I recall this being discussed a while back and I'm not sure about what the
ultimate conclusion was, and I can't remember what the issue was that gave
rise to the change. But it seems like the RC3 version has the behavior that
if(false) returns an empty object rather than nothing. This is different
from what happened in 2019.05, it seems, as shown by this example which
breaks in RC3 but works in 2019.
chamfer = false; // Set to true to get chamfer
intersection(){
cube(10);
if (chamfer)
translate([0,-10,12]) rotate([-45,0,0])cube(30);
When chamfer is false I expect a cube but instead I get nothing because the
intersection is with an empty object. Note that in the list context:
[1,2,if (false) 27, 3, 4] the conditional produces nothing, not an empty
list, so the new behavior makes the openscad language less internally
consistent. Is there some advantage of the new behavior? Note that if this
change is staying, it should be highlighted as a language change from the
2019 version.
I don't think it returns an empty object in 2019.05. (Check the CSG
tree.) What I think is happening is that intersection in 2019.05
ignores the empty object.
Having it return nothing would break things in a different way.
want_sphere = false;
module foo() {
children(1);
foo() {
cube();
if (want_sphere) sphere();
cylinder();
should emit either a sphere or nothing, depending on how want_sphere is set.
tree.)
I mis-wrote. I don't think it returns nothing in 2019.05. In both
2019.05 and the current build, if(false) yields an empty group() in the
CSG tree. As do echo(), for()-that-never-runs, and empty modules.
The difference is in what intersection() and difference() do with
children that don't contain any solid-generators.
2019.05's difference() and intersection() ignore children that don't
contain anything that generates a solid.
Thus echo, if(false), "translate([0,0,0]);", empty modules, et cetera
are all ignored.
An intersection or difference of a cube or other solid, that yields
nothing, is not ignored.
The current build respects those "super empty" structures.
What I think is happening is that intersection in 2019.05 ignores the
empty object.
module foo() {
children(1);
foo() {
cube();
cylinder();
is set.
How do you view the CSG tree?
I noticed that the example you posted works the same in both versions, so
that does imply that it returns an empty object and that the question is
maybe what intersection or difference do with empty objects. Here's a
simple example:
union() {};
cube();
The above code produces a cube in 2019.05 and nothing in RC3. To me the
old behavior makes more sense: if you haven't specified an object then
ignore it rather than "no object" being the same as the empty set.
I could see leaving the current behavior but introducing a nothing() object
that lets you not return geometry. I could also see changing difference and
intersection to the old behavior and having a nothing() object that acts
like the empty set. But maybe this second case doesn't work because the
change fixed a bug? It seems like "if" is a weaker tool if it always has
to return geometry that is acted upon.
tree.)
are all ignored.
empty object.
module foo() {
children(1);
foo() {
cube();
cylinder();
is set.
Discuss@.openscad
Discuss@.openscad
Design/Display-CSG-tree
Now that I know how to look at CSG trees I did some inspection.
It looks like some objects have changed behavior.
echo and assert give group(); in 2019.05 but give nothing in RC3.
if(false) and for(never) give group(); in both versions.
And I discovered something really bad: it's now a warning to write a for
statement that doesn't run. This is a terrible idea. It's going to break a
bunch of base cases and degenerate cases all over the place.
tree.)
are all ignored.
empty object.
module foo() {
children(1);
foo() {
cube();
cylinder();
is set.
Discuss@.openscad
Discuss@.openscad
I think it is only a warning in for() if the range is literal. So a loop
that will never run with any input variables is a warning but one that
sometimes doesn't run is OK.
a
tree.)
are all ignored.
empty object.
module foo() {
children(1);
foo() {
cube();
cylinder();
is set.
Discuss@.openscad
Discuss@.openscad
rise to the change.
The change was introduced by https://github.com/openscad/openscad/pull/3342
which was a fix for at least 4 existing issues:
https://github.com/openscad/openscad/issues/666
https://github.com/openscad/openscad/issues/3311
https://github.com/openscad/openscad/issues/3312
https://github.com/openscad/openscad/issues/3416
On Fri, Dec 25, 2020 at 2:38 PM Jordan Brown openscad@jordan.maileater.net
tree.)
2019.05 and the current build, if(false) yields an empty group() in the CSG
The difference is in what intersection() and difference() do with children
Thus echo, if(false), "translate([0,0,0]);", empty modules, et cetera are
all ignored.
Jordan is correct here, the old version basically had no concept of empty
geometry and treated it the same as "no geometry" (eg an echo or assert
node without children).
So I guess the issue is now whether or not an untaken conditional should be
counted as empty geometry or not geometry at all.
Without enabling the experimental feature of "lazy-union", a group
essentially implies a union. So an empty group is treated much like
"union() {}" which means "the empty set" of geometry.
Hans
I think a false if or an empty for() should not create empty geometry, just
as echo() doesn't. It is more backwards compatible and you can always force
empty geometry with else union();
rise to the change.
On Fri, Dec 25, 2020 at 2:38 PM Jordan Brown <
tree.)
all ignored.
be counted as empty geometry or not geometry at all.
Hans
