Makefile for building complex models from a single file
WC
W. Craig Trader
Wed, Sep 27, 2017 11:47 PM
I've been using OpenSCAD for ~6 years, and it's my go-to tool for both 2D
and 3D modeling. Recently I've been using OpenSCAD to model organizers for
some of my board games, and beyond a certain point it became irritating to
manually export the STL files. So I started writing makefiles. The manual
gives some suggestions for using makefiles, but I found them to be somewhat
clunky. So I did something that worked for me. I'm sharing it here; maybe
it will work for someone else.
Goals:
  • Adhere to DRY (Don't Repeat Yourself) -- there should be no
    duplication of information between the Makefile and the OpenSCAD file.
  • Generate STL models and PNG images with OpenSCAD, and then slice the
    models with Slic3r.
  • All generated files should go into segregated subdirectories.
  • The OpenSCAD file should still be useful without the Makefile.
  • If I change the OpenSCAD file, I accept that everything is going to be
    rebuilt. (Computers are fast.)
  • Work on Linux.
Here's what I ended up with:
Splendor organizers to fit in Splendor box
by W. Craig Trader is dual-licensed under
Creative Commons Attribution-ShareAlike 3.0 Unported License and
GNU Lesser GPL 3.0 or later.
This makefile expects an OpenSCAD file named $(PREFIX).scad that defines
the following variables:
PART    -- the name of a part to generate
VERBOSE -- logically true if you want verbose output (optional)
The OpenSCAD program should have logic that renders a single part by name:
if (PART == "foo") {
foo();
} else if (PART == "bar") {
bar();
} else if (PART == "foo-bar") {
foo_bar();
This makefile will use OpenSCAD to create individual model (STL) files
and
image (PNG) files for each declared part, and will use Slic3r to generate
G-Code for each declared part.
So if PREFIX=widget, then the created files will be:
stl/widget-foo.stl stl/widget-bar.stl stl/widget-foo-bar.stl
png/widget-foo.png png/widget-bar.png png/widget-foo-bar.png
gcode/widget-foo.gcode gcode/widget-bar.gcode gcode/widget-foo-bar.gcode
OpenSCAD binary and options
OPENSCAD=/usr/bin/openscad
OPENSCAD_OPTIONS=-DVERBOSE=false
IMAGE_OPTIONS=--imgsize=1024,768 --colorscheme=DeepOcean
Slic3r binary and options
SLIC3R=/opt/Slic3r/latest/slic3r
SLIC3R_INI=slic3r.ini
SLIC3R_OPTIONS=--load $(SLIC3R_INI) --print-center 125,105
Name of OpenSCAD model file
PREFIX=splendor
----- Everything after this should not need modification
Names of parts to build
PARTS=$(shell grep 'PART == ' $(PREFIX).scad | cut -d'"' -f2)
STL=stl
IMAGE=png
GCODE=gcode
MODELS=$(patsubst %,$(STL)/$(PREFIX)-%.$(STL),$(PARTS))
IMAGES=$(patsubst %,$(IMAGE)/$(PREFIX)-%.$(IMAGE),$(PARTS))
GCODES=$(patsubst %,$(GCODE)/$(PREFIX)-%.$(GCODE),$(PARTS))
all: models gcodes images
directories:
@mkdir -p $(STL) $(IMAGE) $(GCODE)
models: directories $(MODELS)
gcodes: directories $(GCODES)
images: directories $(IMAGES)
clean:
rm -rf $(STL) $(GCODE) $(IMAGE)
Dependencies for models
$(MODELS) : $(STL)/$(PREFIX)-%.$(STL) : $(PREFIX).scad
$(OPENSCAD) $(OPENSCAD_OPTIONS) -o $@ -DPART="$(subst $(PREFIX)-,,$(subst
.$(STL),,$(@F)))" $<
Dependencies for images
$(IMAGES) : $(IMAGE)/$(PREFIX)-%.$(IMAGE) : $(PREFIX).scad
.$(IMAGE),,$(@F)))" $(IMAGE_OPTIONS) $<
Dependencies for slicing
$(GCODES) : $(GCODE)/%.$(GCODE) : $(STL)/%.$(STL) $(SLIC3R_INI)
$(SLIC3R) -o $@ $(SLIC3R_OPTIONS) $<
When I want to add this Makefile to an existing project, all I usually have
to do is set the PREFIX variable in the Makefile, and then add the switch
block at the bottom of the OpenSCAD source file.
