Apologies.
The second version I posted doesn't work right now due to a bug in BOSL2.
Change the line
down(1)offset_sweep(inside, h=H+1, top=os_circle(r=-2),extra=1);
to
down(1)offset_sweep(inside, h=H+1, top=os_circle(r=-2,extra=1));
The first version should work, so when I found the bug I fixed it...but the
fix isn't out yet and I forgot to switch things around to dodge the bug
when I posted the code. (The bug is that you can't apply the extra
argument to an end with no end treatment.)
On Sun, Sep 3, 2023 at 6:12 PM Ken bats059@gmail.com wrote:
Adrian, your first solution works beautifully, but with your second
solution, I get an error
WARNING: undefined operation (undefined + vector) in file
../../Users/user/Documents/OpenSCAD/libraries/BOSL2/rounding.scad, line 595
followed by a heap of trace calls-
TRACE: called by 'concat' in file
TRACE: called by '_rounding_offsets' in file
../../Users/user/Documents/OpenSCAD/libraries/BOSL2/rounding.scad, line 1583
TRACE: called by 'offset_sweep' in file
../../Users/user/Documents/OpenSCAD/libraries/BOSL2/rounding.scad, line 1644
TRACE: assignment to 'vnf' in file
TRACE: called by 'offset_sweep' in file code.scad, line 22
TRACE: called by 'children' in file
../../Users/user/Documents/OpenSCAD/libraries/BOSL2/transforms.scad, line
395
TRACE: called by 'translate' in file
395
TRACE: call of 'down(z = 1, p = undef)' in file
392
TRACE: called by 'down' in file code.scad, line 22
TRACE: called by 'difference' in file code.scad, line 20
Execution aborted
and I'm afraid my openscad skills are not up to finding what the error is-
what am I doing wrong?
On 2023-09-03 22:59, Adrian Mariano wrote:
I think that Sanjeev has identified the two main approaches. You can make
a rounded rectangle shape and sweep. That would look like this:
include<BOSL2/std.scad>
$fa=1;$fs=1;
W=34;L=60;H=10;Or = 8;Ir = 3;
section = rect([Or-Ir,H], rounding=[2,2,0,0],anchor=BOT+LEFT);
path = rect([W,L],rounding=Ir);
path_sweep(section,path,closed=true);
Note that I have chosen as the sweep path the inner rounded rectangle
which avoids issues with self-intersection of the sweep. This is probably
the best way to do this in terms of efficiency. Note also that using
turtle() to compute a rounded rectangle is overkill. I only use turtle()
for shapes that are somehow irregular.
Sanjeev's second approach is to use offsetting. This is possible using
offset_sweep(), but will likely be slower than path_sweep() because
computing offset in userspace is slow. To do this, you have to compute the
outside rounded shape and then subtract the inner rounded shape. So it
could be done like this:
include<BOSL2/rounding.scad>
$fa=1;$fs=1;
inside = rect([W,L]-(Or-Ir)*[2,2], rounding=Ir);
outside = rect([W,L], rounding=Or);
offset_sweep(outside, h=H, top=os_circle(r=2));
Note that you could also compute just one of inside and outside directly
and get the other one with offset().
A third way to make a shape like this is to use rounded_prism(), again
with a difference. However, rounded_prism doesn't make circular roundings,
so the results will be a bit different, and it will not be possible to
assure a uniform width at the corners. (Roundovers here are continuous
curvature beziers. The k parameter controls how gentle the transition,
with a value of .8 close to circular. Smaller k values will give gentler
transitions, but then large joint distance may be desired. Try changing k
to 0.5 to see the difference.)
$fa=1;$fs=1;
diff(){
rounded_prism(rect([W,L]),height=H, joint_top=2, joint_sides=8,k=.8)
up(.01)align(TOP,inside=true)rounded_prism(rect([W,L]-[5,5]),height=H+1,
joint_top=-2, joint_sides=6,k=.8);
On Sun, Sep 3, 2023 at 7:18 AM Sanjeev Prabhakar sprabhakar2006@gmail.com
I will explain the process
I think this is important.
There are 2 approaches.
I am sure this explanation is not enough. Will create a visual
description and send it to you.
For approach 2:
The key is writing a function to offset a section, which I think is not
so easy.
On Sun, 3 Sept, 2023, 4:32 pm Bob Roos, roosbob@wybatap.com wrote:
Hi Sanjeev,
Thank you. It's beautiful, but how did you generate all those points??
I had to hollow out the part a bit and change the shape some so I would
like to find a more generic way to round the edges.
Bob
Sunday, September 3, 2023, 6:17:54 AM, you wrote:
[image: Screenshot 2023-09-03 at 3.45.43 PM.png]
On Sun, 3 Sept 2023 at 06:50, Bob Roos roosbob@wybatap.com wrote:
Hello OpenSCAD,
I want the bottom to be straight and the top inside and outside edges
to have 2mm roundover
Thank you.
include <BOSL2/std.scad> //or screws or threading
W=34;
L=60;
H=10;
Or = 8;
Ir = 3;
rect_tube(size=[W,L], wall=5, rounding=Or, h=H,irounding=3);
Best regards,
Bob mailto:roosbob@wybatap.com
have Fun,
roosbob@wybatap.com
