here's an interesting one to speed-optimize...
Sun, Dec 6, 2015 9:44 PM
$fn=100 is a large round number, so it sounds like Jon may have done what a
lot of us do, which is just pick a random number that is obviously big
enough.
The advantage of Trygon's $fe technique is that it's easy to be more
precise than "pick a large random number". $fe=0.1 means render to a
precision of 100 microns, which is good enough for most 3D printing jobs. A
lot of consumer grade 3D printers don't support layer heights less than 100
microns. Since you know how precise you want your 3D print job to be, it's
not hard to pick a value for $fe that is small enough, without being
excessively small. Too much precision slows rendering down too much.
On 6 December 2015 at 15:57, Peter Falke <
stempeldergeschichte@googlemail.com> wrote:
I asumed jon had a reason for choosing fn=100.
2015-12-06 21:49 GMT+01:00 Trygon db5765@outlook.com:
Peter,
I assume that your comment, "Your code renders in  2 hours, 4 minutes, 48
seconds on my machine.", was not with regard to the modified code I
provided?  The modified code with $fe=0.1 renders in 6 minutes, 21 seconds
on my PC.
Trygon
View this message in context:
http://forum.openscad.org/here-s-an-interesting-one-to-speed-optimize-tp14966p14985.html
$fn=100 is a large round number, so it sounds like Jon may have done what a lot of us do, which is just pick a random number that is obviously big enough. The advantage of Trygon's $fe technique is that it's easy to be more precise than "pick a large random number". $fe=0.1 means render to a precision of 100 microns, which is good enough for most 3D printing jobs. A lot of consumer grade 3D printers don't support layer heights less than 100 microns. Since you know how precise you want your 3D print job to be, it's not hard to pick a value for $fe that is small enough, without being excessively small. Too much precision slows rendering down too much. On 6 December 2015 at 15:57, Peter Falke < stempeldergeschichte@googlemail.com> wrote: > I asumed jon had a reason for choosing fn=100. > > 2015-12-06 21:49 GMT+01:00 Trygon <db5765@outlook.com>: > >> Peter, >> >> I assume that your comment, "Your code renders in 2 hours, 4 minutes, 48 >> seconds on my machine.", was not with regard to the modified code I >> provided? The modified code with $fe=0.1 renders in 6 minutes, 21 seconds >> on my PC. >> >> Trygon >> >> >> >> >> -- >> View this message in context: >> http://forum.openscad.org/here-s-an-interesting-one-to-speed-optimize-tp14966p14985.html >> Sent from the OpenSCAD mailing list archive at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
jpmendes
Sun, Dec 6, 2015 10:29 PM
What if something like this:
Sides = 100;
DefaultSides=24;
Height = 200; // 30;
Diam = 35;
Thick=6;
module Tube(Length,Dout,Din,Sides) //render(convexity=2)
NSides= (Sides < 3 || Sides==undef)  ?  DefaultSides : Sides;
rotate_extrude(convexity=2, $fn=NSides) translate([Din/2,0,0])
    square([(Dout-Din)/2,Length]);
//Tube();
module HoleCylinder()  render(convexity=2)
Din=Diam;
Dout=Diam+Thick;
   Tube(Height,Dout,Din,Sides);
      for (i = [15:6:Height-15]) {
    for (j=[0:360/20]) {
       rotate([j*20, 90, 0])  translate([-i,0, 10]) cylinder(r=2,h=16);
HoleCylinder();
In my dual core running Windows7 32bit it renders in less than 2 minutes.
The part of the module missing is not significant in terms of speed.
Regards
jpmendes
View this message in context: http://forum.openscad.org/here-s-an-interesting-one-to-speed-optimize-tp14966p14999.html
Hi, What if something like this: Sides = 100; DefaultSides=24; Height = 200; // 30; Diam = 35; Thick=6; module Tube(Length,Dout,Din,Sides) //render(convexity=2) { NSides= (Sides < 3 || Sides==undef) ? DefaultSides : Sides; rotate_extrude(convexity=2, $fn=NSides) translate([Din/2,0,0]) square([(Dout-Din)/2,Length]); } //Tube(); module HoleCylinder() render(convexity=2) { Din=Diam; Dout=Diam+Thick; difference() { Tube(Height,Dout,Din,Sides); for (i = [15:6:Height-15]) { for (j=[0:360/20]) { rotate([j*20, 90, 0]) translate([-i,0, 10]) cylinder(r=2,h=16); } } } } HoleCylinder(); In my dual core running Windows7 32bit it renders in less than 2 minutes. The part of the module missing is not significant in terms of speed. Regards jpmendes -- View this message in context: http://forum.openscad.org/here-s-an-interesting-one-to-speed-optimize-tp14966p14999.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Dec 6, 2015 11:28 PM
Actually, no.  I just grabbed the number out of the air.  Everyone else
is right: I could have used $fn=5 easily enough.  I just wanted it to be
pretty!
mailto:db5765@outlook.com>:
 Peter,
 minutes, 48
 seconds
 on my PC.
 Trygon
Actually, no. I just grabbed the number out of the air. Everyone else is right: I could have used $fn=5 easily enough. I just wanted it to be pretty! Jon On 12/6/2015 3:57 PM, Peter Falke wrote: > I asumed jon had a reason for choosing fn=100. > > 2015-12-06 21:49 GMT+01:00 Trygon <db5765@outlook.com > <mailto:db5765@outlook.com>>: > > Peter, > > I assume that your comment, "Your code renders in 2 hours, 4 > minutes, 48 > seconds on my machine.", was not with regard to the modified code I > provided? The modified code with $fe=0.1 renders in 6 minutes, 21 > seconds > on my PC. > > Trygon >
AP
Andrew Plumb
Sun, Dec 6, 2015 11:46 PM
I usually start at $fn=8 for octagonal coverage and work up from there as needed.
Andrew.
Sent from myBrain
Peter,
on my PC.
Trygon
I usually start at $fn=8 for octagonal coverage and work up from there as needed. Andrew. Sent from myBrain > On Dec 6, 2015, at 18:28, jon <jon@jonbondy.com> wrote: > > Actually, no. I just grabbed the number out of the air. Everyone else is right: I could have used $fn=5 easily enough. I just wanted it to be pretty! > > Jon > >> On 12/6/2015 3:57 PM, Peter Falke wrote: >> I asumed jon had a reason for choosing fn=100. >> >> 2015-12-06 21:49 GMT+01:00 Trygon <db5765@outlook.com>: >>> Peter, >>> >>> I assume that your comment, "Your code renders in 2 hours, 4 minutes, 48 >>> seconds on my machine.", was not with regard to the modified code I >>> provided? The modified code with $fe=0.1 renders in 6 minutes, 21 seconds >>> on my PC. >>> >>> Trygon > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
N
Neon22
Mon, Dec 7, 2015 3:04 AM
For the forum. looks like this:
http://forum.openscad.org/file/n15005/bondy-OpenSCAD.png
The difference between the two left most ones is in the module
HoleCylinder()
$fn = undef;
$fs=0.01; // very small => $fa used
$fe=0.1; // 0.1/4 for final output?
rch = 0.1;
height = 200; // 30;
diam = 35;
function fa(r)=$fn>0?360/($fn>3?$fn:3):
				$fe>0?$fe<r?min(45,2*acos(1-$fe/r)):45:
				360/max(min(360/($fa>0.01?$fa:0.01),
					2*PI*r/($fs>0.01?$fs:0.01)),5);
	cylinder(h = 100, d = diam/10, $fa=fa(diam/20)); // intersecting
	 // translate([0,0,diam/2-4])  // non-intersecting
		// cylinder(h = 8, d = diam/10);
	// outer
	cylinder(h = height, d = diam, $fa=fa(diam/2));
	// inner
	translate([0, 0, -1])
		cylinder(h = height + 2, d = diam - 4, $fa=fa((diam-4)/2));
	// reduce the bottom end
		cylinder(h = 10 + 1, d = diam - 2 + rch, $fa=fa((diam-2+rch)/2));
	// reduce the top end
	translate([0, 0, height - 10])
			cylinder(h = 10 + 1, d = diam + 1, $fa=fa((diam+1)/2));
			cylinder(h = 10 + 1, d = diam - 2 - rch, $fa=fa((diam-2-rch)/2));
	// holes
	for (i = [15:5:height-15])
		for (a = [0:15:359])
			translate([0, 0, i])
			rotate([0, 90, a])
				HoleCylinder();
View this message in context: http://forum.openscad.org/here-s-an-interesting-one-to-speed-optimize-tp14966p15005.html
For the forum. looks like this: <http://forum.openscad.org/file/n15005/bondy-OpenSCAD.png> The difference between the two left most ones is in the module HoleCylinder() ``` $fn = undef; $fs=0.01; // very small => $fa used $fe=0.1; // 0.1/4 for final output? rch = 0.1; height = 200; // 30; diam = 35; function fa(r)=$fn>0?360/($fn>3?$fn:3): $fe>0?$fe<r?min(45,2*acos(1-$fe/r)):45: 360/max(min(360/($fa>0.01?$fa:0.01), 2*PI*r/($fs>0.01?$fs:0.01)),5); module HoleCylinder() cylinder(h = 100, d = diam/10, $fa=fa(diam/20)); // intersecting // translate([0,0,diam/2-4]) // non-intersecting // cylinder(h = 8, d = diam/10); difference() { // outer cylinder(h = height, d = diam, $fa=fa(diam/2)); // inner translate([0, 0, -1]) cylinder(h = height + 2, d = diam - 4, $fa=fa((diam-4)/2)); // reduce the bottom end translate([0, 0, -1]) cylinder(h = 10 + 1, d = diam - 2 + rch, $fa=fa((diam-2+rch)/2)); // reduce the top end translate([0, 0, height - 10]) difference() { cylinder(h = 10 + 1, d = diam + 1, $fa=fa((diam+1)/2)); cylinder(h = 10 + 1, d = diam - 2 - rch, $fa=fa((diam-2-rch)/2)); } // holes for (i = [15:5:height-15]) for (a = [0:15:359]) translate([0, 0, i]) rotate([0, 90, a]) HoleCylinder(); } ``` -- View this message in context: http://forum.openscad.org/here-s-an-interesting-one-to-speed-optimize-tp14966p15005.html Sent from the OpenSCAD mailing list archive at Nabble.com.
