Can't run development snapshot of OpenSCAD on OSX
EB
Eric Buijs
Thu, Dec 8, 2016 5:33 PM
Hello, I tried to run the OpenSCAD development snapshot 2016.11.21 on my iMac
but it won't even start. In the console I find the following relevant
entries:
/08/12/16 18:14:31,000 kernel[0]: hfs: mounted OpenSCAD on device disk1s1
08/12/16 18:14:31,481 mds[57]: (Volume.Normal:2464) volume:0x7fce04856a00
********** Bootstrapped Creating a default store:1 SpotLoc:(null)
SpotVerLoc:(null) occlude:0 /Volumes/OpenSCAD
08/12/16 18:14:42,723 OpenSCAD[2182]: Customizer feature not activated
08/12/16 18:14:42,723 OpenSCAD[2182]: Usage:
/Volumes/OpenSCAD/OpenSCAD.app/Contents/MacOS/OpenSCAD [ -o output_file [ -d
deps_file ] ]
08/12/16 18:14:42,725 com.apple.xpc.launchd[1]:
(com.apple.xpc.launchd.oneshot.0x10000005.OpenSCAD[2182]) Service exited
with abnormal code: 1/
I couldn't find a log file (normally at /Library/Logs/DiagnosticReports)
My PC specs are:
OSX version 10.10.5
iMac 21.5 inch, Mid 2011
2.7GHz Intel Core i5
4Gb DDR3
AMD Radeon HD 6770M 512MB
View this message in context: http://forum.openscad.org/Can-t-run-development-snapshot-of-OpenSCAD-on-OSX-tp19508.html
Hello, I tried to run the OpenSCAD development snapshot 2016.11.21 on my iMac but it won't even start. In the console I find the following relevant entries: /08/12/16 18:14:31,000 kernel[0]: hfs: mounted OpenSCAD on device disk1s1 08/12/16 18:14:31,481 mds[57]: (Volume.Normal:2464) volume:0x7fce04856a00 ********** Bootstrapped Creating a default store:1 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/OpenSCAD 08/12/16 18:14:42,723 OpenSCAD[2182]: Customizer feature not activated 08/12/16 18:14:42,723 OpenSCAD[2182]: Usage: /Volumes/OpenSCAD/OpenSCAD.app/Contents/MacOS/OpenSCAD [ -o output_file [ -d deps_file ] ]\ 08/12/16 18:14:42,725 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.oneshot.0x10000005.OpenSCAD[2182]) Service exited with abnormal code: 1/ I couldn't find a log file (normally at /Library/Logs/DiagnosticReports) My PC specs are: OSX version 10.10.5 iMac 21.5 inch, Mid 2011 2.7GHz Intel Core i5 4Gb DDR3 AMD Radeon HD 6770M 512MB -- View this message in context: http://forum.openscad.org/Can-t-run-development-snapshot-of-OpenSCAD-on-OSX-tp19508.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Dec 8, 2016 6:13 PM
How are you running OpenSCAD?
This error message should only happen if you attempt to pass the -p or -P cmd-line argument without having customizer enabled.
You can enable customizer under Preferences->Features
On Dec 8, 2016, at 12:33, Eric Buijs <ebuijs@mac.com> wrote: > > Hello, I tried to run the OpenSCAD development snapshot 2016.11.21 on my iMac > but it won't even start. In the console I find the following relevant entries: > How are you running OpenSCAD? This error message should only happen if you attempt to pass the -p or -P cmd-line argument without having customizer enabled. You can enable customizer under Preferences->Features -Marius
EB
Eric Buijs
Fri, Dec 9, 2016 8:43 AM
I downloaded the disk image file and mounted it by double clicking the dmg
file. I both tried running OpenSCAD from the mounted disk or dragging the
program to the Applications folder first. So no (intentional) attempt to
pass the -p or -P cmd line argument.
The program won't even start, so I can't enable the customizer.
Eric.
View this message in context: http://forum.openscad.org/Can-t-run-development-snapshot-of-OpenSCAD-on-OSX-tp19508p19515.html
I downloaded the disk image file and mounted it by double clicking the dmg file. I both tried running OpenSCAD from the mounted disk or dragging the program to the Applications folder first. So no (intentional) attempt to pass the -p or -P cmd line argument. The program won't even start, so I can't enable the customizer. Eric. -- View this message in context: http://forum.openscad.org/Can-t-run-development-snapshot-of-OpenSCAD-on-OSX-tp19508p19515.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Fri, Dec 9, 2016 3:32 PM
Hi Eric,
Thanks for the clarification. It sounds like Finder is somehow adding some extra cmd-line parameters on launch.
Could you try running it from the cmd-line to check that it works outside a launch from Finder?
In a terminal:
/Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD
Hi Eric, Thanks for the clarification. It sounds like Finder is somehow adding some extra cmd-line parameters on launch. Could you try running it from the cmd-line to check that it works outside a launch from Finder? In a terminal: /Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD -Marius
EB
Eric Buijs
Sat, Dec 10, 2016 3:02 PM
Yes, running it from the command line works fine. Thanks Marius.
http://forum.openscad.org/file/n19530/openscad2.png
View this message in context: http://forum.openscad.org/Can-t-run-development-snapshot-of-OpenSCAD-on-OSX-tp19508p19530.html
Yes, running it from the command line works fine. Thanks Marius. <http://forum.openscad.org/file/n19530/openscad2.png> -- View this message in context: http://forum.openscad.org/Can-t-run-development-snapshot-of-OpenSCAD-on-OSX-tp19508p19530.html Sent from the OpenSCAD mailing list archive at Nabble.com.
