OpenSCAD general discussion
Re: first class modules WIP
AL
Andy Little
Wed, Sep 7, 2022 12:18 PM
Continuing work on the module_alias feature
Now most stuff in https://github.com/kwikius/openscad/tree/WIP-first-class-module/tests/data/scad/experimental/first_class_module is working
Only part not done is member access)
(https://github.com/kwikius/openscad.git
To test it  ( tested on Linux only)
$ git clone -b WIP-first-class-module --single-branch https://github.com/kwikius/openscad.git
$ cd openscad
$ mkdir build
$ cd build
$ cmake .. -DEXPERIMENTAL=1
$ make -j2
#invoke local version of the openscad executable
$ ./openscad
On Monday, 5 September 2022 at 11:16:48 BST, kwikius--- via Discuss <discuss@lists.openscad.org> wrote:
done
https://github.com/kwikius/openscad/blob/WIP-first-class-module/tests/data/scad/experimental/first_class_module/object_existing.scad
Continuing work on the module_alias feature Now most stuff in https://github.com/kwikius/openscad/tree/WIP-first-class-module/tests/data/scad/experimental/first_class_module is working Only part not done is member access) (https://github.com/kwikius/openscad.git To test it  ( tested on Linux only) >$ git clone -b WIP-first-class-module --single-branch https://github.com/kwikius/openscad.git   >$ cd openscad >$ mkdir build >$ cd build >$ cmake .. -DEXPERIMENTAL=1   >$ make -j2 #invoke local version of the openscad executable >$ ./openscad On Monday, 5 September 2022 at 11:16:48 BST, kwikius--- via Discuss <discuss@lists.openscad.org> wrote: done https://github.com/kwikius/openscad/blob/WIP-first-class-module/tests/data/scad/experimental/first_class_module/object_existing.scad _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org
