yesterdays release problem
Wed, Dec 4, 2024 8:42 PM
My fav file format that I feed prusaslicer and its descendants is 3mf.
But the just loaded yesterdays release has replace the 3mf button in the
top row of button with dxf, which dies not appear to work.
3mf is available in the prefs editor, but is apparently only usable with
octoprint and all my printers run klipper for obvius reasons. And theone
option discussed recently has completely dissapeared from the prefs menu's.
How do I restore all that?  Thanks.
Cheers, Gene Heskett, CET.
  • Louis D. Brandeis
My fav file format that I feed prusaslicer and its descendants is 3mf. But the just loaded yesterdays release has replace the 3mf button in the top row of button with dxf, which dies not appear to work. 3mf is available in the prefs editor, but is apparently only usable with octoprint and all my printers run klipper for obvius reasons. And theone option discussed recently has completely dissapeared from the prefs menu's. How do I restore all that? Thanks. Cheers, Gene Heskett, CET. -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author, 1940) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis
TA
Todd Allen
Wed, Dec 4, 2024 9:02 PM
After going through the menu Edit/Preferences/Advanced and selecting "3MF"
for <Toolbar Export 3D> my toolbar 3MF button came back.
On Wed, Dec 4, 2024 at 2:42 PM gene heskett via Discuss <
  • Louis D. Brandeis
After going through the menu Edit/Preferences/Advanced and selecting "3MF" for <Toolbar Export 3D> my toolbar 3MF button came back. On Wed, Dec 4, 2024 at 2:42 PM gene heskett via Discuss < discuss@lists.openscad.org> wrote: > My fav file format that I feed prusaslicer and its descendants is 3mf. > But the just loaded yesterdays release has replace the 3mf button in the > top row of button with dxf, which dies not appear to work. > > 3mf is available in the prefs editor, but is apparently only usable with > octoprint and all my printers run klipper for obvius reasons. And theone > option discussed recently has completely dissapeared from the prefs menu's. > > How do I restore all that? Thanks. > > Cheers, Gene Heskett, CET. > -- > "There are four boxes to be used in defense of liberty: > soap, ballot, jury, and ammo. Please use in that order." > -Ed Howdershelt (Author, 1940) > If we desire respect for the law, we must first make the law respectable. > - Louis D. Brandeis > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Wed, Dec 4, 2024 9:18 PM
For clarification: We have separate toolbar buttons for 2D and 3D export, and we recently cleaned up some of the UI controls for those, which may mean that you need to re-select the format in Edit/Preferences/Advanced, or delete your config.
This will happen occasionally when using nightly builds, but once we release a stable version, the preferences will be more stable.
On Dec 4, 2024, at 16:02, Todd Allen via Discuss discuss@lists.openscad.org wrote:
On Wed, Dec 4, 2024 at 2:42 PM gene heskett via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
  • Louis D. Brandeis
For clarification: We have separate toolbar buttons for 2D and 3D export, and we recently cleaned up some of the UI controls for those, which may mean that you need to re-select the format in Edit/Preferences/Advanced, or delete your config. This will happen occasionally when using nightly builds, but once we release a stable version, the preferences will be more stable. -Marius > On Dec 4, 2024, at 16:02, Todd Allen via Discuss <discuss@lists.openscad.org> wrote: > > After going through the menu Edit/Preferences/Advanced and selecting "3MF" for <Toolbar Export 3D> my toolbar 3MF button came back. > > On Wed, Dec 4, 2024 at 2:42 PM gene heskett via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: >> My fav file format that I feed prusaslicer and its descendants is 3mf. >> But the just loaded yesterdays release has replace the 3mf button in the >> top row of button with dxf, which dies not appear to work. >> >> 3mf is available in the prefs editor, but is apparently only usable with >> octoprint and all my printers run klipper for obvius reasons. And theone >> option discussed recently has completely dissapeared from the prefs menu's. >> >> How do I restore all that? Thanks. >> >> Cheers, Gene Heskett, CET. >> -- >> "There are four boxes to be used in defense of liberty: >> soap, ballot, jury, and ammo. Please use in that order." >> -Ed Howdershelt (Author, 1940) >> If we desire respect for the law, we must first make the law respectable. >> - Louis D. Brandeis >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Wed, Dec 4, 2024 9:32 PM
Worked here too, thank you.
 with
 theone
 menu's.
 respectable.
    - Louis D. Brandeis
  • Louis D. Brandeis
On 12/4/24 16:02, Todd Allen wrote: > After going through the menu Edit/Preferences/Advanced and selecting > "3MF" for <Toolbar Export 3D> my toolbar 3MF button came back. > Worked here too, thank you. > On Wed, Dec 4, 2024 at 2:42 PM gene heskett via Discuss > <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: > > My fav file format that I feed prusaslicer and its descendants is 3mf. > But the just loaded yesterdays release has replace the 3mf button in > the > top row of button with dxf, which dies not appear to work. > > 3mf is available in the prefs editor, but is apparently only usable > with > octoprint and all my printers run klipper for obvius reasons. And > theone > option discussed recently has completely dissapeared from the prefs > menu's. > > How do I restore all that?  Thanks. > > Cheers, Gene Heskett, CET. > -- > "There are four boxes to be used in defense of liberty: >   soap, ballot, jury, and ammo. Please use in that order." > -Ed Howdershelt (Author, 1940) > If we desire respect for the law, we must first make the law > respectable. >   - Louis D. Brandeis > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > <mailto:discuss-leave@lists.openscad.org> > Cheers, Gene Heskett, CET. -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author, 1940) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis
Wed, Dec 4, 2024 9:34 PM
 3mf.
 in the
 usable with
 theone
 prefs menu's.
 respectable.
   - Louis D. Brandeis
  • Louis D. Brandeis
On 12/4/24 16:18, Marius Kintel wrote: > For clarification: We have separate toolbar buttons for 2D and 3D > export, and we recently cleaned up some of the UI controls for those, > which may mean that you need to re-select the format in Edit/ > Preferences/Advanced, or delete your config. > > This will happen occasionally when using nightly builds, but once we > release a stable version, the preferences will be more stable. > >  -Marius > >> On Dec 4, 2024, at 16:02, Todd Allen via Discuss >> <discuss@lists.openscad.org> wrote: >> >> After going through the menu Edit/Preferences/Advanced and selecting >> "3MF" for <Toolbar Export 3D> my toolbar 3MF button came back. >> >> On Wed, Dec 4, 2024 at 2:42 PM gene heskett via Discuss >> <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: >> >> My fav file format that I feed prusaslicer and its descendants is >> 3mf. >> But the just loaded yesterdays release has replace the 3mf button >> in the >> top row of button with dxf, which dies not appear to work. >> >> 3mf is available in the prefs editor, but is apparently only >> usable with >> octoprint and all my printers run klipper for obvius reasons. And >> theone >> option discussed recently has completely dissapeared from the >> prefs menu's. >> >> How do I restore all that?  Thanks. >> >> Cheers, Gene Heskett, CET. >> -- >> "There are four boxes to be used in defense of liberty: >>   soap, ballot, jury, and ammo. Please use in that order." >> -Ed Howdershelt (Author, 1940) >> If we desire respect for the law, we must first make the law >> respectable. >>   - Louis D. Brandeis >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> <mailto:discuss-leave@lists.openscad.org> >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > Cheers, Gene Heskett, CET. -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author, 1940) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis
