more SVG problems
K
ken@volksswitch.org
Sun, Oct 11, 2020 3:01 PM
Here's my simple code.  I.e., put a lion shape on a block:
filename="lion.svg";
fudge=0.05;
union(){
translate([0,0,.25-fudge])
resize([15,10,1])
linear_extrude(height=1)
import(file = filename,center=true);
           cube([20,15,.5],center=true);
This code previews perfectly but when rendered produces the error:
violation! Expr: e->incident_sface() != SFace_const_handle() File:
/mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_const_decora
tor.h Line: 329
Comment out the cube and it renders fine.
Thoughts?
Ken
Here's my simple code. I.e., put a lion shape on a block: filename="lion.svg"; fudge=0.05; union(){ translate([0,0,.25-fudge]) resize([15,10,1]) linear_extrude(height=1) import(file = filename,center=true); cube([20,15,.5],center=true); } This code previews perfectly but when rendered produces the error: ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation! Expr: e->incident_sface() != SFace_const_handle() File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_const_decora tor.h Line: 329 Comment out the cube and it renders fine. Thoughts? Ken
Sun, Oct 11, 2020 4:31 PM
Looks like the svg has self intersections in its outline. Try offsetting it
by a tiny amount. That passes it through clipper, which is good at sorting
out self-intersections.
fudge=0.05;
union(){
resize([15,10,1])
tor.h Line: 329
Thoughts?
Ken
Looks like the svg has self intersections in its outline. Try offsetting it by a tiny amount. That passes it through clipper, which is good at sorting out self-intersections. On Sun, 11 Oct 2020 at 16:02, <ken@volksswitch.org> wrote: > Here's my simple code. I.e., put a lion shape on a block: > > filename="lion.svg"; > fudge=0.05; > > union(){ > translate([0,0,.25-fudge]) > resize([15,10,1]) > linear_extrude(height=1) > import(file = filename,center=true); > > cube([20,15,.5],center=true); > } > > This code previews perfectly but when rendered produces the error: > ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion > violation! Expr: e->incident_sface() != SFace_const_handle() File: > > /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_const_decora > tor.h Line: 329 > > Comment out the cube and it renders fine. > > Thoughts? > Ken > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
K
ken@volksswitch.org
Tue, Oct 13, 2020 1:46 AM
That worked! Thanks.
Sent: Sunday, October 11, 2020 10:31 AM
Subject: Re: [OpenSCAD] more SVG problems
On Sun, 11 Oct 2020 at 16:02, <ken@volksswitch.org mailto:ken@volksswitch.org > wrote:
fudge=0.05;
union(){
resize([15,10,1])
tor.h Line: 329
Thoughts?
Ken
That worked! Thanks. From: nop head <nop.head@gmail.com> Sent: Sunday, October 11, 2020 10:31 AM To: OpenSCAD general discussion <discuss@lists.openscad.org> Subject: Re: [OpenSCAD] more SVG problems Looks like the svg has self intersections in its outline. Try offsetting it by a tiny amount. That passes it through clipper, which is good at sorting out self-intersections. On Sun, 11 Oct 2020 at 16:02, <ken@volksswitch.org <mailto:ken@volksswitch.org> > wrote: Here's my simple code. I.e., put a lion shape on a block: filename="lion.svg"; fudge=0.05; union(){ translate([0,0,.25-fudge]) resize([15,10,1]) linear_extrude(height=1) import(file = filename,center=true); cube([20,15,.5],center=true); } This code previews perfectly but when rendered produces the error: ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation! Expr: e->incident_sface() != SFace_const_handle() File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_const_decora tor.h Line: 329 Comment out the cube and it renders fine. Thoughts? Ken _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
