yes, but usually you pay lots of support for that and the model is probably
not located horizontally, where 3dprints have biggest strength ...
On Thu, Sep 19, 2024 at 6:56 AM Michael Marx (spintel) via Discuss <
Also remember a2 + b2 = c2 using the diagonal of the build plate.
Depending on thickness you can get to ~280mm
From: Shaporev, Timur via Discuss [mailto:discuss@lists.openscad.org]
Sent: Wed, 18 Sep 2024 17:43
Cc: Gábor Magyar; Shaporev, Timur
Subject: [OpenSCAD] Re: too big for printing
https://www.thingiverse.com/thing:35834
From: Gábor Magyar via Discuss discuss@lists.openscad.org
Sent: 17 September 2024 14:01:48
Cc: Gábor Magyar
Subject: [OpenSCAD] too big for printing
Hello!
A large shape should be produced with a 3D printer.
Printing options: 200x200x300mm.
The object, 410x10x530mm.
Which library has the knowledge to cut the design to a printable size?
What other solutions are possible?
Thanks for your answer!
Üdvözlettel,
Magyar Gábor
> *From:* Shaporev, Timur via Discuss [mailto:discuss@lists.openscad.org]
> *Sent:* Wed, 18 Sep 2024 17:43
> *To:* OpenSCAD general discussion Mailing-list
> *Cc:* Gábor Magyar; Shaporev, Timur
> *Subject:* [OpenSCAD] Re: too big for printing
> BTW it is not that difficult manually, e.g.
> https://www.thingiverse.com/thing:4497910 😉
> *From:* Gábor Magyar via Discuss <discuss@lists.openscad.org>
> *Sent:* 17 September 2024 14:01:48
> *Cc:* Gábor Magyar
> *Subject:* [OpenSCAD] too big for printing
> Hello!
> Üdvözlettel,
> Magyar Gábor
