Hi!
I'm new to OpenSCAD and I'm currently working on a small project for which I
need some help.
I have found this script on Thingiverse
(https://www.thingiverse.com/thing:3826892) that uses the Threads.scad
library. I need to import it into FreeCAD but the external library seems to
be causing FreeCAD some problems.
I thought of doing my project entirely in OpenSCAD but I'm really bad at
programming, so for me, considering the complexity of my project, it's a
no-go.
Is there an easy way to include the library inside the project so that the
import is easier?
Thanks!
I doubt you can use an OpenSCAD library directly in FreeCad. I think you
would need to use the library in an OpenSCAD file to actually make a
threaded object and then import that into FreeCAD.
On Fri, 27 Nov 2020 at 16:32, Build-0-Matic francois.laverdure@gmail.com
Hi!
I
need some help.
no-go.
import is easier?
Thanks!
There is a fairly comprehensive thread workbench in freecad. That and
the part workbench will produce your bottle. It has 45deg threads for
bottles.
On 27/11/2020 16:32, Build-0-Matic wrote:
Hi!
need some help.
no-go.
import is easier?
Thanks!
There's actually an OpenSCAD workbench that works fairly well for single file
projects. But with this one FreeCAD hits a wall pretty hard and crashes. I
know FreeCAD creates a link with an installed version of OpenSCAD to do the
calculations, so compatibility should be fine.
I've tried it with some rendered 20x20 aluminum extrusion models and it
worked wonders. But not with this parametric bottle.
It just that using a parametric model would be such a simple way to design
80% of what I want...
I could export to an STL and then import that in FreeCAD... but I really
dislike using STL files as they are so limiting.
