I'm bumping into another limit - for long lists of points the following fails
with
WARNING: Bad range parameter in for statement: too many elements (12288), in
file lsystem.scad, line 69
module path(points,width,closed=false) {
r=width/2;
for (i=[0:len(points)-2]) {
hull() {
translate(points[i]) circle(r);
translate(points[i+1]) circle(r);
if (closed) {
hull() {
translate(points[len(points)-1])
circle(r);
translate(points[0])
circle(r);
A workaround is to replace the range with a vector in the for statement:
for (i=to_n(len(points)-2))
where
function to_n(n) = [for (i=0;i<=n;i=i+1) i];
but this seems clumsy
Any other ways to get past this limit - I believe it's 9999 ?
Kit
Another workaround is to use a nested loop.
This is hardcoded in OpenSCAD in about half a dozen places. I should either
be a preference of a much higher value. 10000 elements in a list is nothing
on today's hardware. 10000 3D CSG operations on the other hand will bring
CGAL to its knees.
fails
with
in
r=width/2;
hull() {
if (closed) {
hull() {
circle(r);
circle(r);
where
Kit
Yes I think the 10000 limit comes from the days when 2D was done with CGAL
and there were no list comprehensions, so everything was slow.
On Tue, 15 Oct 2019 at 10:56, kitwallace kit.wallace@gmail.com wrote:
Although 2D CSG is really fast - 16,000 hull() operations in less than a
minute with the DXF output destined for laser engraving.
