AD
Ari Diacou
Fri, Feb 24, 2017 11:10 PM
I am trying to write arithmetic, geometric and harmonic mean functions in
openscad.
It appears I need to use recursion (
Here is my program:
echo(sum([1,2,3]));
function sum(values,i=0)=(
(i==len(values)) ?
values[i] :
values[i] + sum(values, //f,
i+1)
The output should be 6. with the comment in line 5, the output is undef, if
you uncomment the "f," you get 5 errors, not 3, which means there are too
many calls.
Can anyone give me some help?
I took a look at the WikiBook, but it didnt help me much:
https://en.wikibooks.org/w/index.php?title=OpenSCAD_User_
Manual/User-Defined_Functions_and_Modules&stable=0#Recursive_functions
Or if you have already written the functions I want (product, sum,
aritmentic mean, harmonic mean, and geometric mean) of a list of values,
send me those.
Thanks,
Ari M Diacou, Metis Industries
openscad.
Here is my program:
echo(sum([1,2,3]));
(i==len(values)) ?
values[i] :
i+1)
many calls.
send me those.
Thanks,
Fri, Feb 24, 2017 11:18 PM
When i == len(values) you return values[i] but lists are indexed from 0, so
you are try to access one past the end, hence the undef.
openscad.
Here is my program:
echo(sum([1,2,3]));
(i==len(values)) ?
values[i] :
i+1)
if you uncomment the "f," you get 5 errors, not 3, which means there are
too many calls.
https://en.wikibooks.org/w/index.php?title=OpenSCAD_User_Man
send me those.
Thanks,
> openscad.
> Here is my program:
> echo(sum([1,2,3]));
> (i==len(values)) ?
> values[i] :
> i+1)
> too many calls.
> send me those.
> Thanks,
AD
Ari Diacou
Fri, Feb 24, 2017 11:20 PM
so you are try to access one past the end, hence the undef.
openscad.
Here is my program:
echo(sum([1,2,3]));
(i==len(values)) ?
values[i] :
i+1)
too many calls.
send me those.
Thanks,
Thanks a lot nophead!
>> openscad.
>> Here is my program:
>> echo(sum([1,2,3]));
>> (i==len(values)) ?
>> values[i] :
>> i+1)
>> too many calls.
>> send me those.
>> Thanks,
Fri, Feb 24, 2017 11:21 PM
echo(sum([1,2,3]));
function sum(values, i = 0) =
i == len(values) ? 0 : values[i] + sum(values, i + 1);
Works.
openscad.
Here is my program:
echo(sum([1,2,3]));
(i==len(values)) ?
values[i] :
i+1)
too many calls.
send me those.
Thanks,
echo(sum([1,2,3]));
Works.
>> openscad.
>> Here is my program:
>> echo(sum([1,2,3]));
>> (i==len(values)) ?
>> values[i] :
>> i+1)
>> too many calls.
>> send me those.
>> Thanks,
AD
Ari Diacou
Fri, Feb 24, 2017 11:23 PM
Nice, I like that format better.
On Fri, Feb 24, 2017 at 6:21 PM, nop head nop.head@gmail.com wrote:
echo(sum([1,2,3]));
Works.
in openscad.
Here is my program:
echo(sum([1,2,3]));
(i==len(values)) ?
values[i] :
i+1)
too many calls.
send me those.
Thanks,
On Fri, Feb 24, 2017 at 6:21 PM, nop head <nop.head@gmail.com> wrote:
> echo(sum([1,2,3]));
> Works.
>>> in openscad.
>>> Here is my program:
>>> echo(sum([1,2,3]));
>>> (i==len(values)) ?
>>> values[i] :
>>> i+1)
>>> too many calls.
>>> send me those.
>>> Thanks,
Fri, Feb 24, 2017 11:25 PM
echo(sum([1,2,3]));
function sum(values, i = 0, sum = 0) =
i == len(values) ? sum : sum(values, i + 1, sum + values[i]);
Is a better way to do it because it uses tail recursion. I.e. it ends by
calling itself. That is optimised to a loop by OpenSCAD, so it doesn't run
out of stack.
echo(sum([1,2,3]));
Works.
in openscad.
Here is my program:
echo(sum([1,2,3]));
(i==len(values)) ?
values[i] :
i+1)
undef, if you uncomment the "f," you get 5 errors, not 3, which means there
are too many calls.
send me those.
Thanks,
echo(sum([1,2,3]));
out of stack.
>> echo(sum([1,2,3]));
>> Works.
>>>> in openscad.
>>>> Here is my program:
>>>> echo(sum([1,2,3]));
>>>> (i==len(values)) ?
>>>> values[i] :
>>>> i+1)
>>>> are too many calls.
>>>> send me those.
>>>> Thanks,
AD
Ari Diacou
Fri, Feb 24, 2017 11:28 PM
That was the part of the wikibook i didn't understand, although I at least
updated the link to the wikipedia article.
