Is this good enough? You can play with the sizes, and extrude the parts
separately if you want, make a prettier infill..
hole1 =10; //diameter of small hole
hole2 = 15;// diameter of large hole
wall=3;// thickness of wall
height =50; //height of piece
// position holes
module holes(){
circle (d=hole1);
translate ([(hole1+hole2)/2,0])circle (d=hole2);
// get solids
module skin(){
circle (d=hole1 + wall+wall);
translate([(hole1+hole2)/2,0])circle (d=hole2+wall+wall);
//add in filler
filler();
mirror([0,1,0])filler();
// make wedged shaped filler
module filler(){
polygon(points=[[0,0],[(hole1+hole2)/2,0],[(hole1+hole2)/2,hole2/2+wall],[0,hole1/2+wall]]);
$fn =80;
linear_extrude(height)
difference (){
skin();
holes();
On 19/04/2021 23:49, Chris Johnson via Discuss wrote:
