OpenSCAD Merchandise - Masks @ Zero markup
Sat, Dec 19, 2020 6:11 AM
Redbubble https://www.redbubble.com/people/MichaelAtOz/shop?asc=u&ref=account-nav-dropdown  added
fitted masks to there products, in addition to their flat masks.
Given the times we're in, these are available with zero markup (in my shop, Redbubble will take
their cut).
I can't testify to their medical effectiveness, they are 'non-medical' so put down that scalpel.
See further below for their descriptions/features/materials etc.
The three-layer polyester-outer, cotton-inners Fitted Masks come in Adult & Small-13+ sizes.
The two-layer polyester Flat Masks come in Adult, Small-13+, and two Kids sizes - Small & Extra
Small.
In four flavours.
Any questions, email me oz.at.michael@gmail.com, not the Mailing-List.
(See this forum
http://forum.openscad.org/OpenSCAD-Merchandise-sales-help-support-Development-td28052.html  post
for an overview of the rest of the OpenSCAD Merch., at normal mark-up)
OpenSCAD - The Dark Side
OpenSCAD
https://www.redbubble.com/i/mask/OpenSCAD-The-Dark-Side-by-MichaelAtOz/27096391.6BSL1?asc=u  -
The Dark Side Fitted Mask
data-scale=1.031 data-rotate=0 class=sevi-fit>
OpenSCAD
https://www.redbubble.com/i/mask/OpenSCAD-The-Dark-Side-by-MichaelAtOz/27096391.9G0D8?asc=u  -
The Dark Side Flat Mask
OpenSCAD
https://www.redbubble.com/i/mask/OpenSCAD-The-Dark-Side-by-MichaelAtOz/27096391.5J1F6?asc=u  -
The Dark Side Flat Small
OpenSCAD
https://www.redbubble.com/i/mask/OpenSCAD-The-Dark-Side-by-MichaelAtOz/27096391.F8Y4C?asc=u  -
The Dark Side Flat Kids
OpenSCAD - the Lighter Side
OpenSCAD
https://www.redbubble.com/i/mask/OpenSCAD-the-Lighter-Side-by-MichaelAtOz/27041979.6BSL1?asc=u  -
the Lighter Side Fitted Mask
OpenSCAD
https://www.redbubble.com/i/mask/OpenSCAD-the-Lighter-Side-by-MichaelAtOz/27041979.9G0D8?asc=u  -
the Lighter Side Flat Mask
OpenSCAD
https://www.redbubble.com/i/mask/OpenSCAD-the-Lighter-Side-by-MichaelAtOz/27041979.5J1F6?asc=u  -
the Lighter Side Flat Small
OpenSCAD
https://www.redbubble.com/i/mask/OpenSCAD-the-Lighter-Side-by-MichaelAtOz/27041979.F8Y4C?asc=u  -
the Lighter Side Flat Kids
OpenSCAD - The Alt-Dark Side
data-scale=1 data-rotate=0 class="">
OpenSCAD
https://www.redbubble.com/i/mask/OpenSCAD-The-Alt-Dark-Side-by-MichaelAtOz/42274695.6BSL1?asc=u
  • The Alt-Dark Side Fitted Mask
OpenSCAD
https://www.redbubble.com/i/mask/OpenSCAD-The-Alt-Dark-Side-by-MichaelAtOz/42274695.9G0D8?asc=u
  • The Alt-Dark Side Flat Mask
OpenSCAD
https://www.redbubble.com/i/mask/OpenSCAD-The-Alt-Dark-Side-by-MichaelAtOz/42274695.5J1F6?asc=u
  • The Alt-Dark Side Flat Small
https://www.redbubble.com/i/mask/OpenSCAD-The-Alt-Dark-Side-by-MichaelAtOz/42274695.F8Y4C?asc=u
OpenSCAD - The Alt-Dark Side Flat Kids
OpenSCAD - the Alt-Lighter Side
OpenSCAD
<https://www.redbubble.com/i/mask/OpenSCAD-the-Alt-Lighter-Side-by-MichaelAtOz/41001332.6BSL1?asc=u
  • the Alt-Lighter Side Fitted Mask
OpenSCAD
<https://www.redbubble.com/i/mask/OpenSCAD-the-Alt-Lighter-Side-by-MichaelAtOz/41001332.9G0D8?asc=u
  • the Alt-Lighter Side Flat Mask
<https://www.redbubble.com/i/mask/OpenSCAD-the-Alt-Lighter-Side-by-MichaelAtOz/41001332.5J1F6?asc=u
OpenSCAD - the Alt-Lighter Side Flat Small
OpenSCAD
<https://www.redbubble.com/i/mask/OpenSCAD-the-Alt-Lighter-Side-by-MichaelAtOz/41001332.F8Y4C?asc=u
  • the Alt-Lighter Side Flat Kids
Fitted Masks
Features
  • Premium face-fitting mask with quality construction and vibrant print
  • Adjustable rounded non-elastic ear straps with toggle beads
  • Glasses-friendly nose wire for a snug fit
  • Three layers include two soft cotton inner layers and a polyester outer layer
  • Available in two unisex sizes. Check size guide for measurements. The male model is wearing
    a Regular size and the female model is wearing a Small size
  • Printed and sewn just for you when you order
  • Wash after each use
  • For use by ages 13 and older only. Should not be used by or placed on anyone who has
    trouble breathing or who is unconscious, incapacitated or otherwise unable to remove the mask
