perhaps a bit off topic: automatic generation of line drawing from photo
Thu, Aug 27, 2026 11:31 AM
There are tutorials about how to take a photo and convert it into a line
drawing using ImageMagik and there are also some online tools to do
similar.  They take one bitmap and turn it into another bitmap.  Does
anyone know of a way to take a bitmap (photo) and turn it into a series
of line segments in SVG (or similar) format outlining the boundaries of
similar gray scale or color?
There are tutorials about how to take a photo and convert it into a line drawing using ImageMagik and there are also some online tools to do similar.  They take one bitmap and turn it into another bitmap.  Does anyone know of a way to take a bitmap (photo) and turn it into a series of line segments in SVG (or similar) format outlining the boundaries of similar gray scale or color? -- This email has been checked for viruses by AVG antivirus software. www.avg.com
Thu, Aug 27, 2026 4:07 PM
Some drawing tools have a “trace” feature that can do this.  I’m pretty sure that CorelDraw does.  (But alas $$$.). Don’t know about Inkscape.
But I have found that I was not very satisfied with the results.  They tend to produce wiggly lines that more or less match the image, but don’t match the intent of having a smooth curve.  I usually use Inkscape to manually trace the image using Bézier curves. I then either import the resulting SVG into OpenSCAD, or transcribe the coordinates to into the OpenSCAD program, into calls to Bézier functions.
> There are tutorials about how to take a photo and convert it into a line drawing using ImageMagik and there are also some online tools to do similar. They take one bitmap and turn it into another bitmap. Does anyone know of a way to take a bitmap (photo) and turn it into a series of line segments in SVG (or similar) format outlining the boundaries of similar gray scale or color? Some drawing tools have a “trace” feature that can do this. I’m pretty sure that CorelDraw does. (But alas $$$.). Don’t know about Inkscape. But I have found that I was not very satisfied with the results. They tend to produce wiggly lines that more or less match the image, but don’t match the **intent** of having a smooth curve. I usually use Inkscape to manually trace the image using Bézier curves. I then either import the resulting SVG into OpenSCAD, or transcribe the coordinates to into the OpenSCAD program, into calls to Bézier functions.
JJ
jon jonbondy.com
Thu, Aug 27, 2026 4:41 PM
Jordan:
Thanks.  InkScape has a Path, Trace Bitmap feature that works, but not
as well as the ImageMagik approach.  The InkScape approach may result in
SVGs, while the IM approach just creates a new image.
I just tried combining IM as a pre-processor for IS, and that works very
well, creating a reasonable SVG file!
FYI, the IM command line is as follows, where "Seven.jpg" is the
original image.
Jordan: Thanks.  InkScape has a Path, Trace Bitmap feature that works, but not as well as the ImageMagik approach.  The InkScape approach may result in SVGs, while the IM approach just creates a new image. I just tried combining IM as a pre-processor for IS, and that works very well, creating a reasonable SVG file! FYI, the IM command line is as follows, where "Seven.jpg" is the original image. magick Seven.jpg -canny 0x1+05%+15%  Seven_lines.png Jon On 8/27/2026 12:07 PM, Jordan Brown wrote: > >> There are tutorials about how to take a photo and convert it into a line drawing using ImageMagik and there are also some online tools to do similar. They take one bitmap and turn it into another bitmap. Does anyone know of a way to take a bitmap (photo) and turn it into a series of line segments in SVG (or similar) format outlining the boundaries of similar gray scale or color? > Some drawing tools have a “trace” feature that can do this. I’m pretty sure that CorelDraw does. (But alas $$$.). Don’t know about Inkscape. > > But I have found that I was not very satisfied with the results. They tend to produce wiggly lines that more or less match the image, but don’t match the **intent** of having a smooth curve. I usually use Inkscape to manually trace the image using Bézier curves. I then either import the resulting SVG into OpenSCAD, or transcribe the coordinates to into the OpenSCAD program, into calls to Bézier functions.
GB
Glenn Butcher
Thu, Aug 27, 2026 4:49 PM
I did this to make stone walls, drew a black-n-white image of the wall
profile and wrote software to use OpenCV to extract the contours of the
stones to make meshes and then decorate them with noise-derived
textures. Not exactly plug-n-play, but OpenCV allows you to simplify the
discovered contours with another routine, adjustable regarding degree of
simplification.  Oh, and no .svg output without writing a routine to do
that.
Extracting shapes from photographs is challenging, algorithms aren't
smart enough to handle all the color/contrast situations that clutter
photos.  I've tried using the AI image manipulation tools with limited
success; I did manage to coax Nano Banana to render a black-n-white of a
stone wall in a vintage photo, took a few choice words to get it off
converting to bricks and such.  It did things I didn't ask for, like
replace people's faces with faces from other photos (one kid had a
beard, thank you...), so didn't know if I could trust its mortar lines,
but with enough constraining words I think such an approach can work.
Glenn
I did this to make stone walls, drew a black-n-white image of the wall profile and wrote software to use OpenCV to extract the contours of the stones to make meshes and then decorate them with noise-derived textures. Not exactly plug-n-play, but OpenCV allows you to simplify the discovered contours with another routine, adjustable regarding degree of simplification.  Oh, and no .svg output without writing a routine to do that. Extracting shapes from photographs is challenging, algorithms aren't smart enough to handle all the color/contrast situations that clutter photos.  I've tried using the AI image manipulation tools with limited success; I did manage to coax Nano Banana to render a black-n-white of a stone wall in a vintage photo, took a few choice words to get it off converting to bricks and such.  It did things I didn't ask for, like replace people's faces with faces from other photos (one kid had a beard, thank you...), so didn't know if I could trust its mortar lines, but with enough constraining words I think such an approach can work. Glenn On 8/27/2026 5:31 AM, Jon Bondy via Discuss wrote: > There are tutorials about how to take a photo and convert it into a > line drawing using ImageMagik and there are also some online tools to > do similar.  They take one bitmap and turn it into another bitmap.  > Does anyone know of a way to take a bitmap (photo) and turn it into a > series of line segments in SVG (or similar) format outlining the > boundaries of similar gray scale or color? > >
Thu, Aug 27, 2026 5:24 PM
line
series
of
makerlab.com has some image to keychain or bust or statue or ??
I don't use it myself, but a lot of folks have reasonable results from
it.
Larry
On Thu, 2026-08-27 at 07:31 -0400, Jon Bondy via Discuss wrote: > There are tutorials about how to take a photo and convert it into a > line > drawing using ImageMagik and there are also some online tools to do > similar.  They take one bitmap and turn it into another bitmap.  Does > anyone know of a way to take a bitmap (photo) and turn it into a > series > of line segments in SVG (or similar) format outlining the boundaries > of > similar gray scale or color? makerlab.com has some image to keychain or bust or statue or ?? I don't use it myself, but a lot of folks have reasonable results from it. Larry
WF
William F. Adams
Thu, Aug 27, 2026 6:34 PM
I've always found it best to just re-draw:
https://community.carbide3d.com/t/drawing-a-weber-gasket/104998
-- Sphinx of black quartz, judge my vow.https://designinto3d.com/
On Thursday, August 27, 2026 at 07:31:22 AM EDT, OpenSCAD general discussion Mailing-list discuss@lists.openscad.org wrote:
I've always found it best to just re-draw: https://community.carbide3d.com/t/drawing-a-weber-gasket/104998 William -- Sphinx of black quartz, judge my vow.https://designinto3d.com/ On Thursday, August 27, 2026 at 07:31:22 AM EDT, OpenSCAD general discussion Mailing-list <discuss@lists.openscad.org> wrote: There are tutorials about how to take a photo and convert it into a line drawing using ImageMagik and there are also some online tools to do similar.  They take one bitmap and turn it into another bitmap.  Does anyone know of a way to take a bitmap (photo) and turn it into a series of line segments in SVG (or similar) format outlining the boundaries of similar gray scale or color? -- This email has been checked for viruses by AVG antivirus software. www.avg.com _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org
TA
Todd Allen
Thu, Aug 27, 2026 6:41 PM
GIMP is a free photoshop type app with many tools one can use to "simplify"
a photo.
On Thu, Aug 27, 2026, 1:34 PM William F. Adams via Discuss <
GIMP is a free photoshop type app with many tools one can use to "simplify" a photo. On Thu, Aug 27, 2026, 1:34 PM William F. Adams via Discuss < discuss@lists.openscad.org> wrote: > I've always found it best to just re-draw: > > https://community.carbide3d.com/t/drawing-a-weber-gasket/104998 > > William > > -- > Sphinx of black quartz, judge my vow. > https://designinto3d.com/ > > > On Thursday, August 27, 2026 at 07:31:22 AM EDT, OpenSCAD general > discussion Mailing-list <discuss@lists.openscad.org> wrote: > > > There are tutorials about how to take a photo and convert it into a line > drawing using ImageMagik and there are also some online tools to do > similar. They take one bitmap and turn it into another bitmap. Does > anyone know of a way to take a bitmap (photo) and turn it into a series > of line segments in SVG (or similar) format outlining the boundaries of > similar gray scale or color? > > > -- > This email has been checked for viruses by AVG antivirus software. > www.avg.com > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
KE
Karl Exler
Thu, Aug 27, 2026 6:55 PM
I think there is a function in Inkjet, which does something...
Unfortunately I don´t know how this function is called by now.
Karl
Am 27.08.26 um 20:41 schrieb Todd Allen via Discuss:
"simplify" a photo.
     into a line
     to do
     bitmap.  Does
     a series
     boundaries of
     www.avg.com <http://www.avg.com>
I think there is a function in Inkjet, which does something... Unfortunately I don´t know how this function is called by now. Karl Am 27.08.26 um 20:41 schrieb Todd Allen via Discuss: > GIMP is a free photoshop type app with many tools one can use to > "simplify" a photo. > > On Thu, Aug 27, 2026, 1:34 PM William F. Adams via Discuss > <discuss@lists.openscad.org> wrote: > > I've always found it best to just re-draw: > > https://community.carbide3d.com/t/drawing-a-weber-gasket/104998 > > William > > -- > Sphinx of black quartz, judge my vow. > https://designinto3d.com/ > > > On Thursday, August 27, 2026 at 07:31:22 AM EDT, OpenSCAD general > discussion Mailing-list <discuss@lists.openscad.org> wrote: > > > There are tutorials about how to take a photo and convert it > into a line > drawing using ImageMagik and there are also some online tools > to do > similar.  They take one bitmap and turn it into another > bitmap.  Does > anyone know of a way to take a bitmap (photo) and turn it into > a series > of line segments in SVG (or similar) format outlining the > boundaries of > similar gray scale or color? > > > -- > This email has been checked for viruses by AVG antivirus software. > www.avg.com <http://www.avg.com> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
JJ
jon jonbondy.com
Thu, Aug 27, 2026 10:44 PM
William:
Thanks.  I may need to do a dozen or two of these things, and they may be quite complex.
https://community.carbide3d.com/t/drawing-a-weber-gasket/104998https://urldefense.proofpoint.com/v2/url?u=https-3A__community.carbide3d.com_t_drawing-2Da-2Dweber-2Dgasket_104998&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=Ah1_CbLGFTmg80XCyoPCqjM3t1KBsCgykRYAzkUz-jFJSweROsMDtK6d7qYCxORf&s=V_Z6UVLr0zeqAHyMpDGjr7r4CzMlDL8mGu09PlJoay4&e=
https://designinto3d.com/https://urldefense.proofpoint.com/v2/url?u=https-3A__designinto3d.com_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=Ah1_CbLGFTmg80XCyoPCqjM3t1KBsCgykRYAzkUz-jFJSweROsMDtK6d7qYCxORf&s=fU1V7GzA-rHruzCCK7IPReQrS6H0UnAu-8O5evm1LVI&e=
On Thursday, August 27, 2026 at 07:31:22 AM EDT, OpenSCAD general discussion Mailing-list discuss@lists.openscad.orgmailto:discuss@lists.openscad.org wrote:
www.avg.comhttp://www.avg.com
William: Thanks. I may need to do a dozen or two of these things, and they may be quite complex. Jon On 8/27/2026 2:34 PM, William F. Adams wrote: I've always found it best to just re-draw: https://community.carbide3d.com/t/drawing-a-weber-gasket/104998<https://urldefense.proofpoint.com/v2/url?u=https-3A__community.carbide3d.com_t_drawing-2Da-2Dweber-2Dgasket_104998&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=Ah1_CbLGFTmg80XCyoPCqjM3t1KBsCgykRYAzkUz-jFJSweROsMDtK6d7qYCxORf&s=V_Z6UVLr0zeqAHyMpDGjr7r4CzMlDL8mGu09PlJoay4&e=> William -- Sphinx of black quartz, judge my vow. https://designinto3d.com/<https://urldefense.proofpoint.com/v2/url?u=https-3A__designinto3d.com_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=Ah1_CbLGFTmg80XCyoPCqjM3t1KBsCgykRYAzkUz-jFJSweROsMDtK6d7qYCxORf&s=fU1V7GzA-rHruzCCK7IPReQrS6H0UnAu-8O5evm1LVI&e=> On Thursday, August 27, 2026 at 07:31:22 AM EDT, OpenSCAD general discussion Mailing-list <discuss@lists.openscad.org><mailto:discuss@lists.openscad.org> wrote: There are tutorials about how to take a photo and convert it into a line drawing using ImageMagik and there are also some online tools to do similar. They take one bitmap and turn it into another bitmap. Does anyone know of a way to take a bitmap (photo) and turn it into a series of line segments in SVG (or similar) format outlining the boundaries of similar gray scale or color? -- This email has been checked for viruses by AVG antivirus software. www.avg.com<http://www.avg.com> _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org<mailto:discuss-leave@lists.openscad.org>
Thu, Aug 27, 2026 10:47 PM
Todd:
Thanks.  ImageMagik does most of this with a command line interface
which allows for batch processing; it also is free.
