Programming is communicating with a machine and communicating with
others (including your future self) who reuse, adapt, and extend your
program.
This proposed namespace keyword and functionality clearly communicates
to the machine that library names should not be shared with the user's
names.
To the human, it clearly communicates the author's intention to have
separate names. It reuses the existing syntax and layout, making
adoption trivial for existing libraries:
namespace bosl2_threading {
using bosl2_utility;
using bosl2_skin;
using bosl2_attachable;
using bosl2_lists;
using bosl2_shapes3d;
module generic_nut() {...} // Exact same code as before indented once
With object() as namespaces, the namespace names share the
assignment/variable environment, still causing collisions. The syntax
requires rewriting the code to function literals instead of function
keyword definition and wait for module literals to be implemented before
then rewriting all method definitions and every reference to other
libraries must be individually updated:
bosl2_threading = object(
generic_nut = module() {
// Make assignments for every single module and function declared
in bosl2_threading:
all_positive = bosl2.utility.all_positive;
first_defined = bosl2.utility.first_defined;
linear_sweep = bosl2.skin.linear_sweep;
attachable = bosl2.attachable.attachable;
in_list = bosl2.lists.in_list;
cyl = bosl2.shapes3d.cyl;
// Rest of the existing code
A draft PR is under way
https://github.com/openscad/openscad/pull/6131. I expect to have it
working in 1.5 weeks or sooner. In the next couple days I should have
using working; at that point others can start playing with it if desired.
Technical discussion is happening on the original Namespace Issue
https://github.com/openscad/openscad/issues/522.
This isn't exclusive with whether to treat object as a limited form of
OO with this.
