command line help
Sun, Mar 7, 2021 1:23 PM
I've never used OpenSCAD from the command line before, but I now need to
generate some dozens of model variations, so I am trying it, without
success.
When I try this:
"c:\program files\openscad\openscad" -o out.stl -D 'myVar="val1"' -D
'num=1' -D 'need="false"' my-program.scad
I get this:
Can't parse file 'my-program.scad'!
I've never used OpenSCAD from the command line before, but I now need to generate some dozens of model variations, so I am trying it, without success. When I try this: "c:\program files\openscad\openscad" -o out.stl -D 'myVar="val1"' -D 'num=1' -D 'need="false"' my-program.scad I get this: Can't parse file 'my-program.scad'!
Sun, Mar 7, 2021 1:30 PM
I don't think you want the single quotes under Windows.
success.
When I try this:
I get this:
I don't think you want the single quotes under Windows. On Sun, 7 Mar 2021 at 13:24, jon <jon@jonbondy.com> wrote: > I've never used OpenSCAD from the command line before, but I now need to > generate some dozens of model variations, so I am trying it, without > success. > > When I try this: > > "c:\program files\openscad\openscad" -o out.stl -D 'myVar="val1"' -D > 'num=1' -D 'need="false"' my-program.scad > > I get this: > > Can't parse file 'my-program.scad'! > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sun, Mar 7, 2021 1:40 PM
You appear to be correct, although the example from the documentation is
this:
openscad -o my_model_production.stl -D 'quality="production"' my_model.scad
Now, I get the warning that "val1" is an "unknown variable" for each of
the used files, and too many unnamed arguments for one of the used
files. Unsettling.
The STL appears to have been generated correctly, but the warnings are
frightening: they do not occur when run from the GUI.
I guess I'm off and running, albeit nervously
Thanks!
 need to
 success.
 When I try this:
 I get this:
You appear to be correct, although the example from the documentation is this: openscad -o my_model_production.stl -D 'quality="production"' my_model.scad Now, I get the warning that "val1" is an "unknown variable" for each of the used files, and too many unnamed arguments for one of the used files. Unsettling. The STL appears to have been generated correctly, but the warnings are frightening: they do not occur when run from the GUI. I guess I'm off and running, albeit nervously Thanks! On 3/7/2021 8:30 AM, nop head wrote: > I don't think you want the single quotes under Windows. > > On Sun, 7 Mar 2021 at 13:24, jon <jon@jonbondy.com > <mailto:jon@jonbondy.com>> wrote: > > I've never used OpenSCAD from the command line before, but I now > need to > generate some dozens of model variations, so I am trying it, without > success. > > When I try this: > > "c:\program files\openscad\openscad" -o out.stl -D 'myVar="val1"' -D > 'num=1' -D 'need="false"' my-program.scad > > I get this: > > Can't parse file 'my-program.scad'! > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Sun, Mar 7, 2021 1:44 PM
On Windows you may need to escape the inner quotes instead:
openscad -o my_model_production.stl -D "quality="production""
my_model.scad
It's been a while since I used cmd-line, I seem to recall that in batch
files it got complex.
See wiki <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment> One way: > On Windows you may need to escape the inner quotes instead: > > openscad -o my_model_production.stl -D "quality=\"production\"" > my_model.scad It's been a while since I used cmd-line, I seem to recall that in batch files it got complex. ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
Sun, Mar 7, 2021 1:48 PM
I was using the wiki entry you recommend.
My sense is that nophead is correct about removing the single quotes
from my original example, and that the syntax for a batch file and for a
command line execution are subtly different.  There is no need to escape
the inner quotes, because there are no inner quotes once nophead's
suggestion is implemented
The warnings are scary, but I think I'm off and running
On 3/7/2021 8:44 AM, MichaelAtOz wrote:
See wiki
One way:
 my_model.scad
OpenSCAD Admin - email me if you need anything, * or if I've done
something stupid...
