Here is my current setup:
module bars()
for(x=[-30,-20,-10,0,10,20,30], y=[-30,-20,-10,0,10,20,30 ])
translate([x,y,0]) cylinder (r=2,h=100,$fn=100,
center=true);
bars();
sphere(r=30);
How can I make it possible that the bars will only show up within the limits
of the sphere?
I don't want a solid sphere, I want to see the bars existing only within a
given shape/set of dimensions.
Thank you kindly, maybe I can help you.
View this message in context: http://forum.openscad.org/How-to-set-a-limit-for-extended-pattern-objects-to-be-contained-in-the-volume-of-a-desired-object-tp11623.html
Replacing difference() with intersection() should do the trick.
Ed
softsolder.com
It works! Thank you so so much my good sir.
View this message in context: http://forum.openscad.org/How-to-set-a-limit-for-extended-pattern-objects-to-be-contained-in-the-volume-of-a-desired-object-tp11623p11625.html
