Thu, Dec 30, 2021 7:19 PM
On Thu, 2021-12-30 at 10:11 -0800, David Phillip Oster wrote:
- after rewatching that Vi Hart video, at least either 6 or 9 should
be replaced by something, so they won't be confusable on the
actual dice.
Just put a horizontal bar under the number.
> 3) after rewatching that Vi Hart video, at least either 6 or 9 should
> actual dice.
DP
David Phillip Oster
Thu, Dec 30, 2021 7:27 PM
Yes. Since I wrote last, I looked at some other d20. They solved the
problem by using:
sides=[1,2,3,4,5,"6.",7,8,9,10,11,12,13,14,15,16,17,18,19,20];
actual dice.
problem by using:
> > actual dice.
DP
David Phillip Oster
Thu, Dec 30, 2021 8:51 PM
here is a sides array where opposite faces sum to 21:
sides=[1,2,3,4,5,"6.",7,8,"9.",10,15,14,13,12,11,17,18,19,20,16];
On Thu, Dec 30, 2021 at 11:27 AM David Phillip Oster <
problem by using:
actual dice.
> problem by using:
>> > actual dice.