  • on the Forum, click on my MichaelAtOz label, there is a link to
    email me.
Public Domain;
the above.
I was using the wiki entry you recommend. My sense is that nophead is correct about removing the single quotes from my original example, and that the syntax for a batch file and for a command line execution are subtly different.  There is no need to escape the inner quotes, because there are no inner quotes once nophead's suggestion is implemented The warnings are scary, but I think I'm off and running Jon On 3/7/2021 8:44 AM, MichaelAtOz wrote: > See wiki > <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment> > > One way: > > On Windows you may need to escape the inner quotes instead: > > openscad -o my_model_production.stl -D "quality=\"production\"" > my_model.scad > > It's been a while since I used cmd-line, I seem to recall that in > batch files it got complex. > *OpenSCAD Admin - email* me if you need anything, * or if I've done > something stupid... > * on the Forum, click on my MichaelAtOz label, there is a link to > email me. > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; > to the extent possible under law, I have waived all copyright and > related or neighbouring rights to this work. > Obviously inclusion of works of previous authors is not included in > the above. > > ------------------------------------------------------------------------ > Sent from the OpenSCAD mailing list archive > <http://forum.openscad.org/> at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Ron Wheeler
Sun, Mar 7, 2021 3:57 PM
Do you ECHO the variables to be sure that they are getting in with the
values that you set?
See wiki
One way:
 my_model.scad
something stupid...
    email me.
Public Domain;
the above.
Ron Wheeler
Artifact Software
438-345-3369
Do you ECHO the variables to be sure that they are getting in with the values that you set? On 2021-03-07 8:48 a.m., jon wrote: > > I was using the wiki entry you recommend. > > My sense is that nophead is correct about removing the single quotes > from my original example, and that the syntax for a batch file and for > a command line execution are subtly different. There is no need to > escape the inner quotes, because there are no inner quotes once > nophead's suggestion is implemented > > The warnings are scary, but I think I'm off and running > > Jon > > On 3/7/2021 8:44 AM, MichaelAtOz wrote: >> See wiki >> <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment> >> >> One way: >> >> On Windows you may need to escape the inner quotes instead: >> >> openscad -o my_model_production.stl -D "quality=\"production\"" >> my_model.scad >> >> It's been a while since I used cmd-line, I seem to recall that in >> batch files it got complex. >> *OpenSCAD Admin - email* me if you need anything, * or if I've done >> something stupid... >> * on the Forum, click on my MichaelAtOz label, there is a link to >> email me. >> >> Unless specifically shown otherwise above, my contribution is in the >> Public Domain; >> to the extent possible under law, I have waived all copyright and >> related or neighbouring rights to this work. >> Obviously inclusion of works of previous authors is not included in >> the above. >> >> ------------------------------------------------------------------------ >> Sent from the OpenSCAD mailing list archive >> <http://forum.openscad.org/> at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- Ron Wheeler Artifact Software 438-345-3369 rwheeler@artifact-software.com
Sun, Mar 7, 2021 4:26 PM
The values were correct, because the STLs created were correct. I cannot
explain the warning messages
See wiki
One way:
 my_model.scad
something stupid...
    email me.
Public Domain;
the above.
The values were correct, because the STLs created were correct. I cannot explain the warning messages On 3/7/2021 10:57 AM, Ron Wheeler via Discuss wrote: > Do you ECHO the variables to be sure that they are getting in with the > values that you set? > > On 2021-03-07 8:48 a.m., jon wrote: >> >> I was using the wiki entry you recommend. >> >> My sense is that nophead is correct about removing the single quotes >> from my original example, and that the syntax for a batch file and >> for a command line execution are subtly different.  There is no need >> to escape the inner quotes, because there are no inner quotes once >> nophead's suggestion is implemented >> >> The warnings are scary, but I think I'm off and running >> >> Jon >> >> On 3/7/2021 8:44 AM, MichaelAtOz wrote: >>> See wiki >>> <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment> >>> >>> One way: >>> >>> On Windows you may need to escape the inner quotes instead: >>> >>> openscad -o my_model_production.stl -D "quality=\"production\"" >>> my_model.scad >>> >>> It's been a while since I used cmd-line, I seem to recall that in >>> batch files it got complex. >>> *OpenSCAD Admin - email* me if you need anything, * or if I've done >>> something stupid... >>> * on the Forum, click on my MichaelAtOz label, there is a link to >>> email me. >>> >>> Unless specifically shown otherwise above, my contribution is in the >>> Public Domain; >>> to the extent possible under law, I have waived all copyright and >>> related or neighbouring rights to this work. >>> Obviously inclusion of works of previous authors is not included in >>> the above. >>> >>> ------------------------------------------------------------------------ >>> Sent from the OpenSCAD mailing list archive >>> <http://forum.openscad.org/> at Nabble.com. >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > -- > Ron Wheeler > Artifact Software > 438-345-3369 > rwheeler@artifact-software.com > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Ron Wheeler
Sun, Mar 7, 2021 4:49 PM
The proof is in the pudding but one hates to see error messages
(unexpected ones at least) even if the code appears to work.
See wiki
One way:
 my_model.scad
something stupid...
    email me.
the Public Domain;
the above.
Ron Wheeler
Artifact Software
438-345-3369
The proof is in the pudding but one hates to see error messages (unexpected ones at least) even if the code appears to work. On 2021-03-07 11:26 a.m., jon wrote: > > The values were correct, because the STLs created were correct.  I > cannot explain the warning messages > > > On 3/7/2021 10:57 AM, Ron Wheeler via Discuss wrote: >> Do you ECHO the variables to be sure that they are getting in with >> the values that you set? >> >> On 2021-03-07 8:48 a.m., jon wrote: >>> >>> I was using the wiki entry you recommend. >>> >>> My sense is that nophead is correct about removing the single quotes >>> from my original example, and that the syntax for a batch file and >>> for a command line execution are subtly different.  There is no need >>> to escape the inner quotes, because there are no inner quotes once >>> nophead's suggestion is implemented >>> >>> The warnings are scary, but I think I'm off and running >>> >>> Jon >>> >>> On 3/7/2021 8:44 AM, MichaelAtOz wrote: >>>> See wiki >>>> <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment> >>>> >>>> One way: >>>> >>>> On Windows you may need to escape the inner quotes instead: >>>> >>>> openscad -o my_model_production.stl -D "quality=\"production\"" >>>> my_model.scad >>>> >>>> It's been a while since I used cmd-line, I seem to recall that in >>>> batch files it got complex. >>>> *OpenSCAD Admin - email* me if you need anything, * or if I've done >>>> something stupid... >>>> * on the Forum, click on my MichaelAtOz label, there is a link to >>>> email me. >>>> >>>> Unless specifically shown otherwise above, my contribution is in >>>> the Public Domain; >>>> to the extent possible under law, I have waived all copyright and >>>> related or neighbouring rights to this work. >>>> Obviously inclusion of works of previous authors is not included in >>>> the above. >>>> >>>> ------------------------------------------------------------------------ >>>> Sent from the OpenSCAD mailing list archive >>>> <http://forum.openscad.org/> at Nabble.com. >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> -- >> Ron Wheeler >> Artifact Software >> 438-345-3369 >> rwheeler@artifact-software.com >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- Ron Wheeler Artifact Software 438-345-3369 rwheeler@artifact-software.com
Sun, Mar 7, 2021 6:06 PM
For Linux you would need the outer single quotes but not for Windows.
Windows is weird.
On Linux the outer single quotes would be stripped but on Windows that
would be passed to OpenSCAD.
On Windows the inner double quotes both allow spaces etc in the string but
also get passed to OpenSCAD, which is why you don't need the outer quotes.
You shouldn't expect any additional warnings.
On Sun, 7 Mar 2021 at 16:50, Ron Wheeler via Discuss <
implemented
See wiki
One way:
my_model.scad
something stupid...
Public Domain;
above.
at Nabble.com.
Ron Wheeler
Artifact Software
438-345-3369rwheeler@artifact-software.com
Ron Wheeler
Artifact Software
For Linux you would need the outer single quotes but not for Windows. Windows is weird. On Linux the outer single quotes would be stripped but on Windows that would be passed to OpenSCAD. On Windows the inner double quotes both allow spaces etc in the string but also get passed to OpenSCAD, which is why you don't need the outer quotes. You shouldn't expect any additional warnings. On Sun, 7 Mar 2021 at 16:50, Ron Wheeler via Discuss < discuss@lists.openscad.org> wrote: > The proof is in the pudding but one hates to see error messages > (unexpected ones at least) even if the code appears to work. > > On 2021-03-07 11:26 a.m., jon wrote: > > The values were correct, because the STLs created were correct. I cannot > explain the warning messages > > > On 3/7/2021 10:57 AM, Ron Wheeler via Discuss wrote: > > Do you ECHO the variables to be sure that they are getting in with the > values that you set? > > On 2021-03-07 8:48 a.m., jon wrote: > > I was using the wiki entry you recommend. > > My sense is that nophead is correct about removing the single quotes from > my original example, and that the syntax for a batch file and for a command > line execution are subtly different. There is no need to escape the inner > quotes, because there are no inner quotes once nophead's suggestion is > implemented > > The warnings are scary, but I think I'm off and running > > Jon > On 3/7/2021 8:44 AM, MichaelAtOz wrote: > > See wiki > <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment> > > One way: > > On Windows you may need to escape the inner quotes instead: > > openscad -o my_model_production.stl -D "quality=\"production\"" > my_model.scad > > It's been a while since I used cmd-line, I seem to recall that in batch > files it got complex. > *OpenSCAD Admin - email* me if you need anything, * or if I've done > something stupid... > * on the Forum, click on my MichaelAtOz label, there is a link to email me. > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; > to the extent possible under law, I have waived all copyright and related > or neighbouring rights to this work. > Obviously inclusion of works of previous authors is not included in the > above. > > ------------------------------ > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > > _______________________________________________ > OpenSCAD mailing listDiscuss@lists.openscad.orghttp://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing listDiscuss@lists.openscad.orghttp://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > -- > Ron Wheeler > Artifact Software > 438-345-3369rwheeler@artifact-software.com > > > _______________________________________________ > OpenSCAD mailing listDiscuss@lists.openscad.orghttp://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > -- > Ron Wheeler > Artifact Software > 438-345-3369rwheeler@artifact-software.com > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sun, Mar 7, 2021 7:28 PM
Windows is weird.
Windows isn't weird.  It's just different.
(Well, OK, in some ways it's weird too.  But this really isn't one of them.)
Doing anything non-trivial with the various command processors requires
that you understand the syntax that they impose, and how they will
process the line before the program sees it.
