MA
Mohammad Abdussalam
Wed, Jul 31, 2024 7:57 PM
Hello everyone,
I'm Mohammad, the GSoC contributor working on the development of the new
Library Manager as part of GSoC 2024.
I'm excited to announce that the tool is nearing its trial phase! This
Library Manager will function as a centralized repository for OpenSCAD
libraries, similar to Arduino's Library Manager. You can check out the code
here: https://github.com/openscad/openscad-library-manager
Purpose: The Library Manager aims to simplify the process of finding,
installing, and managing software libraries, saving developers valuable
time and effort.
Benefits:
- Discoverability: Easily find and explore available libraries.
- Efficiency: Streamline the installation and update process.
- Organization: Manage your library dependencies effectively.
To ensure the tool is robust and user-friendly, we're seeking volunteers
with small libraries to participate in our trial phase. Your feedback will
be invaluable as we refine the tool.
If you're interested in helping us test the Library Manager, please reply
to this email with a brief description of your library.
We'll be sharing more details about the trial phase and how to participate
in the coming days.
Thank you for your support!
Best,
Mohammad
Hello everyone,
time and effort.
Benefits:
in the coming days.
Best,
Mohammad
KT
Kevin Toppenberg
Thu, Aug 1, 2024 2:08 AM
Dumb question: What is GSoC? Is it OpenSCAD?
KT
On Wed, Jul 31, 2024 at 3:59 PM Mohammad Abdussalam via Discuss <
Hello everyone,
time and effort.
Benefits:
in the coming days.
Best,
Mohammad
KT
> Hello everyone,
> time and effort.
> Benefits:
> in the coming days.
> Best,
> Mohammad
DP
David Phillip Oster
Thu, Aug 1, 2024 2:09 AM
KT
Hello everyone,
time and effort.
Benefits:
participate in the coming days.
Best,
Mohammad
Google Summer of Code
On Wed, Jul 31, 2024 at 7:08 PM Kevin Toppenberg via Discuss <
> KT
> discuss@lists.openscad.org> wrote:
>> Hello everyone,
>> time and effort.
>> Benefits:
>> Best,
>> Mohammad
PK
Peter Kriens
Fri, Aug 2, 2024 7:13 AM
Is there a reason you need to specify a slightly larger object for difference() than the parent object to make a clean cut?
If they are equal, the F5 renders it badly but the F6 manifold is more than fine. The code looks a lot cleaner and reduces potential collisions.
The question is probably already asked but I could not find it in searching the list. Pointers are thus also appreciated.
Kind regards,
Peter Kriens
Kind regards,
Peter Kriens
Fri, Aug 2, 2024 8:20 AM
It's the same in real life. You have to start a drill above the surface you
are drilling and drill past the bottom of the object to get a clean hole.
The reason you have to do it in OpenSCAD is it uses OpenCSG to draw the
preview and that uses the z-buffer of your graphics card which has finite
resolution.
On Fri, 2 Aug 2024 at 08:13, Peter Kriens via Discuss <
Kind regards,
Peter Kriens
resolution.
> Kind regards,
> Peter Kriens
Fri, Aug 2, 2024 10:36 AM
Actually if they are equal the F6 manifold is sometimes fine. But not
always. Sometimes you'll get a zero thickness layer over your hole. I
assume this depends on round off error. If the face is orthogonal to the
axes it will work OK. But if the face is at some angle then you may end up
getting the two "identical" faces in slightly different places, such as by
10^-12 and if the hole cutting ends up on the wrong side you then get the
phantom extra face. This doesn't have anything to do with using the
z-buffer on your graphics card---that's related to F5, which OP already
notes will fail, but he apparently doesn't care if F5 works.
On Fri, Aug 2, 2024 at 4:10 AM nop head via Discuss <
you are drilling and drill past the bottom of the object to get a clean
hole.
resolution.
Kind regards,
Peter Kriens
Actually if they are equal the F6 manifold is **sometimes** fine. But not
> hole.
> resolution.
>> Kind regards,
>> Peter Kriens
PK
Peter Kriens
Fri, Aug 2, 2024 11:41 AM
Ok, thanks.
Just a bit surprised. I am a developer myself and it seems not too hard to remove these types of faces that have a thickness less than some very small value?
As a mechanic I know I have to handle real life and its messiness, but as a developer it would be nice to take the more platonic world of a digital model?
