Hello,
This code is working fine (all variables are defined at some point but I
don't paste all the code):
step_start_points = [ for (a=[0:len(ext_avec_bordure)-1]) [ for (b = [ 0 : 1
points_interieur[a][b]
+ diff_points[a][b] * (asin(i/(extrude_steps) * 2 - 1) / 180. + 0.5)] ];
step_end_points = [ for (a=[0:len(ext_avec_bordure)-1]) [ for (b = [ 0 : 1
+ diff_points[a][b] * (asin((i+1)/(extrude_steps) * 2 - 1) / 180. + 0.5)]
However, if I modify it like this...
ext_type = 1;
if (ext_type == 1) {
0 : 1 ])
...I have two error messages:
WARNING: Ignoring unknown variable 'step_start_points', in file extrusion
profil dax + relief V13.scad, line 76.
WARNING: Ignoring unknown variable 'step_end_points', in file extrusion
What's wrong?
When you define a variable in a block it goes out of scope at the end of
the block. I.e. at the closing brace. Presumably something at line 76 tries
to use it.
On Mon, 6 Jul 2020 at 10:14, amundsen roald.baudoux@brutele.be wrote:
Hello,
1
0.5)] ];
ext_type = 1;
0 : 1 ])
0.5)] ];
What's wrong?
to use it.
Hello,
ext_type = 1;
Basically what you want is to assign a (different) value when ext_type
== 1.
Due to the reason nop-head explained above, what you're trying isn't
working.
You need to do:
step_end_points = ext_type == 1) ? /* something / : / ... somethingelse */ ;
