small see through dialog when starting
MC
Mr C Camacho
Sun, Apr 9, 2017 5:06 PM
I get no feedback from the console, and sometimes it happens all the
times and for a while it wasn't at all...
when the scad source is loaded (either from start up dialog or file
menu) a small dialog is shown, which is see through or more exactly no
internal content gets drawn at all. I can't close the dialog with the
close widget in the top right but fortunately its not modal so I can use
the application.
anyone seen this ?
here's the info from the libs and build dialog (without the GL flags)
OpenSCAD Version: 2017.03.28System information: Linux 4.10.9_1 #1 SMP
PREEMPT Sat Apr 8 19:26:15 UTC 2017 x86_64 void 4 CPUs 7.71 GB
RAMCompiler: GCC "6.3.0" 64bitBoost version: 1_62Eigen version:
3.3.3CGAL version, kernels: 4.8.1, Cartesian, Extended_cartesian,
EpeckOpenCSG version: OpenCSG 1.4.2Qt version: 5.8.0QScintilla version:
2.10MingW build: NoGLib version: 2.52.0libzip version: 1.2.0Application
Path: /usr/local/binDocuments Path: /home/chris/.local/shareResource
Path: /usr/local/share/openscadUser Library Path:
/home/chris/.local/share/OpenSCAD/librariesUser Config Path:
/home/chris/.config/OpenSCADBackup Path:
/home/chris/.local/share/OpenSCAD/backupsOPENSCADPATH: OpenSCAD library
path: /home/chris/.local/share/OpenSCAD/libraries
/usr/local/share/openscad/libraries OPENSCAD_FONT_PATH: OpenSCAD font
path: /usr/share/fonts /home/chris/.local/share/fonts /home/chris/.fonts
/usr/X11/lib/X11/fonts /System/Library/Fonts /Library/Fonts
/home/chris/Library/Fonts /usr/share/fonts/TTF /usr/share/fonts/Type1
/usr/share/fonts/X11 /usr/share/fonts/cantarell /usr/share/fonts/oiio
/usr/share/fonts/X11/100dpi /usr/share/fonts/X11/75dpi
/usr/share/fonts/X11/cyrillic /usr/share/fonts/X11/misc
/usr/share/fonts/X11/utilGLEW version: 1.13.0OpenGL Version: 3.0 Mesa
17.0.3GL Renderer: Mesa DRI Intel(R) HD Graphics 5500 (Broadwell GT2) GL
Vendor: Intel Open Source Technology Center RGBA(8880), depth(0), stencil(0)
I get no feedback from the console, and sometimes it happens all the times and for a while it wasn't at all... when the scad source is loaded (either from start up dialog or file menu) a small dialog is shown, which is see through or more exactly no internal content gets drawn at all. I can't close the dialog with the close widget in the top right but fortunately its not modal so I can use the application. anyone seen this ? here's the info from the libs and build dialog (without the GL flags) OpenSCAD Version: 2017.03.28System information: Linux 4.10.9_1 #1 SMP PREEMPT Sat Apr 8 19:26:15 UTC 2017 x86_64 void 4 CPUs 7.71 GB RAMCompiler: GCC "6.3.0" 64bitBoost version: 1_62Eigen version: 3.3.3CGAL version, kernels: 4.8.1, Cartesian, Extended_cartesian, EpeckOpenCSG version: OpenCSG 1.4.2Qt version: 5.8.0QScintilla version: 2.10MingW build: NoGLib version: 2.52.0libzip version: 1.2.0Application Path: /usr/local/binDocuments Path: /home/chris/.local/shareResource Path: /usr/local/share/openscadUser Library Path: /home/chris/.local/share/OpenSCAD/librariesUser Config Path: /home/chris/.config/OpenSCADBackup Path: /home/chris/.local/share/OpenSCAD/backupsOPENSCADPATH: OpenSCAD library path: /home/chris/.local/share/OpenSCAD/libraries /usr/local/share/openscad/libraries OPENSCAD_FONT_PATH: OpenSCAD font path: /usr/share/fonts /home/chris/.local/share/fonts /home/chris/.fonts /usr/X11/lib/X11/fonts /System/Library/Fonts /Library/Fonts /home/chris/Library/Fonts /usr/share/fonts/TTF /usr/share/fonts/Type1 /usr/share/fonts/X11 /usr/share/fonts/cantarell /usr/share/fonts/oiio /usr/share/fonts/X11/100dpi /usr/share/fonts/X11/75dpi /usr/share/fonts/X11/cyrillic /usr/share/fonts/X11/misc /usr/share/fonts/X11/utilGLEW version: 1.13.0OpenGL Version: 3.0 Mesa 17.0.3GL Renderer: Mesa DRI Intel(R) HD Graphics 5500 (Broadwell GT2) GL Vendor: Intel Open Source Technology Center RGBA(8880), depth(0), stencil(0)
Sun, Apr 9, 2017 11:42 PM
Are you using text()? It could be the font cache build.
