Note that I get it once, and then it disappears the 2nd time.
WARNING: Attempted to remove too many vertices around this copied face,
remesh aborted!
Geometries in cache: 517
Geometry cache size in bytes: 39490152
CGAL Polyhedrons in cache: 289
CGAL cache size in bytes: 36957104
Total rendering time: 0:00:04.879
Facets: 8272
Rendering finished.
Total rendering time: 0:00:00.151
Facets: 8272
Rendering finished.
[ Jon: sorry for the duplicate; new mail client installation meant that
I sent from the wrong address. ]
I can't speak to the meaning of the error, but the disappearance is an
understood behavior: OpenSCAD caches the (errneous!) results of the
first render attempt, and then doesn't actually do the work that leads
to the error on the second attempt.
I believe this comes from the experimental fast-csg feature.
If you manage to reproduce this with a somewhat simple test model, it’s worth opening an issue.
However, I’d suggest giving the Manifold feature a try; it’s getting a lot more attention than fast-csg these days.
WARNING: Attempted to remove too many vertices around this copied face, remesh aborted!
Facets: 8272
Rendering finished.
Facets: 8272
Rendering finished.