Am I still missing something?
Kind regards,
Peter Kriens
On 2 Aug 2024, at 12:36, Adrian Mariano via Discuss discuss@lists.openscad.org wrote:
Actually if they are equal the F6 manifold is sometimes fine. But not always. Sometimes you'll get a zero thickness layer over your hole. I assume this depends on round off error. If the face is orthogonal to the axes it will work OK. But if the face is at some angle then you may end up getting the two "identical" faces in slightly different places, such as by 10^-12 and if the hole cutting ends up on the wrong side you then get the phantom extra face. This doesn't have anything to do with using the z-buffer on your graphics card---that's related to F5, which OP already notes will fail, but he apparently doesn't care if F5 works.
On Fri, Aug 2, 2024 at 4:10 AM nop head via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
It's the same in real life. You have to start a drill above the surface you are drilling and drill past the bottom of the object to get a clean hole.
The reason you have to do it in OpenSCAD is it uses OpenCSG to draw the preview and that uses the z-buffer of your graphics card which has finite resolution.
On Fri, 2 Aug 2024 at 08:13, Peter Kriens via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
Kind regards,
Peter Kriens
Ok, thanks.
Kind regards,
Peter Kriens
> On 2 Aug 2024, at 12:36, Adrian Mariano via Discuss <discuss@lists.openscad.org> wrote:
> Actually if they are equal the F6 manifold is **sometimes** fine. But not always. Sometimes you'll get a zero thickness layer over your hole. I assume this depends on round off error. If the face is orthogonal to the axes it will work OK. But if the face is at some angle then you may end up getting the two "identical" faces in slightly different places, such as by 10^-12 and if the hole cutting ends up on the wrong side you then get the phantom extra face. This doesn't have anything to do with using the z-buffer on your graphics card---that's related to F5, which OP already notes will fail, but he apparently doesn't care if F5 works.
> On Fri, Aug 2, 2024 at 4:10 AM nop head via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote:
>> On Fri, 2 Aug 2024 at 08:13, Peter Kriens via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote:
>>> Kind regards,
>>> Peter Kriens
>>> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org>
Fri, Aug 2, 2024 12:01 PM
It might be possible to remove zero thickness faces in the render but not
in the preview as no geometry is calculated. It is just drawn and relies on
the z-buffer to decide what is visible. When faces are coincident you get a
shimmering effect because the fixed point z-buffer values are not exact
depending on the angle of the face. Some pixels decide one object is in
front and other pixels decide the other object is in front. When you make
the extracted object slightly longer it is always in front.
On Fri, 2 Aug 2024 at 12:42, Peter Kriens via Discuss <
Ok, thanks.
small value?
model?
Kind regards,
Peter Kriens
hole.
resolution.
Kind regards,
Peter Kriens
> Ok, thanks.
> small value?
> model?
> Kind regards,
> Peter Kriens
>> hole.
>> resolution.
>>> Kind regards,
>>> Peter Kriens
GB
Glenn Butcher
Fri, Aug 2, 2024 12:04 PM
Ambiguity exists in both worlds. Floating point precision for all its
goodness creates a bit of a monster with regard to definite values,
something necessary for that 'platonic world'.
For what it's worth...
Glenn Butcher
On 8/2/2024 5:41 AM, Peter Kriens via Discuss wrote:
Ok, thanks.
digital model?
Kind regards,
Peter Kriens
clean cut?
Kind regards,
Peter Kriens
Glenn Butcher
> Ok, thanks.
> digital model?
> Kind regards,
> Peter Kriens
>> clean cut?
>> Kind regards,
>> Peter Kriens
Fri, Aug 2, 2024 12:27 PM
Yes and binary floating point has a lot more infinitely recurring fractions
than decimal, for example 0.1 is not exactly representable. When
objects are rotated then most numbers become irrational, so can't be
represented exactly numerically, only symbolically.
On Fri, 2 Aug 2024 at 13:04, Glenn Butcher via Discuss <
Glenn Butcher
Ok, thanks.
small value?
model?
Kind regards,
Peter Kriens
hole.
resolution.
Kind regards,
Peter Kriens
> Glenn Butcher
> Ok, thanks.
> small value?
> model?
> Kind regards,
> Peter Kriens
>> hole.
>> resolution.
>>> Kind regards,
>>> Peter Kriens
