I can't find anything wrong with that STL with either NetFabb or OpenSCAD,
so I don't understand how they can do more with an STL from FreeCAD. As far
as I know there are only ASCII and binary STLs and they contain the same
information. I don't think there is any way to embed any more information.
It might be worth checking if it is a binary / ASCII issue but it seems
very unlikely if they can open it.
On Wed, 16 Nov 2022 at 04:56, William F. Adams via Discuss <
To: "discuss@lists.openscad.org" discuss@lists.openscad.org
Cc:
Bcc:
Date: Wed, 16 Nov 2022 04:55:43 +0000 (UTC)
Subject: [OpenSCAD] Re: SolidWorks & OpenSCAD interoperability
Unfortunately, CAD software importing STLs is an operation fraught w/
problems and incompatibilities.
Best thing to do is to create DXFs which mimic the sorts of
drawings/prints which these folks work with and expect (annotate them well,
and try to design them for ease of machining/manufacture) --- then they can
recreate the file in Solidworks which they can then use their CAM software
to create G-code.
From: "William F. Adams via Discuss" discuss@lists.openscad.org
Cc: "William F. Adams" willadams@aol.com
Bcc:
Sorry I meant to send it to the list.
Cc:
Bcc:
to create G-code.
Bcc:
You're absolutely right.
I had to infer what the problem was. I think they confused ".stl" file with ".stp" file. It's only a one letter difference.
------- Original Message -------
On Wednesday, November 16th, 2022 at 12:57 AM, nop head nop.head@gmail.com wrote:
I can't find anything wrong with that STL with either NetFabb or OpenSCAD, so I don't understand how they can do more with an STL from FreeCAD. As far as I know there are only ASCII and binary STLs and they contain the same information. I don't think there is any way to embed any more information.
It might be worth checking if it is a binary / ASCII issue but it seems very unlikely if they can open it.
On Wed, 16 Nov 2022 at 04:56, William F. Adams via Discuss discuss@lists.openscad.org wrote:
Cc:
Bcc:
Unfortunately, CAD software importing STLs is an operation fraught w/ problems and incompatibilities.
Best thing to do is to create DXFs which mimic the sorts of drawings/prints which these folks work with and expect (annotate them well, and try to design them for ease of machining/manufacture) --- then they can recreate the file in Solidworks which they can then use their CAM software to create G-code.
Bcc:
