Again, I wonder if this "hack" could be automated so that the OpenSCAD
compiler generated this or reformulated a function without explicit user
intervention. Or some sort of pre-processor.
Sad that one must even consider this
On 6/15/2020 10:24 AM, nop head wrote:
I knocked 5 seconds of with this hack:
function shelf_screw_positions() = !is_undef($shelf_screw_positions) ?
$shelf_screw_positions :
let(sw = spine_width(), sd = spine_depth(), bc =
box_intrusion(box_type) + box_bezel_clearance(box_type)) [
translate([z_axis_x + sw / 2, box_depth / 2 - sd + spine_clearance
translate([-box_width / 4, box_depth / 2])
* rotate([-90, 0, 0]),
translate([box_width / 2, box_depth / 2 - bc -
shelf_boss_r - eps]) * rotate([-90, 0, -90]),
translate([box_width / 2, -box_depth / 2 + bc +
shelf_boss_r + eps]) * rotate([-90, 0, -90]),
translate([ 10, -box_depth / 2])
* rotate([-90, 0, 180]),
translate([-10, -box_depth / 2])
translate([-box_width / 2, box_depth / 2 - bc -
shelf_boss_r - eps]) * rotate([-90, 0, 90]),
translate([-box_width / 2, -box_depth / 2 + bc +
shelf_boss_r + eps]) * rotate([-90, 0, 90]),
translate([z_axis_x - sw / 2, box_depth / 2 - sd + spine_clearance
In main.scad I have:
$shelf_screw_positions = shelf_screw_positions();
The end effect is it only gets computed once in main and then any
other call gets the value cached in the $variable.
the OpenSCAD compiler generated this or reformulated a
function without explicit user intervention. Or some sort
of pre-processor.
To me it seems more useful to fix the root cause.
Each constant assignment would need to track if its value depended on
special variables or a function that depends on special variables. I
suspect most don't, in which a big optimisation would be to skip
re-evaluating them.
of pre-processor.
I only made my [ridiculous] suggestion because I believe that this
performance problem has been present for a long time, implying that
fixing the root cause is not likely in the near term
re-evaluating them.
On Mon, 15 Jun 2020 at 20:23, Torsten Paul <Torsten.Paul@gmx.de
of pre-processor.
that this performance problem has been present for a long
time, implying that fixing the root cause is not likely
in the near term
I think the chance for a specific issue to be fixed has
not much correlation to how old the issue is.
In my opinion the chances depend on how complicated it seems
to be and/or how difficult it is to reproduce (= anticipated
time needed to get it fixed) and the amount of time and
motivation people have available.
Example with some really nice work:
https://github.com/openscad/openscad/pull/3351
