Thu, Jan 7, 2021 11:25 AM
I'm not sure how the behavior of "if (true)..." can make my statement about
"if (false)" incorrect.
That behavior has stayed the same between RC3 and RC4. And in 2019.05
if(true) echo(..) produces an empty set as well, though it's a different
looking empty set. We get group(){group();} in 2019 and now just group(){};
It looks like "if (true)" always makes a group. So in all the versions, "if
(true) {}" produces group();. It's just that in the RC if you stick an echo
as a child it adds nothing.
nophead wrote
Not quite because if(true) echo() has changed to return the empty set.
On Thu, 7 Jan 2021 at 03:34, adrianv <
In RC4, if (false) doesn't create a group in the tree, so intersection
works
the way it did before.
JordanBrown wrote
[ Sigh. Not my day. First I sent this from the wrong address, then
when I went to resend it from the right address I resent the one of
Adrian's messages instead of this one. ]
On 12/26/2020 6:58 PM, adrianv wrote:
It seems like the truth is that passing assert or echo as children
just weird and confusing.
Somewhat. But they obey the general rule: they run when you say
children(i) and refer to them.
Yes, everything makes sense if you understand the technical details.
for a casual user it's going to be surprising and puzzling, I think.
Yes.
What I'm saying is that if it's going to be surprising and puzzling, at
least there should be a simple rule.
(And I think that all variations that have gotten past the first level
of discussion have that simple rule, that all module-like invocations
yield children.)
I think in my own work I'd be more inclined to stick a cube() or
something in as a placeholder than text. Or just a comment.
A comment won't be enough if you're leaving a placeholder for child #3
which already exists, like it or not.
Well, in the RC, which is 95% existing but not 100%. (I think my
primary contribution to this discussion might be in giving it a
I wasn't saying that the functionality wasn't in the RC... but rather
that the RC is an RC, not a release, so doesn't 100% exist. Behavior
a non-release can change; behavior in a release should normally remain
constant.
(But: the RC has NULL functionality for echo, assert, intersection,
difference, but not for if, for, and modules. Hans has a PR for if.)
[ if(true)echo() and if(false)echo() are different from echo() ]
Wouldn't these things be "fixed" by having if statements not create
geometry?
Well, by having failing if not generate geometry - having it generate
NULL - and by having successful if (or else) yield whatever its
yield (which might or might not be NULL).
I'm in agreement that intersection with empty set should give the
empty set. The problem is that there's no way to specify the
complement of the empty set. So I can't do
intersection(){
if (condition) thing(); else everything();
otherthing();
NULL would address this particular need, because a failing if would
yield NULL, and intersection would be defined to ignore NULL. So for
intersection purposes, NULL would be sort of like everything().
For difference, yes, it matters what the first object is, and your
example
does give a case where things change. But it's not an example that
Agreed. It only has a confusion case, where somebody has put an echo()
as the first child to a difference.
I'm left wondering if it really matters whether if(false) and empty
for return an empty set or a NULL, since most of the time it will give
the same result anyway.
Intersection is the big one.
> avm4@
>> works
>> is
>> But
>> > Yes.
>> > yield children.)
>> of
>> > 6.
>> name.)
>> >> What is the missing 5%?
>> in
>> > constant.
>> and
>> >> geometry?
>> contents
>> >> intersection(){
>> >> otherthing();
>> >> example
>> seems
>> >> like it has a use case.
>> > _______________________________________________
>> > OpenSCAD mailing list
>> > Discuss@.openscad
>> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
>> Sent from: http://forum.openscad.org/
> Discuss@.openscad
> Discuss@.openscad
Thu, Jan 7, 2021 11:57 AM
Yes but in the last release empty groups were ignored in intersection and
difference, so adding an echo did not break them. A plain echo now does not
break them but if() echo() does if it is true but not false. And a wrapped
echo in a module now breaks intersection and difference.
group(){};
"if
echo
works
Yes.
yield children.)
constant.
geometry?
intersection(){
otherthing();
example
> group(){};
> "if
> echo
> > avm4@
> >> works
> >> is
> >> But
> >> > Yes.
> at
> >> > yield children.)
> >> of
> >> > 6.
> >> name.)
> >> in
> >> > constant.
> >> and
> >> >> geometry?
> >> contents
> >> >> intersection(){
> >> >> otherthing();
> >> >> example
> >> seems
> echo()
> give
> >> > Discuss@.openscad
> > Discuss@.openscad
> > Discuss@.openscad
