Sorry for an off topic question but there must be some Github experts on
this list.
I want to compare the heads of two branches and show all the file
differences. Github compare seems to do something different and is not
commutative. For example
https://github.com/openscad/openscad/compare/master...c++11 is not the same
as https://github.com/openscad/openscad/compare/c++11...master. I would
expect it to simply to swap left and right making additions deletions, etc.
I think it must find the point where the branches diverged and show the
difference of one branch with respect to that. Is there a way to show the
difference between the two heads?
Looks like it should be two dots instead of three in git diff but Github
compare doesn't support it, bummer!
this list.
same as https://github.com/openscad/openscad/compare/c++11...master. I
would expect it to simply to swap left and right making additions
deletions, etc.
On Jan 16, 2016, at 07:40 AM, nop head nop.head@gmail.com wrote:
Looks like it should be two dots instead of three in git diff but Github compare doesn't support it, bummer!
Yep, that’s correct.
You can simply do that on the cmd-line though: git diff origin/c++11..origin/master
There might be git GUI wrappers showing a graphical diff as well, but I don’t generally use those.
Odd they don't support it. I even found some of their code that converted
two dots to three dots. It seems a massive gap in functionality and very
easy to implement if they use git as in their back end.
The reason I like using github compare is because it can show image
differences and STL differences graphically. I might have to create a dummy
repository and check in the files I want to compare sequentially and then
delete it again.