"simplify" a photo.
 <https://urldefense.proofpoint.com/v2/url?u=https-3A__community.carbide3d.com_t_drawing-2Da-2Dweber-2Dgasket_104998&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=v74Zgd6D2TjRt5ES8CHWOa2YICrVP4XpuEKJGcslvkU0TswF8cNQkvZ9CuYK7yhf&s=sewdCNqqFYHvBYHrVOMYJpSYrWP-I4uP1kHr4NoloNk&e=>
 <https://urldefense.proofpoint.com/v2/url?u=https-3A__designinto3d.com_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=v74Zgd6D2TjRt5ES8CHWOa2YICrVP4XpuEKJGcslvkU0TswF8cNQkvZ9CuYK7yhf&s=2vI6lgdp76VcnWVcWbCTz2sHgrI26Gv1ajwUZ-1YIcQ&e=>
     into a line
     to do
     bitmap.  Does
     a series
     boundaries of
     <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.avg.com&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=v74Zgd6D2TjRt5ES8CHWOa2YICrVP4XpuEKJGcslvkU0TswF8cNQkvZ9CuYK7yhf&s=YAoQkdvzLXlTaQfuwd6dpSKrEQQqZF4ep-FAIDdAmUk&e=>
Todd: Thanks.  ImageMagik does most of this with a command line interface which allows for batch processing; it also is free. Jon On 8/27/2026 2:41 PM, Todd Allen via Discuss wrote: > GIMP is a free photoshop type app with many tools one can use to > "simplify" a photo. > > On Thu, Aug 27, 2026, 1:34 PM William F. Adams via Discuss > <discuss@lists.openscad.org> wrote: > > I've always found it best to just re-draw: > > https://community.carbide3d.com/t/drawing-a-weber-gasket/104998 > <https://urldefense.proofpoint.com/v2/url?u=https-3A__community.carbide3d.com_t_drawing-2Da-2Dweber-2Dgasket_104998&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=v74Zgd6D2TjRt5ES8CHWOa2YICrVP4XpuEKJGcslvkU0TswF8cNQkvZ9CuYK7yhf&s=sewdCNqqFYHvBYHrVOMYJpSYrWP-I4uP1kHr4NoloNk&e=> > > William > > -- > Sphinx of black quartz, judge my vow. > https://designinto3d.com/ > <https://urldefense.proofpoint.com/v2/url?u=https-3A__designinto3d.com_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=v74Zgd6D2TjRt5ES8CHWOa2YICrVP4XpuEKJGcslvkU0TswF8cNQkvZ9CuYK7yhf&s=2vI6lgdp76VcnWVcWbCTz2sHgrI26Gv1ajwUZ-1YIcQ&e=> > > > On Thursday, August 27, 2026 at 07:31:22 AM EDT, OpenSCAD general > discussion Mailing-list <discuss@lists.openscad.org> wrote: > > > There are tutorials about how to take a photo and convert it > into a line > drawing using ImageMagik and there are also some online tools > to do > similar.  They take one bitmap and turn it into another > bitmap.  Does > anyone know of a way to take a bitmap (photo) and turn it into > a series > of line segments in SVG (or similar) format outlining the > boundaries of > similar gray scale or color? > > > -- > This email has been checked for viruses by AVG antivirus software. > www.avg.com > <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.avg.com&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=v74Zgd6D2TjRt5ES8CHWOa2YICrVP4XpuEKJGcslvkU0TswF8cNQkvZ9CuYK7yhf&s=YAoQkdvzLXlTaQfuwd6dpSKrEQQqZF4ep-FAIDdAmUk&e=> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
