Wed, Jul 20, 2022 10:52 PM
Before I go off and re-invent the nut, does the BOSL2 library provide a
module for modelling metric square nuts? It appears that metric_nut() only
provides hex nuts.
I very much like the way that square nuts are used in the Prusa 3D printer
and would like to use that method myself.
Thanks!
provides hex nuts.
Thanks!
Wed, Jul 20, 2022 11:20 PM
There is presently no direct support for square nuts. Write it and
we'll add it. The main nontrivial thing missing, I think, is the
table of nut sizes. One thing to be aware of is that right now BOSL2
has two redundant systems for making screws. Probably
metric_screws.scad will go away because it's less general than
screws.scad. But at the moment, screws.scad doesn't know about nut
dimensions at all.
On Wed, Jul 20, 2022 at 6:52 PM Leonard Martin Struttmann
lenstruttmann@gmail.com wrote:
Before I go off and re-invent the nut, does the BOSL2 library provide a module for modelling metric square nuts? It appears that metric_nut() only provides hex nuts.
I very much like the way that square nuts are used in the Prusa 3D printer and would like to use that method myself.
Thanks!
dimensions at all.
> Thanks!
Thu, Jul 21, 2022 12:03 AM
Adrian,
Well, since Amazon has promised that my order of assorted square nuts is to
arrive this Friday, I may just take that challenge. The only issue is that
I know absolutely nothing about GitHub. Is there a tutorial for the
workflow of contributing updates?
Thanks!
Len
dimensions at all.
provides hex nuts.
Adrian,
Thanks!
Len
> dimensions at all.
> provides hex nuts.
> > Thanks!
Thu, Jul 21, 2022 5:47 AM
Adrian,
to arrive this Friday, I may just take that challenge. The only issue is
that I know absolutely nothing about GitHub. Is there a tutorial for the
Thanks!
Len
dimensions at all.
provides hex nuts.
NopSCADlib has square nuts: https://github.com/nophead/NopSCADlib#Nuts
On Thu, 21 Jul 2022 at 01:03, Leonard Martin Struttmann <
> Adrian,
> Thanks!
> Len
>> dimensions at all.
>> provides hex nuts.
>> > Thanks!
Thu, Jul 21, 2022 9:39 AM
metric square nuts, where a standard is quoted is are often to din 562
(some dimensions here
(https://fullerfasteners.com/tech/din-562-specifications/) I've no idea
if Prusa's nuts are to that standard. Of course, you could always add
aero nuts, T nuts and Nylocs, etc. (and the equivalent for Ansi, too.)
dimensions at all.
Thanks!
> dimensions at all.
>> Thanks!
Thu, Jul 21, 2022 11:23 AM
provides hex nuts.
Thanks!
There appears to be two stds for those, and Prusa uses the thinner version.
Just saying.
Cheers, Gene Heskett.
> provides hex nuts.
> Thanks!
Just saying.
- Louis D. Brandeis
Genes Web page <http://geneslinuxbox.net:6309/>
