Experimental features from the command line?
Mon, Dec 11, 2017 1:24 AM
I have lc-each enabled on in the GUI but it doesn't work from the command
line. I get
ERROR: Experimental feature not enabled: 'lc-each'. Please check
preferences.
Is is expected to work from the command line. The preferences are stored in
the registry under Windows and I have verified they are set.
I have lc-each enabled on in the GUI but it doesn't work from the command line. I get ERROR: Experimental feature not enabled: 'lc-each'. Please check preferences. Is is expected to work from the command line. The preferences are stored in the registry under Windows and I have verified they are set.
Mon, Dec 11, 2017 1:33 AM
GUI settings don’t affect the cmd-line.
"openscad --enable=lc-each" should do the trick
GUI settings don’t affect the cmd-line. "openscad --enable=lc-each" should do the trick -Marius > On Dec 10, 2017, at 8:24 PM, nop head <nop.head@gmail.com> wrote: > > I have lc-each enabled on in the GUI but it doesn't work from the command line. I get > ERROR: Experimental feature not enabled: 'lc-each'. Please check preferences. > > Is is expected to work from the command line. The preferences are stored in the registry under Windows and I have verified they are set. > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Mon, Dec 11, 2017 1:42 AM
Yes that works, thanks.
command line. I get
preferences.
Yes that works, thanks. On 11 December 2017 at 01:33, Marius Kintel <marius@kintel.net> wrote: > GUI settings don’t affect the cmd-line. > "openscad --enable=lc-each" should do the trick > > -Marius > > > On Dec 10, 2017, at 8:24 PM, nop head <nop.head@gmail.com> wrote: > > > > I have lc-each enabled on in the GUI but it doesn't work from the > command line. I get > > ERROR: Experimental feature not enabled: 'lc-each'. Please check > preferences. > > > > Is is expected to work from the command line. The preferences are stored > in the registry under Windows and I have verified they are set. > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
