Hi
I am sure I must be doing something very silly here but I just can't spot
it. Here is some test code to demonstrate my issue:
Test(choice = 1);
// Test(choice = 2);
// Test(choice = 3);
module Test(choice = 1){
echo(choice=choice);
myVar = 0;
if (choice==1) {
myVar = 1;
} else if (choice == 2) {
myVar = 2;
} else {
myVar = 3;
echo(myVar=myVar);
Why is myVar always 0 at the echo statement?
Hope you can help
Ex
View this message in context: http://forum.openscad.org/Puzzled-here-tp17172.html
OpenSCAD is a declarative language. It doesn't have mutable variables (or
mutable data structures). Each variable is defined in exactly one location.
It does have nested scopes, and {...} introduces a new scope, which is why
you don't get an error.
You can't use multiple assignment statements to specify the value of a
variable.
Try this:
myVar =
(choice==1) ?
1
: (choice == 2) ?
2
3;
On 23 April 2016 at 11:13, Experimentalist experimentalist@aaawesome.co.uk
Hi
Test(choice = 1);
myVar = 0;
if (choice==1) {
myVar = 1;
myVar = 2;
} else {
myVar = 3;
echo(myVar=myVar);
Hope you can help
Ex
You can reassign values to variables. This shows you how:
Test(choice = 1);
// myVar = 0;
if (choice==1) {
myVar=var(choice);
myVar=var(choice);
} else {
myVar=var(choice);
echo(myVar);
function var(choice)=choice;
wolf
View this message in context: http://forum.openscad.org/Puzzled-here-tp17172p17176.html
ECHO: choice = 1
WARNING: Ignoring unknown variable 'myVar'.
ECHO: undef
What makes you think it works? Each myVar is a different variable because
brackets open a new scope. None of them are in scope when it gets to the
echo.
Test(choice = 1);
// myVar = 0;
if (choice==1) {
myVar=var(choice);
myVar=var(choice);
} else {
myVar=var(choice);
echo(myVar);
wolf
Wolf, your program does not work, and contains errors. Here's the console
output that I get:
ECHO: choice = 1
ECHO: undef
Test(choice = 1);
// myVar = 0;
if (choice==1) {
myVar=var(choice);
myVar=var(choice);
} else {
myVar=var(choice);
echo(myVar);
wolf
Sorry, for a moment I did not remember that a module is intended to return a
shape, and a function to return a value. Thus, the confusion. What I should
have sent is this:
choice = 1;
echo(myVar());
Test(myVar());
module Test(xyz)
if (xyz==1) cube([10,xyz,xyz]);
else if (xyz == 2) cube([xyz,10,xyz]);
else if (xyz == 3) cube([xyz,xyz,10]);
else sphere(10);
function myVar()=choice==1?1:
choice==2?2:
choice==3?3:"not in list";
By changing the value assigned to choice, you may change the value reported
by echo() and the shape returned by Test(), which is what -I think-
experimentalist originally intended to do, when we were all mislead by
doug.moen's correct, but misleading answer.
I have read similar questions on these pages before, so the issue is not
new. To overcome it, may I suggest that above sample program be added to the
manual so that others in future can look up the answer there? In particular,
try to stress that module returns a shape, function a value!
wolf
View this message in context: http://forum.openscad.org/Puzzled-here-tp17172p17179.html
"what -I think- experimentalist originally intended to do"
What I was trying to do was change the Z offset of a translation in a module
by passing a more concise parameter to avoid code duplication and improve
readability. With your help I have added a function and achieved my goal,
thanks.
I never have, so maybe it is time to go RTFM.
View this message in context: http://forum.openscad.org/Puzzled-here-tp17172p17182.html
a shape, and a function to return a value. Thus, the confusion. What I
should have sent is this:
choice = 1;
echo(myVar());
Test(myVar());
module Test(xyz)
else sphere(10);
choice==2?2:
reported by echo() and the shape returned by Test(), which is what -I
think- experimentalist originally intended to do, when we were all mislead
by doug.moen's correct, but misleading answer.
the manual so that others in future can look up the answer there? In
particular, try to stress that module returns a shape, function a value!
wolf
Two comments.
In OpenSCAD, modules create shapes but don't return anything.
Your function myVar() returns a value which is a function of choice. This
is what he original poster wanted.
Do not be mislead into thinking it reassigns a value for a variable.
Calling it several times while running the script will always return the
same value.
View this message in context: http://forum.openscad.org/Puzzled-here-tp17172p17185.html
