Today, I have two ways I do my scripts:
Use a program I've written to generate the scripts from Excel, where I do
my calculations. This makes for awkward script programming when I want to do
something complicated, but it allows me to use the measurements as input for
a parts list when I'm going to buy stuff when building the object.
Use Excel to simply generate a few seed measurements variables into a
script which I include in the main script, then script normally and do the
calculations in the script. Neater scripting, but doesn't allow me to export
the calculated values in a sample way, so I can't generate the parts lists.
I would like to work according to #2, but that would require duplicating a
lot of calculations (with all the errors that'll bring). However, if there
was a simple way to export some variables, it would be doable.
Basically, something like (for example):
writefile("c:\temp\myfile.txt", myvar); //Appends variable to file, creating
the file if needed
writefile("c:\temp\myfile.txt", myothervar);
Which would result in (assuming values 1 and 2):
myvar=1
myothervar=2
This, of course, would be easy to handle in further processing stages.
Of course, some command to delete a file would also be needed.
Basically, OpenSCAD is great when it works alone, but when you have to put
it in a larger process, some means of connecting things together is needed.
View this message in context: http://forum.openscad.org/Writing-to-files-tp21005.html
I just use echo and then post process the output with python.
do
do
for
export
creating
the file if needed
myvar=1
myothervar=2
Is there a way to redirect the echo output to a file, or do I have to do the
copy-paste dance?
View this message in context: http://forum.openscad.org/Writing-to-files-tp21005p21045.html
If you are using the GUI, the later.
You could try the command line
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment
View this message in context: http://forum.openscad.org/Writing-to-files-tp21005p21046.html