PF
Peter Falke
Mon, Dec 7, 2015 8:27 PM
Dear jpmendes,
I had a look at your code: The cylinders that you subtract are overlapping
by a little bit.
Now I realise this is not so importend in this case, decreasing fn makes it
run fast enough.
This line
cylinder(r=2,h=16);
I changed to
           rotate([j*20, 90, 0])  translate([-i,0, 15])
cylinder(r=2,h=16);
to remove the overlap.
This makes it 20 % faster in F5, preview and F6, render.
Here are the numbers:
F5, with overlap of the subtracted cylinders:  1 minutes 38 seconds
F5, no overlap: 1 minutes, 23 seconds,  gain in speed 20%
F6, no overlap: 1 minutes, 23 seconds,  gain in speed 20%
F6, with overlap: 1 minutes, 36 seconds
2015-12-07 4:04 GMT+01:00 Neon22 mschafer@wireframe.biz:
HoleCylinder()
$fn = undef;
rch = 0.1;
diam = 35;
        // outer
        // inner
        // holes
                        rotate([0, 90, a])
                                HoleCylinder();
Dear jpmendes, I had a look at your code: The cylinders that you subtract are overlapping by a little bit. Now I realise this is not so importend in this case, decreasing fn makes it run fast enough. This line rotate([j*20, 90, 0]) translate([-i,0, 10]) cylinder(r=2,h=16); I changed to rotate([j*20, 90, 0]) translate([-i,0, 15]) cylinder(r=2,h=16); to remove the overlap. This makes it 20 % faster in F5, preview and F6, render. Here are the numbers: F5, with overlap of the subtracted cylinders: 1 minutes 38 seconds F5, no overlap: 1 minutes, 23 seconds, gain in speed 20% F6, no overlap: 1 minutes, 23 seconds, gain in speed 20% F6, with overlap: 1 minutes, 36 seconds 2015-12-07 4:04 GMT+01:00 Neon22 <mschafer@wireframe.biz>: > For the forum. looks like this: > <http://forum.openscad.org/file/n15005/bondy-OpenSCAD.png> > The difference between the two left most ones is in the module > HoleCylinder() > ``` > $fn = undef; > $fs=0.01; // very small => $fa used > > $fe=0.1; // 0.1/4 for final output? > > rch = 0.1; > height = 200; // 30; > diam = 35; > > function fa(r)=$fn>0?360/($fn>3?$fn:3): > $fe>0?$fe<r?min(45,2*acos(1-$fe/r)):45: > 360/max(min(360/($fa>0.01?$fa:0.01), > 2*PI*r/($fs>0.01?$fs:0.01)),5); > > module HoleCylinder() > cylinder(h = 100, d = diam/10, $fa=fa(diam/20)); // intersecting > // translate([0,0,diam/2-4]) // non-intersecting > // cylinder(h = 8, d = diam/10); > > difference() { > // outer > cylinder(h = height, d = diam, $fa=fa(diam/2)); > // inner > translate([0, 0, -1]) > cylinder(h = height + 2, d = diam - 4, $fa=fa((diam-4)/2)); > // reduce the bottom end > translate([0, 0, -1]) > cylinder(h = 10 + 1, d = diam - 2 + rch, > $fa=fa((diam-2+rch)/2)); > // reduce the top end > translate([0, 0, height - 10]) > difference() { > cylinder(h = 10 + 1, d = diam + 1, > $fa=fa((diam+1)/2)); > cylinder(h = 10 + 1, d = diam - 2 - rch, > $fa=fa((diam-2-rch)/2)); > } > // holes > for (i = [15:5:height-15]) > for (a = [0:15:359]) > translate([0, 0, i]) > rotate([0, 90, a]) > HoleCylinder(); > } > ``` > > > > > -- > View this message in context: > http://forum.openscad.org/here-s-an-interesting-one-to-speed-optimize-tp14966p15005.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
