I haven't found this topic by searching. Please let me know if it's already
been discussed.
When I do --info from the command line, I get a warning that looks like:
Fontconfig warning: "/Applications/OpenSCAD.app/Contents/Resources/fonts/fonts.conf", line 84: unknown element "blank"
Anybody know what this is about? I figured I'd ask before I go digging.
Looks like Linux, not my specialty, but try; close OpenSCAD, rename that to
fonts.conf.old, run OpenSCAD, if it's the file I think it is, it will get
rebuilt, if not change it back and await an Linux aware answer.
I see this warning under OS X as well.
-Revar
In the file is said if you have errors to report it, so I did. They said openscad needs to update. Which was obvious once I read the error message more closely headslap
I did try removing the file, but it didn’t fix itself.
I’m going to try building from the latest source, and see what we can do.
-Revar