In a UNIX-derived shell, in this command:
the single quotes are not formally part of the definition of the
command.  They are eaten by the shell and are not at all visible to the
program.  What the program sees is a list of "words", the argv array:
openscad
-o
-D
my_model.scad
The Windows model for passing arguments to programs is completely
different.  It's been a million years since I've looked at Windows
arguments without a C library interpreting them for me, but historically
MS-DOS just handed over the entire line after the command, quotes,
spaces, and all, less only a few things like I/O redirection.  C
libraries, since they want to present a sort of UNIX-like environment to
the program, parse those command lines in a way that's sort of similar
to the UNIX shell, but only sort of.  The details will depend on the
particular library used, which can lead to unfortunate inconsistencies
between one program and the next.  For MSYS2, it appears that double
quotes are handled but single quotes are not.  Here's a demonstration
using a simple program that dumps its arguments:
C:\msys64\home\Jordan>args a "a b" 'a b' "'a b'" '"a b"' a\ b
0 >args<
1 >a<
2 >a b<
3 >'a<
4 >b'<
5 >'a b'<
6 >'a b'<
7 >a\<
8 >b<
Contrast that with the UNIX shell behavior:
$ ./args a "a b" 'a b' "'a b'" '"a b"' a\ b
0 >C:\msys64\home\Jordan\args.exe<
1 >a<
2 >a b<
3 >a b<
4 >'a b'<
5 >"a b"<
6 >a b<
(Interesting note:  that's the same MSYS2 program running in both
cases.  The MSYS2 infrastructure must somehow negotiate with the program
to let it know that the arguments have already been parsed.  Running
under the MSYS2 version of bash, the command is getting parsed the same
as it would be under UNIX.)
In the world of the UNIX shell, double quotes protect most characters
from special interpretation, allowing spaces and wild-card characters to
be passed as arguments.  They do not protect against shell variable
references.  Single quotes protect against all special interpretation,
except for the closing single quote.  Backslash protects the following
character against any special interpretation.  After these characters
have done their job, they are stripped from the arguments that are
passed to the program.
In the world of the half-hearted UNIX-like parsing done by the MSYS2
library, it seems that double quotes are similar, but single quotes and
backslashes are not special - or at least not quite as special;
backslashes do seem to protect double quotes from being treated specially.
I don't know anything about Windows PowerShell syntax, but
experimentation says that it (combined with the MSYS2 library) gives
still another behavior:
PS C:\msys64\home\jordan> ./args a "a b" 'a b' "'a b'" '"a b"' a\ b
0 >C:\msys64\home\jordan\args.exe<
1 >a<
2 >a b<
3 >a b<
4 >'a b'<
5 >a b<
6 >a\<
7 >b<
Note that it has respected the simple single and double quote cases as a
UNIX shell would, and the single-inside-double case, but it stripped
both layers off of the double-inside-single case, and didn't respect the
backslash.
Judging from the examples in the documentation, some Windows C library
that OpenSCAD has used allowed protecting double quotes by doubling
them.  I don't know what variation this is from:
openscad.com -o my_model_production.stl -D "quality=""production""" my_model.scad
The documentation hints at how it really works in its description of
running OpenSCAD from another programming language:
When executing OpenSCAD from another process in Unix, the
single-quotes shouldn't be used e.g. from within a Java application:
   pb = new ProcessBuilder("/usr/bin/openscad",
     "-o", "my_model_production.stl",
     "-D", "quality=\"production\"",
     "my_model.scad");
but it's not exactly correct, or at least it doesn't lead to the right
mental model.  It's not that OpenSCAD doesn't need the single quotes in
that context - it's that they are needed in the shell context, but by
the shell, not OpenSCAD itself.  Note that this Java invocation has also
done several other things to the command - it's split the words into
separate strings, and it's supplied an absolute path to the program, and
it's backslash-quoted the double quotes so that they can be inside a
Java string.
Anyhow, net, you always need to distinguish between what the command
processor (perhaps augmented by the system-specific C library) will do
to the command, and what the program proper will see.  If you don't keep
that straight in your head, you'll run into trouble and
apparently-mysterious behavior in more complex cases and when you move
from system to system and command processor to command processor.
