Greetings all;
Whats the relative speed between:
359 iterations of a cylinder(h=3.175,r=5,center=true);
and 359 iterations of a cube with 3 var args,center=true?
The point being that a cube just wide enough vs a sq made by cylinder,
would leave a smoother surface on both inside and outside of the thread.
If the cube is faster, I'll convert this code.
Depends on too much else, so here is a (too ?) simple test
for ( i = [1:400] ) translate([i,i/2,i/4])
cube([1+i/100,2+i/88,2-i/88],center=true) ;
cylinder(r=3.2,h=3+i/100,center=true) ;
Geometry cache size in bytes: 291928 Geometry cache size in bytes:
2003928
CGAL Polyhedrons in cache: 1 CGAL Polyhedrons in cache: 3
CGAL cache size in bytes: 5699488 CGAL cache size in bytes: 22387440
Total rendering time: 0:00:41.585 Total rendering time: 0:01:09.567
Top level object is a 3D object: Top level object is a 3D object:
Simple: yes Simple: yes
Vertices: 3998 Vertices: 10396
Halfedges: 12792 Halfedges: 31188
Edges: 6396 Edges: 15594
Halffacets: 4800 Halffacets: 10400
Facets: 2400 Facets: 5200
Volumes: 2 Volumes: 2
Rendering finished. Rendering finished.
On Wed, 9 Feb 2022 at 12:23, gene heskett gheskett@shentel.net wrote:
Greetings all;
2003928
22387440 Total rendering time: 0:00:41.585 Total rendering
time: 0:01:09.567 Top level object is a 3D object: Top level
object is a 3D object: Simple: yes
Simple: yes Vertices: 3998 Vertices:
10396 Halfedges: 12792 Halfedges: 31188
Halffacets: 4800 Halffacets: 10400 Facets:
2400 Facets: 5200 Volumes: 2
Volumes: 2 Rendering finished.
Rendering finished.
if the left column is cube, it wins, and the right column is cylinder,
its slower but they are not identified as to which is which here.
Greetings all;
cylinder,
thread.
But Ray pointed out in a PM that for wood, I should use a buttress
thread, which they don't grind mills for, but a 60 degree engraving bit
with a 20 degree wedge under the motor mount would come pretty close, so
thats being considered.
Thanks all.
Michael,
I am puzzled as to why I am seeing only half the geometry that your cube test generates whilst the cylinder matches exactly.
But I do like the performance of Marius’s M1 native OpenSCAD build.
Cube
for ( i = [1:400] ) translate([i,i/2,i/4]) cube([1+i/100,2+i/88,2-i/88],center=true) ;
Geometry cache size in bytes: 323200
CGAL cache size in bytes: 2715136
Total rendering time: 0:00:02.859
Simple: yes
Vertices: 2012
Halfedges: 6036
Edges: 3018
Halffacets: 2100
Facets: 1050
Volumes: 23
Rendering finished.
Cylinder
for ( i = [1:400] ) translate([i,i/2,i/4]) cylinder(r=3.2,h=3+i/100,center=true) ;
Geometry cache size in bytes: 1712000
CGAL Polyhedrons in cache: 2
CGAL cache size in bytes: 16687952
Total rendering time: 0:00:17.202
Simple: yes
Vertices: 10396
Halfedges: 31188
Edges: 15594
Halffacets: 10400
Facets: 5200
Volumes: 2
Rendering finished.
Geometry cache size in bytes: 291928 Geometry cache size in bytes: 2003928
On Wed, 9 Feb 2022 at 12:23, gene heskett <gheskett@shentel.net mailto:gheskett@shentel.net> wrote:
Greetings all;
I am puzzled, too. I get the lower value now. Ah... sorry, cut-n-paste
error, that was from an earlier run
cube([1+i/100,2+i/88,2-i/88],center=true) ; // fewer
for ( i = [1:400] ) translate([i,i/2,i/4]) cube([1,2,3],center=true) ;
// more.
"I leave it to the reader as an exercise to explain why" ;-) - I haven't
the foggiest
On Wed, 9 Feb 2022 at 16:33, Bob Carter caggius@gmail.com wrote:
Michael,
Cube
Simple: yes
Vertices: 2012
Halfedges: 6036
Edges: 3018
Halffacets: 2100
Facets: 1050
Volumes: 23
Rendering finished.
Cylinder
Simple: yes
Vertices: 10396
Halfedges: 31188
Edges: 15594
Halffacets: 10400
Facets: 5200
Volumes: 2
Rendering finished.
2003928
object:
Greetings all;
the foggiest
Perhaps because when i/88 > 2, the cube has 0 size in z?
2003928
Rendering finished.
Greetings all;
cylinder,
thread.
Thanks all.
Of course. <facepalm slap!>
It shows that a "quick test case" ... there is no such thing. A test case
needs as careful coding as a "real" code. I just threw in the
"/88 +-something" to make nonidentical cubes. Didn't think it through. Just
wanted to show that of course a cube is faster than a cylinder - less
triangles, no trigonometry and so on.
Well, now I have to go and wash this egg off my shirt ....;-)
On Thu, 10 Feb 2022 at 00:58, Will Hardiman bill.hardiman1995@gmail.com
haven't the foggiest
2003928
Rendering finished.
Greetings all;
cylinder,
thread.
Thanks all.
For what it's worth... in my experience, linear_extrude() of a circle or
a square will render /much/ faster than cylinder() or cube().
You can seamlessly replace cylinder()s with extruded circles by
including this module:
module cylinder(d,h,center=false) {
z = center? -h/2 : 0;
translate([0,0,z]) linear_extrude(height=h) circle(d=d);
On 2/9/2022 6:03 AM, gene heskett wrote:
Greetings all;
Cheers, Gene Heskett.
