I'm a relatively new user to open SCAD. I wanted to use a 'thingiverse'
model for robot wheels, but wound up having to debug/modify it to handle my
use case. In the process I learned a lot about SCAD, and really missed the
ability to determine the current transform in the various modules making up
the model. I wound up laboriously documenting the transform progression
through the various levels to determine why a particular sub-object was or
was not in the 'correct' place.
In a previous lifetime as a Electromagnetics researcher I did quite a bit
of scientific visualization software, and my programs always had the
ability to display both the 'global' and 'local' coordinate systems for
each sub-object in a complex (or not) antenna structure. It "sure would be
nice" if OSCAD had a right-click option in the visual model, or maybe a
different character operator in the text side that would display the local
coordinate system for whatever object was active at the point of the
character. Maybe even combine that with the '#' operator, so whatever
object was highlighted would also have it's local coordinate system
displayed?
Before posting this, I searched the forum and found only a few very old
posts discussing this issue, but there didn't seem to be any response other
than "you don't really need that" ;-)
TIA,
Frank
G.Frank Paynter, PhD
OSU ESL Research Scientist (ret)
EM Workbench LLC
614 638-6749 (cell)
Interesting feature, and potentially very useful when troubleshooting a design.
Similarly, I'd find it very useful to be able to get the current position including all transformations as an absolute coordinate, so something like:
translate([0,10,0]){translate([100,0,0]){echo(currentXorigin); // writes out 100echo(currentYorigin); // writes out 10}}