    without assistance, including children under age 3
Flat Masks Adult
Features
  • Non-medical face masks help you express yourself even when you can't show your face
  • Two layers of soft 95% polyester / 5% spandex fabric with sublimation print on the outside
    layer
  • 7.25" x 4.6" / 18.5 x 11.5 cm with over-ear elastic straps for a snug fit over mouth and
    nose. Each ear strap is 7" / 17.70cm (the largest size available on Redbubble)
  • Should not be used by or placed on anyone who has trouble breathing or who is unconscious,
    incapacitated or otherwise unable to remove the mask without assistance, including children under
    age 3
Flat Small-13+
Features
  • Non-medical face mask with shorter straps, for a more snug fit on smaller faces
  • Two layers of fabric with sublimated print on outer layer. Outer layer: 83% polyester, 17%
    spandex. Internal layer: 97% polyester & 3% spandex
  • 7.25" x 4.6" / 18.5 x 11.5 cm with over-ear elastic straps. Each ear strap is 6.5" / 17cm
  • Do not use as medical personal protective equipment
  • For ages 13+ only
  • Should not be placed on young children younger than 3 years of age, anyone who has trouble
    breathing, or is unconscious, incapacitated or otherwise unable to remove the cover without
    assistance
Flat Kids
Features
  • Fun designs on non-medical cloth masks in two sizes, for ages 3-12
  • Two layers of 100% polyester fabric with sublimated print on outer layer
  • Small size, recommended for ages 8-12, measures 6.7" x 3.9" / 17 x 10 cm. Over-ear elastic
    straps are 4.5" / 11.4 cm
  • Extra-small size, recommended for ages 3-7, measures 6" x 3.6" / 15 x 9 cm. Over-ear
    elastic straps are 4.5" / 11.4 cm
  • Older/larger people should use regular Masks or Teen Masks.
  • For ages 3+ only
    assistance
Redbubble <https://www.redbubble.com/people/MichaelAtOz/shop?asc=u&ref=account-nav-dropdown> added fitted masks to there products, in addition to their flat masks. Given the times we're in, these are available with zero markup (in my shop, Redbubble will take their cut). I can't testify to their medical effectiveness, they are 'non-medical' so put down that scalpel. See further below for their descriptions/features/materials etc. The three-layer polyester-outer, cotton-inners Fitted Masks come in Adult & Small-13+ sizes. The two-layer polyester Flat Masks come in Adult, Small-13+, and two Kids sizes - Small & Extra Small. In four flavours. Any questions, email me oz.at.michael@gmail.com, not the Mailing-List. (See this forum <http://forum.openscad.org/OpenSCAD-Merchandise-sales-help-support-Development-td28052.html> post for an overview of the rest of the OpenSCAD Merch., at normal mark-up) OpenSCAD - The Dark Side OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-The-Dark-Side-by-MichaelAtOz/27096391.6BSL1?asc=u> - The Dark Side Fitted Mask data-scale=1.031 data-rotate=0 class=sevi-fit> OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-The-Dark-Side-by-MichaelAtOz/27096391.9G0D8?asc=u> - The Dark Side Flat Mask OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-The-Dark-Side-by-MichaelAtOz/27096391.5J1F6?asc=u> - The Dark Side Flat Small OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-The-Dark-Side-by-MichaelAtOz/27096391.F8Y4C?asc=u> - The Dark Side Flat Kids OpenSCAD - the Lighter Side data-scale=1.031 data-rotate=0 class=sevi-fit> OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-the-Lighter-Side-by-MichaelAtOz/27041979.6BSL1?asc=u> - the Lighter Side Fitted Mask data-scale=1.031 data-rotate=0 class=sevi-fit> OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-the-Lighter-Side-by-MichaelAtOz/27041979.9G0D8?asc=u> - the Lighter Side Flat Mask OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-the-Lighter-Side-by-MichaelAtOz/27041979.5J1F6?asc=u> - the Lighter Side Flat Small OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-the-Lighter-Side-by-MichaelAtOz/27041979.F8Y4C?asc=u> - the Lighter Side Flat Kids OpenSCAD - The Alt-Dark Side data-scale=1 data-rotate=0 