On 3/7/2021 10:06 AM, nop head wrote: > For Linux you would need the outer single quotes but not for Windows. > Windows is weird.  Windows isn't weird.  It's just different. (Well, OK, in some ways it's weird too.  But this really isn't one of them.) Doing anything non-trivial with the various command processors requires that you understand the syntax that they impose, and how they will process the line before the program sees it. In a UNIX-derived shell, in this command: openscad -o my_model_production.stl -D 'quality="production"' my_model.scad the single quotes are *not* formally part of the definition of the command.  They are eaten by the shell and are not at all visible to the program.  What the program sees is a list of "words", the argv array: openscad -o my_model_production.stl -D quality="production" my_model.scad The Windows model for passing arguments to programs is completely different.  It's been a million years since I've looked at Windows arguments without a C library interpreting them for me, but historically MS-DOS just handed over the entire line after the command, quotes, spaces, and all, less only a few things like I/O redirection.  C libraries, since they want to present a sort of UNIX-like environment to the program, parse those command lines in a way that's sort of similar to the UNIX shell, but only sort of.  The details will depend on the particular library used, which can lead to unfortunate inconsistencies between one program and the next.  For MSYS2, it appears that double quotes are handled but single quotes are not.  Here's a demonstration using a simple program that dumps its arguments: C:\msys64\home\Jordan>args a "a b" 'a b' "'a b'" '"a b"' a\ b 0 >args< 1 >a< 2 >a b< 3 >'a< 4 >b'< 5 >'a b'< 6 >'a b'< 7 >a\< 8 >b< Contrast that with the UNIX shell behavior: $ ./args a "a b" 'a b' "'a b'" '"a b"' a\ b 0 >C:\msys64\home\Jordan\args.exe< 1 >a< 2 >a b< 3 >a b< 4 >'a b'< 5 >"a b"< 6 >a b< (Interesting note:  that's the same MSYS2 program running in both cases.  The MSYS2 infrastructure must somehow negotiate with the program to let it know that the arguments have already been parsed.  Running under the MSYS2 version of bash, the command is getting parsed the same as it would be under UNIX.) In the world of the UNIX shell, double quotes protect most characters from special interpretation, allowing spaces and wild-card characters to be passed as arguments.  They do not protect against shell variable references.  Single quotes protect against all special interpretation, except for the closing single quote.  Backslash protects the following character against any special interpretation.  After these characters have done their job, they are stripped from the arguments that are passed to the program. In the world of the half-hearted UNIX-like parsing done by the MSYS2 library, it seems that double quotes are similar, but single quotes and backslashes are not special - or at least not quite as special; backslashes do seem to protect double quotes from being treated specially. I don't know anything about Windows PowerShell syntax, but experimentation says that it (combined with the MSYS2 library) gives still another behavior: PS C:\msys64\home\jordan> ./args a "a b" 'a b' "'a b'" '"a b"' a\ b 0 >C:\msys64\home\jordan\args.exe< 1 >a< 2 >a b< 3 >a b< 4 >'a b'< 5 >a b< 6 >a\< 7 >b< Note that it has respected the simple single and double quote cases as a UNIX shell would, and the single-inside-double case, but it stripped both layers off of the double-inside-single case, and didn't respect the backslash. Judging from the examples in the documentation, some Windows C library that OpenSCAD has used allowed protecting double quotes by doubling them.  I don't know what variation this is from: openscad.com -o my_model_production.stl -D "quality=""production""" my_model.scad The documentation hints at how it really works in its description of running OpenSCAD from another programming language: When executing OpenSCAD from another process in Unix, the single-quotes shouldn't be used e.g. from within a Java application: pb = new ProcessBuilder("/usr/bin/openscad", "-o", "my_model_production.stl", "-D", "quality=\"production\"", "my_model.scad"); but it's not exactly correct, or at least it doesn't lead to the right mental model.  It's not that OpenSCAD doesn't need the single quotes in that context - it's that they *are* needed in the shell context, but by the shell, not OpenSCAD itself.  Note that this Java invocation has also done several other things to the command - it's split the words into separate strings, and it's supplied an absolute path to the program, and it's backslash-quoted the double quotes so that they can be inside a Java string. Anyhow, net, you always need to distinguish between what the command processor (perhaps augmented by the system-specific C library) will do to the command, and what the program proper will see.  If you don't keep that straight in your head, you'll run into trouble and apparently-mysterious behavior in more complex cases and when you move from system to system and command processor to command processor.
