I'm trying to create a teardrop shape using OpenSCAD - however I'm getting
issues with the rendering. It is only giving me a semicircle, yet in preview
it looks exactly how I want it to.
I have tried to translate the triangular portion so that it is inside the
semicircle, however this didn't seem to help.
Thanks,
Ed
radius = 15;
height = 10;
length = 50;
union () {
cylinder(h=height,r=radius,center=false,$fn = 100);
translate([-radius,0,0])//translate so centered
cube(size=[radius2, radius2, height], center=false, $fn = 100);
//have so semicircle, slightly larger
//translate([0,-0.5,0])
polyhedron( //triangle
points = [
[-radius,0,0],[radius,0,0],[0,length,0], //bottom
[-radius,0,height],[radius,0,height],[0,length,height] //top
faces = [
[3,4,5],[0,1,2], //top and bottom
[0,3,5],[0,5,2], // -x to y
[0,4,3],[0,4,1], // -x to x
[1,4,2],[4,5,2] // x to y
], $fn = 100
View this message in context: http://forum.openscad.org/Issue-between-preview-and-rendering-tp13555.html
Hi regressor,
try
$fn=180;
translate([0,0,20])
hull() {
scale([1,1,10/30]) sphere(15);
translate([0,50,0]) sphere(0.01);
translate([0,0,-20])
hull() {
cylinder(h=10,r=15);
translate([0,50,0]) cylinder(h=10,r=0.01);
Regards,
Jean-Paul
AC9GH
Thanks,
Ed
radius = 15;
height = 10;
length = 50;
union () {
points = [
faces = [
], $fn = 100
Check View/Thrown-together (after F5 - maybe need to Design/Flush-cache) the
purple shows your polyhedron is inside out.
View this message in context: http://forum.openscad.org/Issue-between-preview-and-rendering-tp13555p13557.html
You also want to difference() something slightly bigger than the first object
otherwise the preview looks bad (https://en.wikipedia.org/wiki/Z-fighting),
like so
s=0.01;
union () {
translate([-radius,0,-s])//translate so centered
cube(size=[radius2, radius2, height+s*2], center=false, $fn =
100); //have so semicircle, slightly larger
View this message in context: http://forum.openscad.org/Issue-between-preview-and-rendering-tp13555p13558.html
If the model should stay as a flat object, it might be helpful to create
the shape in 2D and just extrude that at the end. In most cases that's
much faster then directly going to 3D and has no risk of producing
problematic geometry.
radius = 15;
height = 10;
length = 50;
linear_extrude(height = height) {
hull() {
circle(r = radius);
translate([0, length]) circle(r = 0.1);
