A Package Manager for OpenSCAD
Mindfab
Wed, Feb 28, 2018 7:31 AM
Hey guys,
I know, I'm not the first and maybe also not the last one... but here it is,
a package manager for OpenSCAD. A Quickstart is described under the
following link...  https://github.com/RobertFach/Openscad-Modules
I didn't wanted to reinvent the wheel, that's why I studied already
available package managers. Well, after trying out several of these, I
decided to give NPM.js, the NODE.js package manager a more decent try. The
advantage of reusing an already existing package manager is obvious, they
are well  established, work flawlessly on a couple of platforms, have a good
documentation, broad acceptance and large communities behind.
Also, with NPM.js, it's also possible to specify dependencies to a registry
and at the same time to private git repositories. Each dependency (including
the project itself) has a semantic version, which can be used to reason
about compatible dependency versions. This all is amazing when building up
complex projects.
Okay, right now, I work on some examples and already released some modules
in the registry itself. For those of you, already familiar with publishing
own modules in NPM.js can do this already. This means the registry is free
for all and without any restrictive control. Others should wait for the
documentations... Anyway, just feel free to try it out, give feedback,
comments, drawbacks, improvements... For me, its just an idea I wanted to
try out and share with you.
Cheers, Mindfab aka Robert
Hey guys, I know, I'm not the first and maybe also not the last one... but here it is, a package manager for OpenSCAD. A Quickstart is described under the following link... https://github.com/RobertFach/Openscad-Modules <https://github.com/RobertFach/Openscad-Modules> I didn't wanted to reinvent the wheel, that's why I studied already available package managers. Well, after trying out several of these, I decided to give NPM.js, the NODE.js package manager a more decent try. The advantage of reusing an already existing package manager is obvious, they are well established, work flawlessly on a couple of platforms, have a good documentation, broad acceptance and large communities behind. Also, with NPM.js, it's also possible to specify dependencies to a registry and at the same time to private git repositories. Each dependency (including the project itself) has a semantic version, which can be used to reason about compatible dependency versions. This all is amazing when building up complex projects. Okay, right now, I work on some examples and already released some modules in the registry itself. For those of you, already familiar with publishing own modules in NPM.js can do this already. This means the registry is free for all and without any restrictive control. Others should wait for the documentations... Anyway, just feel free to try it out, give feedback, comments, drawbacks, improvements... For me, its just an idea I wanted to try out and share with you. Cheers, Mindfab aka Robert -- Sent from: http://forum.openscad.org/
LT
Len Trigg
Sun, Mar 4, 2018 1:40 AM
It looks interesting, and I think that a decent package manager would be a
good addition to the openscad community. As you note, there have been a
couple of attempts in the past, but they've not made it past the proof of
concept stage.
I'm not really familiar with npm. How do libraries make it into the
registry? If my openscad project makes use of a library that is currently
hosted on Thingiverse, is there a way to fetch that as a dependency?
For an openscad package manager to take off, either there needs to be a
fair bit of initial work getting a bunch of libraries into the registry to
kick things off (and probably on an ongoing basis), or it needs to have the
ability to fetch semi-random dependencies where people haven't taken the
time to tidy things up for the registry, e.g. references to libraries
residing in thingiverse and random openscad libraries stored in github
projects (presumably the latter would associated with particular
tags/commits, not sure if you could do anything about versioning those on
thingiverse).
Cheers,
Len.
On 28 February 2018 at 20:31, Mindfab robert.fach@gmx.net wrote:
Hey guys,
is,
good
(including
complex projects.
It looks interesting, and I think that a decent package manager would be a good addition to the openscad community. As you note, there have been a couple of attempts in the past, but they've not made it past the proof of concept stage. I'm not really familiar with npm. How do libraries make it into the registry? If my openscad project makes use of a library that is currently hosted on Thingiverse, is there a way to fetch that as a dependency? For an openscad package manager to take off, either there needs to be a fair bit of initial work getting a bunch of libraries into the registry to kick things off (and probably on an ongoing basis), or it needs to have the ability to fetch semi-random dependencies where people haven't taken the time to tidy things up for the registry, e.g. references to libraries residing in thingiverse and random openscad libraries stored in github projects (presumably the latter would associated with particular tags/commits, not sure if you could do anything about versioning those on thingiverse). Cheers, Len. On 28 February 2018 at 20:31, Mindfab <robert.fach@gmx.net> wrote: > Hey guys, > > I know, I'm not the first and maybe also not the last one... but here it > is, > a package manager for OpenSCAD. A Quickstart is described under the > following link... https://github.com/RobertFach/Openscad-Modules > <https://github.com/RobertFach/Openscad-Modules> > > I didn't wanted to reinvent the wheel, that's why I studied already > available package managers. Well, after trying out several of these, I > decided to give NPM.js, the NODE.js package manager a more decent try. The > advantage of reusing an already existing package manager is obvious, they > are well established, work flawlessly on a couple of platforms, have a > good > documentation, broad acceptance and large communities behind. > > Also, with NPM.js, it's also possible to specify dependencies to a registry > and at the same time to private git repositories. Each dependency > (including > the project itself) has a semantic version, which can be used to reason > about compatible dependency versions. This all is amazing when building up > complex projects. > > Okay, right now, I work on some examples and already released some modules > in the registry itself. For those of you, already familiar with publishing > own modules in NPM.js can do this already. This means the registry is free > for all and without any restrictive control. Others should wait for the > documentations... Anyway, just feel free to try it out, give feedback, > comments, drawbacks, improvements... For me, its just an idea I wanted to > try out and share with you. > > Cheers, Mindfab aka Robert > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
CC
Chris Camacho
Sun, Mar 4, 2018 2:02 AM
What would be nice to avoid, is where one person decides they don't want
to have their package published any more and it breaks all its
descendants... (something similar happened in the javascript world not
so long past I believe) Its all right drinking from an open source, as
long as you are sure what people are putting into the river up stream...
This would tend to suggest some kind of archived versioning, so people
use dependencies of a specific version and upgrade their dependency
versions as they maintain their package.
I'm not sure if there is something "off the shelf" that could do this,
but it would make the whole ecosystem much more robust...
concept stage.
thingiverse).
Cheers,
Len.
Hey guys,
is,
good
(including
complex projects.
What would be nice to avoid, is where one person decides they don't want to have their package published any more and it breaks all its descendants... (something similar happened in the javascript world not so long past I believe) Its all right drinking from an open source, as long as you are sure what people are putting into the river up stream... This would tend to suggest some kind of archived versioning, so people use dependencies of a specific version and upgrade their dependency versions as they maintain their package. I'm not sure if there is something "off the shelf" that could do this, but it would make the whole ecosystem much more robust... On 04/03/18 01:40, Len Trigg wrote: > It looks interesting, and I think that a decent package manager would be a > good addition to the openscad community. As you note, there have been a > couple of attempts in the past, but they've not made it past the proof of > concept stage. > > I'm not really familiar with npm. How do libraries make it into the > registry? If my openscad project makes use of a library that is currently > hosted on Thingiverse, is there a way to fetch that as a dependency? > > For an openscad package manager to take off, either there needs to be a > fair bit of initial work getting a bunch of libraries into the registry to > kick things off (and probably on an ongoing basis), or it needs to have the > ability to fetch semi-random dependencies where people haven't taken the > time to tidy things up for the registry, e.g. references to libraries > residing in thingiverse and random openscad libraries stored in github > projects (presumably the latter would associated with particular > tags/commits, not sure if you could do anything about versioning those on > thingiverse). > > Cheers, > Len. > > > On 28 February 2018 at 20:31, Mindfab <robert.fach@gmx.net> wrote: > >> Hey guys, >> >> I know, I'm not the first and maybe also not the last one... but here it >> is, >> a package manager for OpenSCAD. A Quickstart is described under the >> following link... https://github.com/RobertFach/Openscad-Modules >> <https://github.com/RobertFach/Openscad-Modules> >> >> I didn't wanted to reinvent the wheel, that's why I studied already >> available package managers. Well, after trying out several of these, I >> decided to give NPM.js, the NODE.js package manager a more decent try. The >> advantage of reusing an already existing package manager is obvious, they >> are well established, work flawlessly on a couple of platforms, have a >> good >> documentation, broad acceptance and large communities behind. >> >> Also, with NPM.js, it's also possible to specify dependencies to a registry >> and at the same time to private git repositories. Each dependency >> (including >> the project itself) has a semantic version, which can be used to reason >> about compatible dependency versions. This all is amazing when building up >> complex projects. >> >> Okay, right now, I work on some examples and already released some modules >> in the registry itself. For those of you, already familiar with publishing >> own modules in NPM.js can do this already. This means the registry is free >> for all and without any restrictive control. Others should wait for the >> documentations... Anyway, just feel free to try it out, give feedback, >> comments, drawbacks, improvements... For me, its just an idea I wanted to >> try out and share with you. >> >> Cheers, Mindfab aka Robert >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
G
Gadgetmind
Sun, Mar 4, 2018 1:33 PM
openscad community.
While I don't disagree, I've been bitten more than once by clashing
names within libraries. These cause mayhem that's very hard to debug.
Namespaces, or at least a convention on naming within libraries to avoid
these issues, would soon turn out to be pretty important IMO.
