Re: disappearing code
Gene Heskett
Thu, Dec 9, 2021 5:12 PM
On Thu, 9 Dec, 2021 at 10:35 AM, Leonard Martin Struttmann lenstruttmann@gmail.com wrote:
To: openscad general discussion
Gene, I see it but it is very small.
Why are you passing a vector to cylinder()?
Should not that be:
cylinder(2,2,20,center=true); // latch bumps
I have them placed and the printer is warming up.
It was a cast iron bitch getting the rotate's and translate's right but enough iterations
got it. Buried about .25mm of the base of each triangle in the top of each sidewall.
Maybe someday I'll get it. But at 87, the short term memory is very short. :(
Thanks Leonard.
Cheers, gene
On Thu, 9 Dec, 2021 at 10:35 AM, Leonard Martin Struttmann <lenstruttmann@gmail.com> wrote: To: openscad general discussion Gene, I see it but it is very small. Why are you passing a vector to cylinder()? Should not that be: cylinder(2,2,20,center=true); // latch bumps ? I have them placed and the printer is warming up. It was a cast iron bitch getting the rotate's and translate's right but enough iterations got it. Buried about .25mm of the base of each triangle in the top of each sidewall. Maybe someday I'll get it. But at 87, the short term memory is very short. :( Thanks Leonard. Cheers, gene
