boxcarmib wrote
It's straightforward to save an object in .off format, and then using an
external program i wrote, create an openscad program that describes the
object as a polyhedron using the points and faces from the .off data.
My question is this, and its directed to those of you familiar with the
openscad source:
How hard would it be to create a function that effectively calls the
program logic that creates the .off export and returns a two element
matrix of points and faces?
I'm thinking of a module that would work something like render() does,
providing the points and faces for whatever has been defined at the point
the function is called.
Having some programming experience I'd be interested in pursuing the
development of such a function, but I'd like an opinion from someone who
knows what's under the hood if this is just an impractical or staggeringly
complex project.
Your post is still flagged as "This post has NOT been accepted by the
mailing list yet", so nobody gets it unless they look. So I quoted it above.
You need to subscribe to the mailing list
and CLICK THE LINK in the registration email (check your spam folder).
Stand by for the philosophical discussion...
View this message in context: http://forum.openscad.org/how-easy-to-make-off-export-a-function-call-tp21595p21596.html
There is no resource in OpenSCAD language to write a file. There is
neither any way to get vertex and edge data for a given model. The only
text output you may get is by echo() and it is directed to the console
window.
On May 30, 2017, at 09:04, Ronaldo Persiano rcmpersiano@gmail.com wrote:
There is no resource in OpenSCAD language to write a file. There is neither any way to get vertex and edge data for a given model. The only text output you may get is by echo() and it is directed to the console window.
This could be made a UI feature though (e.g. select a node/subtree and inline it).
Here is some similar work in progress where I’m modifying the CSG export to resolve nodes like import() into a polyhedron:
https://github.com/openscad/openscad/pull/1882
