50, Terry Pinnell <terrypingm@gmail.com> wrote: > > > > > Probably an embarrassingly obvious answer, but.. > > > > > > When building a model, say a shaft for a spindle, suppose I start with > > > subtracting a smaller cylinder from another. Developing that, the code > can > > > soon get quite messy. Differences of differences and the like. Is > there a > > > simple way to name my model, say 'Shaft', and then use that name in all > > > further editing? > > > > > > -- > > > Terry > > > _______________________________________________ > > > OpenSCAD mailing list > > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > -- > ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 > ** > ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** > f equals m times a. When your f is steady, and your m is going down > your a is going up. -- Chris Hadfield about flying up the space shuttle. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > -- LargePrefPlaceholder-XKUz1MEJBwkOM
Terry Pinnell
Wed, Feb 9, 2022 2:05 PM
Thanks for both follow ups. On iPad but I'll get back to PC shortly and
experiment further with modules and includes.
'shaftxyz'
include <poly.scad>
Thanks for both follow ups. On iPad but I'll get back to PC shortly and experiment further with modules and includes. On Wed, 9 Feb 2022 at 14:00, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: > On Wed, Feb 09, 2022 at 01:56:16PM +0000, Terry Pinnell wrote: > > But of course without actually entering the code! just the abbreviation > > 'shaftxyz' > > That's what a library does. > > include <poly.scad> > > Roger. > > -- > ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 > ** > ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** > f equals m times a. When your f is steady, and your m is going down > your a is going up. -- Chris Hadfield about flying up the space shuttle. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > -- LargePrefPlaceholder-XKUz1MEJBwkOM
FS
FF Systems
Wed, Feb 9, 2022 2:58 PM
Hmmmm... at the risk of being less than helpful, all the "pipes" in my
house are hollow...
Indeed.
rotate ([0,90,0])
difference () {
center=true);
center=true);
pipe (80, 10, 1);
can
there a
further editing?
Terry
Hmmmm... at the risk of being less than helpful, all the "pipes" in my house are hollow... On Wed, Feb 9, 2022 at 7:55 AM Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: > On Wed, Feb 09, 2022 at 12:53:01PM +0000, nop head wrote: > > Yes, make it a module called shaft and use shaft(). > > > Indeed. > Terry might need a bit more help to figure out the actual syntax: > > module pipe (length, inner_diameter, wall_thickness) > { > rotate ([0,90,0]) > difference () { > cylinder (d= inner_diameter + 2 * wall_thickness, h= length, > center=true); > cylinder (d= inner_diameter + 0 * wall_thickness, h= length+2, > center=true); > } > } > > pipe (80, 10, 1); > rotate (90) pipe (60, 6, 1); > > > (For the record, I think of a shaft being solid. so I called it "pipe"). > > Roger. > > > > On Wed, 9 Feb 2022 at 12:50, Terry Pinnell <terrypingm@gmail.com> wrote: > > > > > Probably an embarrassingly obvious answer, but.. > > > > > > When building a model, say a shaft for a spindle, suppose I start with > > > subtracting a smaller cylinder from another. Developing that, the code > can > > > soon get quite messy. Differences of differences and the like. Is > there a > > > simple way to name my model, say 'Shaft', and then use that name in all > > > further editing? > > > > > > -- > > > Terry > > > _______________________________________________ > > > OpenSCAD mailing list > > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > -- > ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 > ** > ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** > f equals m times a. When your f is steady, and your m is going down > your a is going up. -- Chris Hadfield about flying up the space shuttle. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
