When you compose the cones together the resulting shape is concave, so it
will do a single slow minkowski. When you do each cone separately they are
convex, so if the profile is convex, it will do the fast minkowski, but lots
of them.
In the concave case it probably has to decompose the shapes into convex
parts, so perhaps it breaks the cones apart again and does effective what my
version did.
The reason preview is slow is because OpenCSG can't do minkowski or hull so
those are done with CGAL even during F5.
View this message in context: http://forum.openscad.org/Fillet-With-Internal-Angles-tp17201p17225.html
Clear and sound. Thanks.
2016-04-29 4:21 GMT-03:00 nophead nop.head@gmail.com:
lots
of them.
my
version did.
I am using version 2015.05.16 (git e673fff).
The cylinder takes 14 or 15 seconds. Both shapes together takes 1m11. I
can't explain why you get a big difference between methods and I get none.
Perhaps you have an older version of OpenScad.
lots
of them.
my
version did.
so
Nophead & Ronaldo, interesting discussion thanks.
I had pondered the same idea as you Ronaldo (code below), but it is still
slower than your version Nophead - i.e. very, very slow! The only possible
advantage is that a 2D profile can easily be constructed with a boolean
combination of circles and squares to generate an arbitrary fillet shape.
-Trygon
http://forum.openscad.org/file/n17231/BlendFilletExtrude_test01.png
n=5; // number of steps in fillet
r=2; // fillet radius
h=8; // overall extrusion height
translate([-10,-10,-2]) cube([40,40,2]); //plate
BlendFilletExtrude(h,r,$fn=n*4) TestShape();
module TestShape(s=20,r=3,$fn=20){
FilletPolygon(r) difference(){
square(s);
translate([s/2,s/2]) square(s);
module FilletPolygon(r=2,internal=true,external=true){
if(internal && external){
offset(r=-r) offset(delta=r) offset(r=r) offset(delta=-r)
} else if (external){
offset(r=r) offset(delta=-r) children();
} else if(internal){
offset(r=-r) offset(delta=r) children();
}else{
// h height of extrusion (from z=0)
// r radius of fillet
// padding distance fillet is extended below plane z=0
module BlendFilletExtrude(h=10,r=2,padding=0.1){
eps=0.001;
linear_extrude(height=h) children();
minkowski(){
rotate_extrude() difference(){
translate([0,-padding]) square([r,r+padding]);
translate([r,r])circle(r);
linear_extrude(height=eps) children();
View this message in context: http://forum.openscad.org/Fillet-With-Internal-Angles-tp17201p17231.html
The clever nophead's code to produce fillets from 2D shapes is restricted to
extrusions that are orthogonal to the base plane. I have faced the problem
to fillet a cylinder that makes an angle of 45 degrees to its base. A proper
modification of nophead's code allows it to handle such more general cases.
RADS = 2.5; // Radius of the fillet
fn=24; // control the fillet step size
// base
translate([-30,-30,0])
cube([60,60,5]);
// cylinder
angs = [45,0,0];
translate([12,12,5]) {
ninteyDegFillet(RADS,angs=angs,$fn=24)
circle(10,$fn=fn);
rotate(angs)
translate([0,0,-10.4])
cylinder(r=10,h=30,$fn=fn);
// generic shape
angs2 = [-20,0,30];
translate([-20,-20,5]){
ninteyDegFillet(RADS,angs2,$fn=24)
a_profile();
rotate(angs2)
translate([0,0,-10])
linear_extrude(30)
a_profile($fn=fn);
module a_profile(){
square(15);
translate([12,3])
circle(5);
module ninteyDegFillet(r,angs=[0,0,0]) {
r - fllet radius
$fn/4 - number of steps
function rad(x) = r - sqrt(pow(r,2) - pow(x - r, 2));
st = r4/$fn; // step size
eps = 0.001; // a little overlap between slices
a = angs[0];
s = sin(angs[2]);
c = cos(angs[2]);
if (abs(cos(a))>0.05) {// avoid shallow angles to horizontal
rot = [[c,-s,0],[s,c,0],[0,0,1]];
m = rot*[[1,0,0],[0,1/cos(a),-tan(a)],[0,0,1]];
multmatrix(m)
for(i = [0 : st : r - st])
translate([0,0, i])
minkowski() {
linear_extrude(height = eps)
cylinder(r1=rad(i), r2=rad(i+st), h=st, $fn=fn);
The trick to get it done was to skew the fillet and rotate it. Note that
ninteyDegFillet() (what that name means after all?) now receives a list of
angles angs, the same list that is passed to rotate the extrusion. However,
the code considers only the x and z rotations which is enough for all cases.
Also, the fillet refinement is now controlled by $fn.
Interestingly, the hard and lengthy work of minkowski does depends only on
the shape and the refinement. After the first run, you may change the angles
and the preview is immediate.
View this message in context: http://forum.openscad.org/Fillet-With-Internal-Angles-tp17201p18807.html
