OpenSCAD compatible computational fluid dynamics software?
RS
Rob Sherwood
Mon, Jun 17, 2019 5:41 PM
Hi All,
I'm trying to export a design from OpenSCAD (e.g., via .stl file format)
and analyze it using some CFD software (ideally open source/free) to infer
properties about the design, e.g., drag, lift, etc.
While this is not 100% an openscad question, I'm hoping someone from the
openscad community has had the same requirements and might have a ready
solution that they're willing to share.
Fwiw, I've found OpenFOAM (openfoam.org) which seems to be the right thing
but has some many options and seems to be "everything to everyone" that
I've lost the last week trying to figure out (without success) how to
calculate drag and lift on my model.  Absent a better option, I will keep
trying with OpenFOAM but I'm hoping that someone in the community has some
wisdom they're willing to share.
Thank you in advance!
  • Rob
Hi All, I'm trying to export a design from OpenSCAD (e.g., via .stl file format) and analyze it using some CFD software (ideally open source/free) to infer properties about the design, e.g., drag, lift, etc. While this is not 100% an openscad question, I'm hoping someone from the openscad community has had the same requirements and might have a ready solution that they're willing to share. Fwiw, I've found OpenFOAM (openfoam.org) which seems to be the right thing but has some many options and seems to be "everything to everyone" that I've lost the last week trying to figure out (without success) how to calculate drag and lift on my model. Absent a better option, I will keep trying with OpenFOAM but I'm hoping that someone in the community has some wisdom they're willing to share. Thank you in advance! - Rob .
AC
A. Craig West
Mon, Jun 17, 2019 5:53 PM
I've been using simscale for similar purposes. Not open source, but free to
use, and it's pretty cool
On Mon, 17 Jun 2019, 13:42 Rob Sherwood, rob.sherwood@gmail.com wrote:
Hi All,
  • Rob
I've been using simscale for similar purposes. Not open source, but free to use, and it's pretty cool On Mon, 17 Jun 2019, 13:42 Rob Sherwood, <rob.sherwood@gmail.com> wrote: > Hi All, > > I'm trying to export a design from OpenSCAD (e.g., via .stl file format) > and analyze it using some CFD software (ideally open source/free) to infer > properties about the design, e.g., drag, lift, etc. > > While this is not 100% an openscad question, I'm hoping someone from the > openscad community has had the same requirements and might have a ready > solution that they're willing to share. > > Fwiw, I've found OpenFOAM (openfoam.org) which seems to be the right > thing but has some many options and seems to be "everything to everyone" > that I've lost the last week trying to figure out (without success) how to > calculate drag and lift on my model. Absent a better option, I will keep > trying with OpenFOAM but I'm hoping that someone in the community has some > wisdom they're willing to share. > > Thank you in advance! > > - Rob > . > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
RS
Rob Sherwood
Wed, Jun 19, 2019 6:09 PM
Thanks for the reply - I’ll check it out!  If anyone else has any
suggestions I’d be happy to check those out as well.
  • Rob
Hi All,
  • Rob
Thanks for the reply - I’ll check it out! If anyone else has any suggestions I’d be happy to check those out as well. - Rob . On Mon, Jun 17, 2019 at 8:53 PM A. Craig West <acraigwest@gmail.com> wrote: > I've been using simscale for similar purposes. Not open source, but free > to use, and it's pretty cool > > On Mon, 17 Jun 2019, 13:42 Rob Sherwood, <rob.sherwood@gmail.com> wrote: > >> Hi All, >> >> I'm trying to export a design from OpenSCAD (e.g., via .stl file format) >> and analyze it using some CFD software (ideally open source/free) to infer >> properties about the design, e.g., drag, lift, etc. >> >> While this is not 100% an openscad question, I'm hoping someone from the >> openscad community has had the same requirements and might have a ready >> solution that they're willing to share. >> >> Fwiw, I've found OpenFOAM (openfoam.org) which seems to be the right >> thing but has some many options and seems to be "everything to everyone" >> that I've lost the last week trying to figure out (without success) how to >> calculate drag and lift on my model. Absent a better option, I will keep >> trying with OpenFOAM but I'm hoping that someone in the community has some >> wisdom they're willing to share. >> >> Thank you in advance! >> >> - Rob >> . >> > _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
