I've carried out some speed tests to compare the performance of list
comprehension and recursion. The preliminary result shows that list comp. is
much much faster than recursion. The difference is huge especially at large
data set. In some cases recursion hangs the computer but list comp can
finish in 1~2 sec.
But there are cases that recursion is needed. A simple sum( list ) function
will require recursion, because we can't carry the result of
list[i]+list[i+1] to the next iteration.
So I have an idea: how about an internal variable to represent the result of
the previous iteration ?
Let's say, @ = result of the previous iteration
function sum( list ) = [ for( i=[0:len(list)-1] ) i==0?list[i]:(@+list[i]) ]
[ len(list)-1] ;
sum( [2,3,4] ) = [ 2,5,9][2] = 9;
$ Runsun Pan, PhD
$ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse )
View this message in context: http://forum.openscad.org/Idea-local-var-inside-list-comprehension-tp12446.html
Better to optimise tail recursion to be iteration than make the language
more complicated and ugly. I thought that had already been done though?
is
large
finish in 1~2 sec.
of
[ len(list)-1] ;
$ Runsun Pan, PhD
language more complicated and ugly. I thought that had already
been done though?
Simple tail recursion elimination is supported (functions only,
not for modules):
function rec_add(i = 0) = i <= 0 ? 0 : i + rec_add(i - 1);
echo(rec_add(10000));
=> ERROR: Recursion detected calling function 'rec_add'
function tail_rec_add(i = 0, result = 0) = i <= 0 ? result : tail_rec_add(i - 1, result + i);
echo(tail_rec_add(10000));
=> ECHO: 5.0005e+07
Note that there is currently still a limit for the iteration
count, but it's much higher than the limit caused by stack
size for the recursive call.
You are right !!! Tail recursion is very fast, indeed. I adjusted my code and
it's much faster. It's still 3x slower than the list comprehension at very
large data set, but is very impressive already. Good enough. Thx, man.
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Idea-local-var-inside-list-comprehension-tp12446p12449.html
@Torsten, your examples demonstrate tail recursion nicely. Thx a lot. I gotta
review all my codes :) :)
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Idea-local-var-inside-list-comprehension-tp12446p12450.html
