Thanks, but cc does not seem to import my png files. I do not have the
inclination to dig further, since i think I can get around the problem
within openscad itself, using offsets on the png surface file(translated
and projected).
On 06/03/2023 16:14, William F. Adams wrote:
If you have a high-resolution image, I would suggest tracing.
A free program which includes this feature is Carbide Create v6:
https://carbide3d.com/carbidecreate/download6
For information on tracing see:
https://community.carbide3d.com/t/carbide-create-image-tracing/31208
Then, once you have a vector image you can adjust it as needed and
export to an SVG which can be imported into OpenSCAD.
To: OpenSCAD general discussion Discuss@lists.openscad.org
Sent: Mon, Mar 6, 2023 10:12 am
Subject: [OpenSCAD] OT - PNG jaggies
In the past, I've drawn icons and the like, by using a felt-tip pen,
at a large size, and using a desktop scanner and reducing the size in
image editing software. This reduces errors and gives the impression
of smoothing the ragged edges when printed at the final size. However,
the same technique does not seem to work for openscad, which seems to
pick up the individual pixels from the scan resolution, giving a very
complex outline for png's. Smoothing, the usual visual way, simply
blurs the outline, and reverting to black and white, returns it to
more or less to the original resolution. Anyone know of any smoothing
software that will actually smooth out the jagged edges?
An example of an image is attached, which needs to be about 24 units
between leaf tips.
and projected).
> William
> Sphinx of black quartz, judge my vow.
> -----Original Message-----
> From: Raymond West <raywest@raywest.com>
> To: OpenSCAD general discussion <Discuss@lists.openscad.org>
> between leaf tips.