You can find source code examples on GitHub:
https://github.com/wcraigtrader/game-parts/blob/master/splendor/Makefile
https://github.com/wcraigtrader/game-parts/blob/master/splendor/splendor.scad
Feedback is always appreciated.
  • Craig -
I've been using OpenSCAD for ~6 years, and it's my go-to tool for both 2D and 3D modeling. Recently I've been using OpenSCAD to model organizers for some of my board games, and beyond a certain point it became irritating to manually export the STL files. So I started writing makefiles. The manual gives some suggestions for using makefiles, but I found them to be somewhat clunky. So I did something that worked for me. I'm sharing it here; maybe it will work for someone else. *Goals:* - Adhere to DRY (Don't Repeat Yourself) -- there should be no duplication of information between the Makefile and the OpenSCAD file. - Generate STL models and PNG images with OpenSCAD, and then slice the models with Slic3r. - All generated files should go into segregated subdirectories. - The OpenSCAD file should still be useful without the Makefile. - If I change the OpenSCAD file, I accept that everything is going to be rebuilt. (Computers are fast.) - Work on Linux. Here's what I ended up with: # Splendor organizers to fit in Splendor box # # by W. Craig Trader is dual-licensed under # Creative Commons Attribution-ShareAlike 3.0 Unported License and # GNU Lesser GPL 3.0 or later. # This makefile expects an OpenSCAD file named $(PREFIX).scad that defines # the following variables: # # PART -- the name of a part to generate # VERBOSE -- logically true if you want verbose output (optional) # # The OpenSCAD program should have logic that renders a single part by name: # # if (PART == "foo") { # foo(); # } else if (PART == "bar") { # bar(); # } else if (PART == "foo-bar") { # foo_bar(); # } # # This makefile will use OpenSCAD to create individual model (STL) files and # image (PNG) files for each declared part, and will use Slic3r to generate # G-Code for each declared part. # # So if PREFIX=widget, then the created files will be: # # stl/widget-foo.stl stl/widget-bar.stl stl/widget-foo-bar.stl # png/widget-foo.png png/widget-bar.png png/widget-foo-bar.png # gcode/widget-foo.gcode gcode/widget-bar.gcode gcode/widget-foo-bar.gcode # OpenSCAD binary and options OPENSCAD=/usr/bin/openscad OPENSCAD_OPTIONS=-DVERBOSE=false IMAGE_OPTIONS=--imgsize=1024,768 --colorscheme=DeepOcean # Slic3r binary and options SLIC3R=/opt/Slic3r/latest/slic3r SLIC3R_INI=slic3r.ini SLIC3R_OPTIONS=--load $(SLIC3R_INI) --print-center 125,105 # Name of OpenSCAD model file PREFIX=splendor # ----- Everything after this should not need modification # Names of parts to build PARTS=$(shell grep 'PART == ' $(PREFIX).scad | cut -d'"' -f2) STL=stl IMAGE=png GCODE=gcode MODELS=$(patsubst %,$(STL)/$(PREFIX)-%.$(STL),$(PARTS)) IMAGES=$(patsubst %,$(IMAGE)/$(PREFIX)-%.$(IMAGE),$(PARTS)) GCODES=$(patsubst %,$(GCODE)/$(PREFIX)-%.$(GCODE),$(PARTS)) all: models gcodes images directories: @mkdir -p $(STL) $(IMAGE) $(GCODE) models: directories $(MODELS) gcodes: directories $(GCODES) images: directories $(IMAGES) clean: rm -rf $(STL) $(GCODE) $(IMAGE) # Dependencies for models $(MODELS) : $(STL)/$(PREFIX)-%.$(STL) : $(PREFIX).scad $(OPENSCAD) $(OPENSCAD_OPTIONS) -o $@ -DPART=\"$(subst $(PREFIX)-,,$(subst .$(STL),,$(@F)))\" $< # Dependencies for images $(IMAGES) : $(IMAGE)/$(PREFIX)-%.$(IMAGE) : $(PREFIX).scad $(OPENSCAD) $(OPENSCAD_OPTIONS) -o $@ -DPART=\"$(subst $(PREFIX)-,,$(subst .$(IMAGE),,$(@F)))\" $(IMAGE_OPTIONS) $< # Dependencies for slicing $(GCODES) : $(GCODE)/%.$(GCODE) : $(STL)/%.$(STL) $(SLIC3R_INI) $(SLIC3R) -o $@ $(SLIC3R_OPTIONS) $< When I want to add this Makefile to an existing project, all I usually have to do is set the PREFIX variable in the Makefile, and then add the switch block at the bottom of the OpenSCAD source file. You can find source code examples on GitHub: https://github.com/wcraigtrader/game-parts/blob/master/splendor/Makefile https://github.com/wcraigtrader/game-parts/blob/master/splendor/splendor.scad Feedback is always appreciated. - Craig -
ST
Shaporev, Timur
Thu, Sep 28, 2017 8:19 AM
Please be warned that left tabs are removed (at least from my E-mail client), so the quoted code needs small manual repair.
