On 3/14/2020 12:57 PM, Jordan Brown wrote:
Thanks, all. Good stuff to chew on.
So I chewed. The truly right answer is Adrian's - use a library - but I
wanted to understand the math. (And Adrian's implementation was too
complete to easily extract just the math.)
After some chewing, I understand some of the math.
Kristian and Parkinbot's answers seemed similar, but even after throwing
a fair amount of algebra at them I couldn't make them be the same.
I ran some tests, and lo and behold, they aren't the same.
Kristian's appears to be the one that I want, the "pointy" answer, the
one equivalent to offset(delta=xxx, chamfer=false).
Parkinbot's appears to be equivalent to offset(delta=xxx, chamfer=true)
or offset(r=xxx). Those are probably the more useful variants in
general, but not for my particular case where I need the points
connected by straight lines.
Thanks!
