threads.scad errors
Y
yvette
Sat, Jan 24, 2015 1:22 AM
hi,
trying to generate a large (25mm) screw, 9mm long, with a decent (between
the U.S. "national coarse" and "national fine") thread count.
if i use:
metric_thread(diameter=25, pitch=26, length=strsScrewLength, internal=false,
n_starts=1);
it fails (see below);
if i use:
metric_thread(25, 16, strsScrewLength);
it works.
if anyone has any advice, i'm all ears.
thanks
twistOneUp
the scad and the output of failing F6:
THE SCAD:
use <threads.scad>;
include <foo.scad>;
genTest = true;
strhFn=(genTest) ? 30 : 30;
//strhKeeperHoleOffsetFromCentah  =
(strhDiametah/2)-strhKeeperHoleFromEdge;
cylinder(r=strhSpacerRadius, h=strhSpacerWidth, $fn=strhFn, center=true);
translate([0, 0, (strhSpacerWidth/2)])//strhSpacerWidth])
cylinder(r=strhGripRadius, h=strhGripWidth, $fn=strhFn);
// iterate da grips
for (i = [0 : (strhGripHoleQuantity-1)]) {
translate([(strhGripRadiussin(i(360/strhGripHoleQuantity))),
(strhGripRadiuscos(i(360/strhGripHoleQuantity))), (strhSpacerWidth/2)])
cylinder(r=(strhGripHoleDiametah/2), h=strhSpacerWidth, $fn=strhFn);
// smooth the "gear teeth"
translate([((strhGripRadiussin(i(360/strhGripHoleQuantity)+((360/strhGripHoleQuantity/2))))),
((strhGripRadiuscos(i(360/strhGripHoleQuantity)+((360/strhGripHoleQuantity/2))))),
cylinder(r=(strhGripHoleDiametah/4), h=strhGripWidth, $fn=strhFn);
// add in shaft (splined)
rotate([-180, 0, 0])
cylinder(r=12.7, h=50, $fn=strhFn);
for (i=[0:(strhGripHoleQuantity-1)]) {
if ( (i==0) || (i==3) || (i==6) || (i==9) ) {
translate([-1.25, -1.25, -5])
translate([12.7sin(i(360/strhGripHoleQuantity)),
12.7cos(i(360/strhGripHoleQuantity)), (strhSpacerWidth/2)])
cube([2.5, 2.5, 50]);
// add in da screw
translate([0, 0, -59])
// metric_thread(25, 16, strsScrewLength); // takes forEVAH!
internal=false, n_starts=1);
foo.scad:
strStrappingWidth            =  25.4;
strDiametah                  =    4*25.4;
strThickness                  =    4;
strCenterHoleDiametah        =  25;
strPinHoleQuantity            =  12;
strPinHoleDiametah            =  10;
strPinpHoleFromEdge          =    4;
strhGripHoleQuantity          =  12;
strhSpacerRadius              =  17.5;
strhSpacerWidth              =  10;
strhGripRadius                =  25;
strhGripWidth                =    5;
strhGripHoleDiametah          =  10;
strcsRadius                  =  16;
strcsSpacerInsetIntoReel      =    2;
strcsAddlWidthAroundStrap    =    1;
strpPinGripRadius            =    6;
strpPinGripLength            =  12;
strpPinCollarRadius          =    8;
strpPinCollarThickness        =    2;
strpPinProngRadius            =    6;
strpPinProngLength            =  12;
strsScrewLength              =    9;
THE OUTPUT:
CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion
violation!
Expr: itl != it->second.end()
File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
violation!
Line: 1102
CGAL error in CGAL_Nef_polyhedron's intersection operator: CGAL ERROR:
assertion violation!
Line: 1102
PolySets in cache: 0
PolySet cache size in bytes: 0
CGAL Polyhedrons in cache: 1167
CGAL cache size in bytes: 104848440
Simple:        yes
Vertices:    1018
Halfedges:    3054
Edges:        1527
Halffacets:  1026
Facets:        513
Volumes:        2
Total rendering time: 0 hours, 0 minutes, 6 seconds
Rendering finished.
