On Sun, 2025-06-08 at 16:56 -0400, Adrian Mariano via Discuss wrote:
Larry, is it possible that your code is not finding the updated
version? That's the only explanation I can come up with.
Upon further investigation, I did find that I was not executing the one
I downloaded on June 1. I had placed it in
/.local/share/OpenSCAD/
So I deleted the BOSL2 that was in /.local/share/OpenSCAD/libraries,
and moved the new one (Jun 1) as shown:
:~/.local/share/OpenSCAD/libraries$ ls -l BOSL2
total 3976
-rw-rw-r-- 1 larry larry 18723 Jun 1 13:03 affine.scad
-rw-rw-r-- 1 larry larry 255745 Jun 1 13:03 attachments.scad
I then ran OpenSCAD and ran the same script, but I still get 'inside'
and 'extra' not specified as parameter.
Could it be cached? Do I have to reboot?
On Sat, 2025-06-07 at 21:42 +1000, Ken via Discuss wrote:
Problem solved Adrian- my Bosl2 was out-of-date. Downloaded the
latest from github, extra now works as advertised- thanks🙂
I had the same problem, except that 'inside' gave the same error. I
downloaded the latest version from github, using 'Download ZIP',
but I
still get the error, and thr flared hole appears on top of the
cube.
On 2025-06-07 08:09, Adrian Mariano via Discuss wrote:
Your question is not clearly posed. Do you mean this?
include<BOSL2/std.scad>
size = 20;
$fa=1;$fs=.3;
diff()
cuboid(size)
attach(TOP,TOP,inside=true)
cyl(h=size,d=4,rounding=-2,extra=1); // extra adds
length to
avoid z-fighting
On Fri, Jun 6, 2025 at 4:33 PM Joe Weinpert via Discuss
I want to create a block with a hole in it where the top and
bottom of the hole have a radius.
total 3976
> On Sat, Jun 7, 2025 at 1:41 PM larry via Discuss
> > but I
> > cube.
> > > > size = 20;
> > > > $fa=1;$fs=.3;
> > > > diff()
> > > > cuboid(size)
> > > > length to
> > > > avoid z-fighting
> > > > > _______________________________________________
> > > > > OpenSCAD mailing list
> > > > > To unsubscribe send an email to
> > > > > discuss-leave@lists.openscad.org
> > > To unsubscribe send an email to discuss-leave@lists.openscad.org