On 04/03/18 01:40, Len Trigg wrote: > I think that a decent package manager would be a good addition to the > openscad community. While I don't disagree, I've been bitten more than once by clashing names within libraries. These cause mayhem that's *very* hard to debug. Namespaces, or at least a convention on naming within libraries to avoid these issues, would soon turn out to be pretty important IMO.
Mindfab
Sun, Mar 4, 2018 11:31 PM
My documention is not yet complete. However, I think NPM is a pretty good
choice when combined with some rules.
I'm working on a more complex example, where one can see how NPM and
OpenSCAD can deal with the following problems:
  • Namespaces, I'm simulating the namespace by doing the following "trick". I
    include the dependencies inside a the package module. It looks like:
module stepper_mount(<parameters>) {
include <node_modules/stepper/stepper.scad>
include <node_modules/screws/screws.scad>
module do_something_useful() {
call_fn_from_stepper_scad();
call_fn_from_screw_scad();
do_something_useful();
This simulates a namespace and works perfect with npm. It also has another
advantage which is nested dependencies. That means your modules can require
dependencies in different versions. NPM takes care of all of this.
My documention is not yet complete. However, I think NPM is a pretty good choice when combined with some rules. I'm working on a more complex example, where one can see how NPM and OpenSCAD can deal with the following problems: - Namespaces, I'm simulating the namespace by doing the following "trick". I include the dependencies inside a the package module. It looks like: module stepper_mount(<parameters>) { include <node_modules/stepper/stepper.scad> include <node_modules/screws/screws.scad> module do_something_useful() { call_fn_from_stepper_scad(); ... call_fn_from_screw_scad(); } do_something_useful(); } This simulates a namespace and works perfect with npm. It also has another advantage which is nested dependencies. That means your modules can require dependencies in different versions. NPM takes care of all of this. -- Sent from: http://forum.openscad.org/
Mindfab
Sun, Mar 4, 2018 11:39 PM
You are right, this is a serious problem, but it can be dealt with. Right
now, I don't see it to serious, but the registry can be tuned in the way
that published versions cannot be deleted. This will be anyway a good
choice, because in semantic versioning (I think this is what you are
refering to by archived versioning) a published version should never be
changed. I'm not 100% sure how its implemented in the registry that I is
currently used.
Therefore, I 100% agree. Maybe you can fill out an issue in Github.
Thx,
You are right, this is a serious problem, but it can be dealt with. Right now, I don't see it to serious, but the registry can be tuned in the way that published versions cannot be deleted. This will be anyway a good choice, because in semantic versioning (I think this is what you are refering to by archived versioning) a published version should never be changed. I'm not 100% sure how its implemented in the registry that I is currently used. Therefore, I 100% agree. Maybe you can fill out an issue in Github. Thx, -- Sent from: http://forum.openscad.org/
Mindfab
Mon, Mar 5, 2018 12:04 AM
Thx for your feedback.
Publishing is pretty straight forward. If you are already familiar with NPM
you can do this already. Otherwise, just give me some time to complete the
more complex examples. In principle it works like that. You register or
login to the registry by choosing a username/password combination. Once you
are logged in, you can publish packages if you are the owner of a package or
if its a new package. Packages are identified by the "name" and "version"
fields.
Right now its not possible to use libraries from thingiverse. I also think
that it would be better to motivate the thingiverse library authors to move
to the package manager or at least use github as a repository. With NPM it's
already possible to use github as a package source. Using Thingiverse as a
source would require to modify NPM itself, this I would like to avoid. (NPM
supports tarballs over http - but this would only help with a small
percentage of the libraries on thingiverse).
My roadline was as follows:
  1. Completing the documention and more examples
  2. Asking thingiverse and github OpenSCAD library authors to add their
    libraries to the registry
  3. Move some libraries, where the authors did not respond, to the registry
    by cloning them on github and adding a package.json file.
  4. Iterating through 1,2,3,4
What do you mean by fetching semi-random dependencies?
My personal workflow already changed a lot. Beforehand I few repositories
with a couple of modules in different versions. Now, I have a lot of
repositories where my modules are stored in different versions. A new
project is always started as a new repository and with a package.json file
refering to the required dependencies. This way, my projects can always
reuse artifacts/modules from other projects and its pretty easy to increase
complexity by requiring already existing modules/projects.
I think things will be more clear with more examples. Meanwhile, just have a
look at NPM.js to get a feeling of what is possible.
