I have vague memories of seeing someone trying to add offset/delat to
linear extrude and now have an idea that could really make use of this.
Did it go anywhere? Is it available in a build?
Thanks
Ian
to linear extrude and now have an idea that could really make use
of this.
It's not in any automatic build right now, the source and discussion
is at https://github.com/openscad/openscad/pull/2079
Thanks. Is this now in mainline or on a branch?
I guess I need to start plugging away at building it from source.
Ian
It's in a forked repo. Github suggests the following commands
to get the code based on master which currently will create
a code conflict:
git checkout -b mrkmg-linear_extrude_offset master
git pull https://github.com/mrkmg/openscad.git linear_extrude_offset
As alternative, it would be possible to get that repo directly.
If you have an affine description of the 2D polygon, you can always use a
sweep() to emulate any linear_extrude operation. As far as I know current
sweep implementations don't support 2D polygons with holes. But in this case
you still can sweep the primitives and do all the Boolean stuff in 3D.
