I have noticed version 2014.11.07 often stops working (openccad has stopped
working is what windows tells me") for no reason. This doesn't seem to be
related to any particular piece of code.
View this message in context: http://forum.openscad.org/Many-crashes-in-2014-11-07-tp10346.html
I experience the same. Lots of crashes with 2014.11.09. Sometimes a piece of
code works, sometimes it crashes OpenSCAD.
View this message in context: http://forum.openscad.org/Many-crashes-in-2014-11-07-tp10346p10347.html
It's been fine for me so far. W7-64
View this message in context: http://forum.openscad.org/Many-crashes-in-2014-11-07-tp10346p10348.html
Please report any such crashes with as much detail as possible.
We’re striving to keep the development snapshots stable, but bugs will creep in. The sooner we learn about them, the sooner we can fix them.
Especially on Windows, as we don’t currently have any devs using Windows as our primary platform.
PS! New dev snapshot out today.
There's no real detail, it seems completely random. :(
View this message in context: http://forum.openscad.org/Many-crashes-in-2014-11-07-tp10346p10358.html
On Thu, 4 Dec 2014 15:49:14 -0700 (MST)
Is anyone seeing the same in Linux ? If so it might be worth running it
under valgrind to see what that flags up.
Alan
I did not see just random crashes (on Linux). Pretty much all real crashes
(e.g. OpenSCAD process is killed, not things like "not responding") were
related to either undefined parameters "polygon(points = undef)" or due
to recursion hitting the stack limit (which should be much better in the
latest snapshot).
Running with valgrind is unfortunately not so easy as it requires a special
flag while compilation (-DCGAL_DISABLE_ROUNDING_MATH_CHECK=ON).
Here is another thread where I posted a script that sometimes works,
somestimes not.
http://forum.openscad.org/Simple-script-crashes-OpenSCAD-2014-11-09-Windows-Dev-version-td10239.html
View this message in context: http://forum.openscad.org/Many-crashes-in-2014-11-07-tp10346p10371.html