Cheers, Robert
Thx for your feedback. Publishing is pretty straight forward. If you are already familiar with NPM you can do this already. Otherwise, just give me some time to complete the more complex examples. In principle it works like that. You register or login to the registry by choosing a username/password combination. Once you are logged in, you can publish packages if you are the owner of a package or if its a new package. Packages are identified by the "name" and "version" fields. Right now its not possible to use libraries from thingiverse. I also think that it would be better to motivate the thingiverse library authors to move to the package manager or at least use github as a repository. With NPM it's already possible to use github as a package source. Using Thingiverse as a source would require to modify NPM itself, this I would like to avoid. (NPM supports tarballs over http - but this would only help with a small percentage of the libraries on thingiverse). My roadline was as follows: 1) Completing the documention and more examples 2) Asking thingiverse and github OpenSCAD library authors to add their libraries to the registry 3) Move some libraries, where the authors did not respond, to the registry by cloning them on github and adding a package.json file. 4) Iterating through 1,2,3,4 What do you mean by fetching semi-random dependencies? My personal workflow already changed a lot. Beforehand I few repositories with a couple of modules in different versions. Now, I have a lot of repositories where my modules are stored in different versions. A new project is always started as a new repository and with a package.json file refering to the required dependencies. This way, my projects can always reuse artifacts/modules from other projects and its pretty easy to increase complexity by requiring already existing modules/projects. I think things will be more clear with more examples. Meanwhile, just have a look at NPM.js to get a feeling of what is possible. Cheers, Robert -- Sent from: http://forum.openscad.org/
AR
Algot Runeman
Mon, Mar 5, 2018 8:59 PM
fields.
While pipenv sounds like a parallel tool compared to the one you are
proposing, it might be useful to see what the developers of pipenv are
doing.
Descriptive article:
https://opensource.com/article/18/2/why-python-devs-should-use-pipenv
Right now this level of thinking is above my head, I am glad to see
people working on ideas like this.
--Algot
On 03/04/2018 07:04 PM, Mindfab wrote: > Thx for your feedback. > > Publishing is pretty straight forward. If you are already familiar with NPM > you can do this already. Otherwise, just give me some time to complete the > more complex examples. In principle it works like that. You register or > login to the registry by choosing a username/password combination. Once you > are logged in, you can publish packages if you are the owner of a package or > if its a new package. Packages are identified by the "name" and "version" > fields. While pipenv sounds like a parallel tool compared to the one you are proposing, it might be useful to see what the developers of pipenv are doing. Descriptive article: https://opensource.com/article/18/2/why-python-devs-should-use-pipenv Right now this level of thinking is above my head, I am glad to see people working on ideas like this. --Algot
1
1i7
Fri, Mar 9, 2018 2:43 PM
I have come across this thread after having an idea to use npm to manage
packages for OpenSCAD :) I already use NPM to store some NodeJS modules and
feel that OpenSCAD is missing such central modules repo. I am going to give
it a try and publish some modules I use in my projects. Can I somehow
register?
I have come across this thread after having an idea to use npm to manage packages for OpenSCAD :) I already use NPM to store some NodeJS modules and feel that OpenSCAD is missing such central modules repo. I am going to give it a try and publish some modules I use in my projects. Can I somehow register? -- Sent from: http://forum.openscad.org/
1
1i7
Fri, Mar 9, 2018 7:25 PM
Also, good module repository support might require better build logic
integration in OpenSCAD itself.
With NodeJS when you have project dir project1 and run
npm install some_module
inside, the module copy comes from central repository to
project1/node_modules/some_module
So whe I import some_module from JavaScript source file by name like:
require ('some_module');
NodeJS runtime would search ./node_modules/some_module to resolve this
dependency (even more, if it doest not find requested module in project dir
./node_modules, it would go one level up to ../node_modules, then one more
level up to ../../node_modules etc - so with this mecanics some module deps
can be shared among multiple projects).
This logic should be implemented on the level of build/runtime tool (NodeJS
or OpenSCAD), not on the level of package manager.
Of course one cane import module like
require ('./node_modules/some_module');
But this would not be so elegant.
Also, good module repository support might require better build logic integration in OpenSCAD itself. With NodeJS when you have project dir project1 and run npm install some_module inside, the module copy comes from central repository to project1/node_modules/some_module So whe I import some_module from JavaScript source file by name like: require ('some_module'); NodeJS runtime would search ./node_modules/some_module to resolve this dependency (even more, if it doest not find requested module in project dir ./node_modules, it would go one level up to ../node_modules, then one more level up to ../../node_modules etc - so with this mecanics some module deps can be shared among multiple projects). This logic should be implemented on the level of build/runtime tool (NodeJS or OpenSCAD), not on the level of package manager. Of course one cane import module like require ('./node_modules/some_module'); But this would not be so elegant. -- Sent from: http://forum.openscad.org/
