It emits a signal in Preferences class, and the signal is NOT connected
(not even implicitly, because Qt cannot know about Preferences)
Is not a function/slot either.
It's just an odd situation, because it does not make sense to emit
signals, which are not connected.
Not sure why you cause confusion :)
On Thu, Sep 4, 2025 at 5:37 PM Jordan Brown conceptis@jordan.maileater.net
For me it looks like, the culprit is here:
https://github.com/openscad/openscad/blob/master/src/gui/Preferences.cc#L747
Yes, that’s my conclusion too.
Only in windows builds emitting this signal takes 7 seconds.
Remarkably enough, I cannot find where this signal is connected to, so can
we skip sleeping 7 seconds here ?
As best I can tell, it leads into Qt-generated functions. It’s not
sleeping - it’s CPU bound.
What it’s doing, I’m not sure. My guess is that it’s recalculating the
layout of the preferences dialog, but I don’t know why it takes that long.
Qt knows all. :-)
You think that because you haven't found the reference, and you are
forgetting that src/gui/Preferences.ui is in the picture.
The references are not in src. They are in your build directory, in
the dynamically created moc_Preferences.cpp. I don't yet understand how
they fit together or exactly what they do, but there are several
references to applicationFontChanged there.
On Sep 4, 2025, at 12:45, Guenther Sohler via Discuss discuss@lists.openscad.org wrote:
It looks connected to me:
QObject::connect(GlobalPreferences::inst(), &Preferences::applicationFontChanged, &app,
&OpenSCADApp::setApplicationFont);
Should be doable to add some debug/timing statements to see if there is anything in that function itself that is slow.
The thing that probably confused him, and that confused me for a while,
is that there's no obvious definition of
Preferences::applicationFontChanged:
$ grep -R applicationFontChanged src
src/gui/Preferences.cc: emit applicationFontChanged(family, size);
src/gui/Preferences.h: void applicationFontChanged(const QString& family, uint size) const;
src/openscad_gui.cc: QObject::connect(GlobalPreferences::inst(), &Preferences::applicationFontChanged, &app,
It's defined in a dynamically created source file:
$ grep applicationFontChanged b/OpenSCAD_autogen/MXUWEOXILK/moc_Preferences.cpp
QT_MOC_LITERAL(9, 97, 22), // "applicationFontChanged"
"family\0size\0applicationFontChanged\0"
case 4: _t->applicationFontChanged((*reinterpret_cast< const QString(*)>(_a[1])),(*reinterpret_cast< uint(*)>(_a[2]))); break;
if (*reinterpret_cast<_t *>(_a[1]) == static_cast<_t>(&Preferences::applicationFontChanged)) {
void Preferences::applicationFontChanged(const QString & _t1, uint _t2)const
So while it's not impossible to add additional diagnostics, it must be
done with care.
On Sep 4, 2025, at 19:48, Jordan Brown openscad@jordan.maileater.net wrote:
The thing that probably confused him, and that confused me for a while, is that there's no obvious definition of Preferences::applicationFontChanged:
It’s a signal so the implementation will always be auto-generated by Qt. Günther is pretty familiar with Qt I think so it was likely just an oversight on his part:
signals:
So while it's not impossible to add additional diagnostics, it must be done with care.
Signals themselves and their connections is an extremely robust and performant mechanism in Qt, so it should be sufficient to test the function it’s connected to, to at least prove or disprove that the blocking behaviour actually happens there an not somewhere else.
Ah, and so I wasn't understanding it deeply enough. I wasn't finding
applicationFontChanged and wasn't familiar with Qt signals, so didn't
take the next step to OpenSCADApp::setApplicationFont. Sigh.
Now I can look deeper...
It's this call to scadApp->setStyleSheet():
(Which may well trigger callbacks to various other components, but I
haven't tried to track them down yet.)
If that stylesheet is empty, there's no delay.
(Which may well trigger callbacks to various other components, but I haven't tried to track them down yet.)
We used to have that stylesheet code elsewhere, but what’s new is that we also override the font. This is recent (Aug 2nd), so it checks out.
Torsten may know more as he added the font change :)