Does it eventually go away?
Have you tried the release version 2015.03?
View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21148.html
Are you using text()? It could be the font cache build. Does it eventually go away? Have you tried the release version 2015.03? ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21148.html Sent from the OpenSCAD mailing list archive at Nabble.com.
MC
Mr C Camacho
Mon, Apr 10, 2017 1:54 PM
I seems erratic, and its difficult to tell without any kind of feedback,
I don't remember seeing it with the file release version.
I seems erratic, and its difficult to tell without any kind of feedback, I don't remember seeing it with the file release version. On 10/04/17 00:42, MichaelAtOz wrote: > Are you using text()? It could be the font cache build. > Does it eventually go away? > Have you tried the release version 2015.03? > > > > ----- > Admin - PM me if you need anything, or if I've done something stupid... > > Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21148.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Mon, Apr 10, 2017 9:34 PM
Try deleting the fontconfig folder, sorry I don't know where it is on Linux.
View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21169.html
Are you using text()? Try deleting the fontconfig folder, sorry I don't know where it is on Linux. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21169.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Apr 10, 2017 9:35 PM
Can you get a screen capture?
View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21170.html
Can you get a screen capture? ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21170.html Sent from the OpenSCAD mailing list archive at Nabble.com.
MC
Mr C Camacho
Mon, Apr 10, 2017 10:25 PM
typically its stopped doing it again...
its a small dialog say about eighth of the screen width and half that
size in height.
I can't remember of it appears only in projects with text, I have a
number of different
project some with text and some without that often get tweaked, but I'll
keep an eye open...
typically its stopped doing it again... its a small dialog say about eighth of the screen width and half that size in height. I can't remember of it appears only in projects with text, I have a number of different project some with text and some without that often get tweaked, but I'll keep an eye open... On 10/04/17 22:35, MichaelAtOz wrote: > Can you get a screen capture? > > > > ----- > Admin - PM me if you need anything, or if I've done something stupid... > > Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21170.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Mon, Apr 10, 2017 10:35 PM
Would it be similar to this?
http://forum.openscad.org/file/n21175/font_config.png
View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21175.html
Would it be similar to this? <http://forum.openscad.org/file/n21175/font_config.png> ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21175.html Sent from the OpenSCAD mailing list archive at Nabble.com.
MC
Mr C Camacho
Tue, Apr 11, 2017 8:17 AM
its about that size but with nicer decoration ;p, I wonder why the gui
isn't updating it though???
its about that size but with nicer decoration ;p, I wonder why the gui isn't updating it though??? On 10/04/17 23:35, MichaelAtOz wrote: > Would it be similar to this? > <http://forum.openscad.org/file/n21175/font_config.png> > > > > ----- > Admin - PM me if you need anything, or if I've done something stupid... > > Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21175.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Tue, Apr 11, 2017 11:44 AM
I'm not a linux guy, but I would suspect a wrong library in the build.
View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21191.html
I'm not a linux guy, but I would suspect a wrong library in the build. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21191.html Sent from the OpenSCAD mailing list archive at Nabble.com.
MC
Mr C Camacho
Tue, Apr 11, 2017 2:04 PM
didn't see any warnings in the compile, I'm building against qt5 which I
assume everyone else uses ??
didn't see any warnings in the compile, I'm building against qt5 which I assume everyone else uses ?? On 11/04/17 12:44, MichaelAtOz wrote: > I'm not a linux guy, but I would suspect a wrong library in the build. > > > > ----- > Admin - PM me if you need anything, or if I've done something stupid... > > Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: http://forum.openscad.org/small-see-through-dialog-when-starting-tp21144p21191.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