class=""> OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-The-Alt-Dark-Side-by-MichaelAtOz/42274695.6BSL1?asc=u> - The Alt-Dark Side Fitted Mask data-scale=1.031 data-rotate=0 class=sevi-fit> OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-The-Alt-Dark-Side-by-MichaelAtOz/42274695.9G0D8?asc=u> - The Alt-Dark Side Flat Mask OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-The-Alt-Dark-Side-by-MichaelAtOz/42274695.5J1F6?asc=u> - The Alt-Dark Side Flat Small <https://www.redbubble.com/i/mask/OpenSCAD-The-Alt-Dark-Side-by-MichaelAtOz/42274695.F8Y4C?asc=u> OpenSCAD - The Alt-Dark Side Flat Kids OpenSCAD - the Alt-Lighter Side data-scale=1.031 data-rotate=0 class=sevi-fit> OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-the-Alt-Lighter-Side-by-MichaelAtOz/41001332.6BSL1?asc=u > - the Alt-Lighter Side Fitted Mask OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-the-Alt-Lighter-Side-by-MichaelAtOz/41001332.9G0D8?asc=u > - the Alt-Lighter Side Flat Mask <https://www.redbubble.com/i/mask/OpenSCAD-the-Alt-Lighter-Side-by-MichaelAtOz/41001332.5J1F6?asc=u > OpenSCAD - the Alt-Lighter Side Flat Small OpenSCAD <https://www.redbubble.com/i/mask/OpenSCAD-the-Alt-Lighter-Side-by-MichaelAtOz/41001332.F8Y4C?asc=u > - the Alt-Lighter Side Flat Kids Fitted Masks Features * Premium face-fitting mask with quality construction and vibrant print * Adjustable rounded non-elastic ear straps with toggle beads * Glasses-friendly nose wire for a snug fit * Three layers include two soft cotton inner layers and a polyester outer layer * Available in two unisex sizes. Check size guide for measurements. The male model is wearing a Regular size and the female model is wearing a Small size * Printed and sewn just for you when you order * Wash after each use * For use by ages 13 and older only. Should not be used by or placed on anyone who has trouble breathing or who is unconscious, incapacitated or otherwise unable to remove the mask without assistance, including children under age 3 Flat Masks Adult Features * Non-medical face masks help you express yourself even when you can't show your face * Two layers of soft 95% polyester / 5% spandex fabric with sublimation print on the outside layer * 7.25" x 4.6" / 18.5 x 11.5 cm with over-ear elastic straps for a snug fit over mouth and nose. Each ear strap is 7" / 17.70cm (the largest size available on Redbubble) * Wash after each use * For use by ages 13 and older only * Should not be used by or placed on anyone who has trouble breathing or who is unconscious, incapacitated or otherwise unable to remove the mask without assistance, including children under age 3 Flat Small-13+ Features * Non-medical face mask with shorter straps, for a more snug fit on smaller faces * Two layers of fabric with sublimated print on outer layer. Outer layer: 83% polyester, 17% spandex. Internal layer: 97% polyester & 3% spandex * 7.25" x 4.6" / 18.5 x 11.5 cm with over-ear elastic straps. Each ear strap is 6.5" / 17cm * Wash after each use * Do not use as medical personal protective equipment * For ages 13+ only * Should not be placed on young children younger than 3 years of age, anyone who has trouble breathing, or is unconscious, incapacitated or otherwise unable to remove the cover without assistance Flat Kids Features * Fun designs on non-medical cloth masks in two sizes, for ages 3-12 * Two layers of 100% polyester fabric with sublimated print on outer layer * Small size, recommended for ages 8-12, measures 6.7" x 3.9" / 17 x 10 cm. Over-ear elastic straps are 4.5" / 11.4 cm * Extra-small size, recommended for ages 3-7, measures 6" x 3.6" / 15 x 9 cm. Over-ear elastic straps are 4.5" / 11.4 cm * Older/larger people should use regular Masks or Teen Masks. * Wash after each use * Do not use as medical personal protective equipment * For ages 3+ only * Should not be placed on young children younger than 3 years of age, anyone who has trouble breathing, or is unconscious, incapacitated or otherwise unable to remove the cover without assistance -- This email has been checked for viruses by AVG. https://www.avg.com