On Fri, Feb 24, 2017 at 6:25 PM, nop head nop.head@gmail.com wrote:
echo(sum([1,2,3]));
out of stack.
echo(sum([1,2,3]));
Works.
0, so you are try to access one past the end, hence the undef.
in openscad.
Here is my program:
echo(sum([1,2,3]));
(i==len(values)) ?
values[i] :
i+1)
are too many calls.
send me those.
Thanks,
On Fri, Feb 24, 2017 at 6:25 PM, nop head <nop.head@gmail.com> wrote:
> echo(sum([1,2,3]));
> out of stack.
>>> echo(sum([1,2,3]));
>>> Works.
>>>>> in openscad.
>>>>> Here is my program:
>>>>> echo(sum([1,2,3]));
>>>>> (i==len(values)) ?
>>>>> values[i] :
>>>>> i+1)
>>>>> are too many calls.
>>>>> send me those.
>>>>> Thanks,
Fri, Feb 24, 2017 11:33 PM
The difference is the previous version has to add values[i] after it calls
itself, so it has to actually recurse. When the tail is just a call to
itself with nothing to do afterwards it can be made into a loop.
echo(sum([1,2,3]));
out of stack.
echo(sum([1,2,3]));
Works.
functions in openscad.
Here is my program:
echo(sum([1,2,3]));
(i==len(values)) ?
values[i] :
i+1)
are too many calls.
send me those.
Thanks,
>> echo(sum([1,2,3]));
>> out of stack.
>>>> echo(sum([1,2,3]));
>>>> Works.
>>>>>> Here is my program:
>>>>>> echo(sum([1,2,3]));
>>>>>> (i==len(values)) ?
>>>>>> values[i] :
>>>>>> i+1)
>>>>>> are too many calls.
>>>>>> send me those.
>>>>>> Thanks,
Sat, Feb 25, 2017 12:24 AM
There is some code about similar functions in the Tips and Tricks
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Tips_and_Tricks#Add_all_values_in_a_list
section of the Manual. The simpler and non-recursive solution I know for
your case is:
function sum(values) = [for(p=values) 1]*values;
It works with list of numbers and list of vectors.
<https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Tips_and_Tricks#Add_all_values_in_a_list>
your case is:
AD
Ari Diacou
Sat, Feb 25, 2017 2:33 AM
I think it works now:
A=[2,3,4];
m=-2;
echo(str("A=",A));
echo(str("power mean(A,",m,")=",power_mean(A,m)));
echo(str("arithmetic mean=",mean(A)));
echo(str("harmonic mean=",harmonic_mean(A)));
echo(str("sum=",sum(A)));
echo(str("product=",product(A)));
echo(str("invert(A)=",invert(A)));
echo(str("power_each(A,",m,")=",power_each(A,m)));
//outputs the sum of a list of values
//uses recursion, but takes advantage of OpenSCAD's automatic looping
of certain recursive function formats.
i==len(values) ? 0 :
values[i] + sum(values, i+1)
function product(values,i=0)=(
//outputs the product of a list of values
i==len(values) ? 1 :
values[i]*product(values, i+1)
function mean(values,i=0)=(
//outputs the arithmetic mean of a list of values
//See https://en.wikipedia.org/wiki/Mean#Arithmetic_mean
)/len(values);
function geometric_mean(values)=pow(product(values),1/len(values));
//outputs the geometric mean of a list of values //uses recursion, but
takes advantage of OpenSCAD's automatic looping of certain recursive
function formats. See https://en.wikipedia.org/wiki/Mean#Geometric_mean
function harmonic_mean(values,i=0)=len(values)/sum(invert(values));
//outputs the harmonic mean of a list of values //uses recursion, but takes
advantage of OpenSCAD's automatic looping of certain recursive function
formats. //See https://en.wikipedia.org/wiki/Mean#Harmonic_mean
function invert(values)=[for(i=[0:len(values)-1]) 1/values[i]]; //inverts
each value in a list
function power_each(values,n)=[for(i=[0:len(values)-1]) pow(values[i],n)];
//returns a list of each value in a list raised to the power of n. n can be
any value.
function
power_mean(values,m)=pow(sum(power_each(values,m))/len(values),1/m); //See
https://en.wikipedia.org/wiki/Mean#Generalized_means
echo(sum([1,2,3]));
out of stack.
echo(sum([1,2,3]));
Works.
Here is my program:
echo(sum([1,2,3]));
(i==len(values)) ?
values[i] :
i+1)
are too many calls.
send me those.
Thanks,
A=[2,3,4];
m=-2;
echo(str("A=",A));
)/len(values);
any value.
function
>> echo(sum([1,2,3]));
>> out of stack.
>>>> echo(sum([1,2,3]));
>>>> Works.
>>>>>> Here is my program:
>>>>>> echo(sum([1,2,3]));
>>>>>> (i==len(values)) ?
>>>>>> values[i] :
>>>>>> i+1)
>>>>>> are too many calls.
>>>>>> send me those.
>>>>>> Thanks,