View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201.html
hi, trying to generate a large (25mm) screw, 9mm long, with a decent (between the U.S. "national coarse" and "national fine") thread count. if i use: metric_thread(diameter=25, pitch=26, length=strsScrewLength, internal=false, n_starts=1); it fails (see below); if i use: metric_thread(25, 16, strsScrewLength); it works. if anyone has any advice, i'm all ears. thanks twistOneUp the scad and the output of failing F6: THE SCAD: --------- use <threads.scad>; include <foo.scad>; genTest = true; strhFn=(genTest) ? 30 : 30; //strhKeeperHoleOffsetFromCentah = (strhDiametah/2)-strhKeeperHoleFromEdge; union() { difference() { union() { cylinder(r=strhSpacerRadius, h=strhSpacerWidth, $fn=strhFn, center=true); translate([0, 0, (strhSpacerWidth/2)])//strhSpacerWidth]) cylinder(r=strhGripRadius, h=strhGripWidth, $fn=strhFn); } // iterate da grips for (i = [0 : (strhGripHoleQuantity-1)]) { translate([(strhGripRadius*sin(i*(360/strhGripHoleQuantity))), (strhGripRadius*cos(i*(360/strhGripHoleQuantity))), (strhSpacerWidth/2)]) cylinder(r=(strhGripHoleDiametah/2), h=strhSpacerWidth, $fn=strhFn); } } // smooth the "gear teeth" for (i = [0 : (strhGripHoleQuantity-1)]) { translate([((strhGripRadius*sin(i*(360/strhGripHoleQuantity)+((360/strhGripHoleQuantity/2))))), ((strhGripRadius*cos(i*(360/strhGripHoleQuantity)+((360/strhGripHoleQuantity/2))))), (strhSpacerWidth/2)]) cylinder(r=(strhGripHoleDiametah/4), h=strhGripWidth, $fn=strhFn); } // add in shaft (splined) rotate([-180, 0, 0]) cylinder(r=12.7, h=50, $fn=strhFn); for (i=[0:(strhGripHoleQuantity-1)]) { rotate([-180, 0, 0]) if ( (i==0) || (i==3) || (i==6) || (i==9) ) { translate([-1.25, -1.25, -5]) translate([12.7*sin(i*(360/strhGripHoleQuantity)), 12.7*cos(i*(360/strhGripHoleQuantity)), (strhSpacerWidth/2)]) cube([2.5, 2.5, 50]); } } // add in da screw translate([0, 0, -59]) // metric_thread(25, 16, strsScrewLength); // takes forEVAH! metric_thread(diameter=25, pitch=26, length=strsScrewLength, internal=false, n_starts=1); } foo.scad: strStrappingWidth = 25.4; strDiametah = 4*25.4; strThickness = 4; strCenterHoleDiametah = 25; strPinHoleQuantity = 12; strPinHoleDiametah = 10; strPinpHoleFromEdge = 4; strhGripHoleQuantity = 12; strhSpacerRadius = 17.5; strhSpacerWidth = 10; strhGripRadius = 25; strhGripWidth = 5; strhGripHoleDiametah = 10; strcsRadius = 16; strcsSpacerInsetIntoReel = 2; strcsAddlWidthAroundStrap = 1; strpPinGripRadius = 6; strpPinGripLength = 12; strpPinCollarRadius = 8; strpPinCollarThickness = 2; strpPinProngRadius = 6; strpPinProngLength = 12; strsScrewLength = 9; THE OUTPUT: ----------- Compiling design (CSG Tree generation)... Rendering Polygon Mesh using CGAL... CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's union operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 CGAL error in CGAL_Nef_polyhedron's intersection operator: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: ../openscad_deps/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 PolySets in cache: 0 PolySet cache size in bytes: 0 CGAL Polyhedrons in cache: 1167 CGAL cache size in bytes: 104848440 Top level object is a 3D object: Simple: yes Vertices: 1018 Halfedges: 3054 Edges: 1527 Halffacets: 1026 Facets: 513 Volumes: 2 Total rendering time: 0 hours, 0 minutes, 6 seconds Rendering finished. -- View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Jan 24, 2015 2:26 AM
where is threads.scad?
View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11202.html
where is threads.scad? ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11202.html Sent from the OpenSCAD mailing list archive at Nabble.com.
BP
Brad Pitcher
Sat, Jan 24, 2015 3:09 AM
Probably http://dkprojects.net/openscad-threads/?
On Fri Jan 23 2015 at 6:26:57 PM MichaelAtOz oz.at.michael@gmail.com
Probably http://dkprojects.net/openscad-threads/? On Fri Jan 23 2015 at 6:26:57 PM MichaelAtOz <oz.at.michael@gmail.com> wrote: > where is threads.scad? > > > > ----- > Unless specifically shown otherwise above, my contribution is in the > Public Domain; To the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. This work is > published globally via the internet. :) Inclusion of works of previous > authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ > -- > View this message in context: http://forum.openscad.org/ > threads-scad-errors-tp11201p11202.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sat, Jan 24, 2015 3:33 AM
With the latest snapshot, I get a different, single error.
ERROR: CGAL error in CGALUtils::applyBinaryOperator union: CGAL ERROR:
/data/OpenSCAD/libraries-mingw64-master/mxe-w64/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1102
What OpenSCAD version are you using?
View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11204.html
With the latest snapshot, I get a different, single error. ERROR: CGAL error in CGALUtils::applyBinaryOperator union: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: /data/OpenSCAD/libraries-mingw64-master/mxe-w64/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102 What OpenSCAD version are you using? ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11204.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Jan 24, 2015 3:37 AM
I get the OP's errors with 2014.03. And with just the metric_thread(25,26,9)
call, no other geometry.
View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11205.html
I get the OP's errors with 2014.03. And with just the metric_thread(25,26,9) call, no other geometry. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11205.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Jan 24, 2015 3:45 AM
OK, the library, where the pitch >= diameter, gets n_turns=0, probably not
healthy.
It may take a while to understand what's happening.
Perhaps, diameter=25, pitch=24 will do???
View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11206.html
OK, the library, where the pitch >= diameter, gets n_turns=0, probably not healthy. It may take a while to understand what's happening. Perhaps, diameter=25, pitch=24 will do??? ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11206.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Jan 24, 2015 3:52 AM
Scratch that.
View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11207.html
Scratch that. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11207.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Jan 24, 2015 4:12 AM
That's above my pay grade.
I've dropped Dan the author a note in case he can see something...
View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11208.html
That's above my pay grade. I've dropped Dan the author a note in case he can see something... ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11208.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Jan 25, 2015 2:04 AM
Ping, because the above post didn't make it to the mailing list.
View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11215.html
Ping, because the above post didn't make it to the mailing list. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/threads-scad-errors-tp11201p11215.html Sent from the OpenSCAD mailing list archive at Nabble.com.