It looks like a good idea to get the thing from github.
From: Discuss discuss-bounces@lists.openscad.org on behalf of W. Craig Trader craig.trader@gmail.com
Sent: 28 September 2017 02:47:14
Subject: [OpenSCAD] Makefile for building complex models from a single file
Goals:
  • Adhere to DRY (Don't Repeat Yourself) -- there should be no duplication of information between the Makefile and the OpenSCAD file.
  • Generate STL models and PNG images with OpenSCAD, and then slice the models with Slic3r.
  • If I change the OpenSCAD file, I accept that everything is going to be rebuilt. (Computers are fast.)
  • Work on Linux.
foo();
bar();
foo_bar();
PREFIX=splendor
STL=stl
IMAGE=png
GCODE=gcode
directories:
clean:
$(OPENSCAD) $(OPENSCAD_OPTIONS) -o $@ -DPART="$(subst $(PREFIX)-,,$(subst .$(STL),,$(@F)))" $<
$(OPENSCAD) $(OPENSCAD_OPTIONS) -o $@ -DPART="$(subst $(PREFIX)-,,$(subst .$(IMAGE),,$(@F)))" $(IMAGE_OPTIONS) $<
  • Craig -
Please be warned that left tabs are removed (at least from my E-mail client), so the quoted code needs small manual repair. It looks like a good idea to get the thing from github. ________________________________ From: Discuss <discuss-bounces@lists.openscad.org> on behalf of W. Craig Trader <craig.trader@gmail.com> Sent: 28 September 2017 02:47:14 To: discuss@lists.openscad.org Subject: [OpenSCAD] Makefile for building complex models from a single file I've been using OpenSCAD for ~6 years, and it's my go-to tool for both 2D and 3D modeling. Recently I've been using OpenSCAD to model organizers for some of my board games, and beyond a certain point it became irritating to manually export the STL files. So I started writing makefiles. The manual gives some suggestions for using makefiles, but I found them to be somewhat clunky. So I did something that worked for me. I'm sharing it here; maybe it will work for someone else. Goals: * Adhere to DRY (Don't Repeat Yourself) -- there should be no duplication of information between the Makefile and the OpenSCAD file. * Generate STL models and PNG images with OpenSCAD, and then slice the models with Slic3r. * All generated files should go into segregated subdirectories. * The OpenSCAD file should still be useful without the Makefile. * If I change the OpenSCAD file, I accept that everything is going to be rebuilt. (Computers are fast.) * Work on Linux. Here's what I ended up with: # Splendor organizers to fit in Splendor box # # by W. Craig Trader is dual-licensed under # Creative Commons Attribution-ShareAlike 3.0 Unported License and # GNU Lesser GPL 3.0 or later. # This makefile expects an OpenSCAD file named $(PREFIX).scad that defines # the following variables: # # PART -- the name of a part to generate # VERBOSE -- logically true if you want verbose output (optional) # # The OpenSCAD program should have logic that renders a single part by name: # # if (PART == "foo") { # foo(); # } else if (PART == "bar") { # bar(); # } else if (PART == "foo-bar") { # foo_bar(); # } # # This makefile will use OpenSCAD to create individual model (STL) files and # image (PNG) files for each declared part, and will use Slic3r to generate # G-Code for each declared part. # # So if PREFIX=widget, then the created files will be: # # stl/widget-foo.stl stl/widget-bar.stl stl/widget-foo-bar.stl # png/widget-foo.png png/widget-bar.png png/widget-foo-bar.png # gcode/widget-foo.gcode gcode/widget-bar.gcode gcode/widget-foo-bar.gcode # OpenSCAD binary and options OPENSCAD=/usr/bin/openscad OPENSCAD_OPTIONS=-DVERBOSE=false IMAGE_OPTIONS=--imgsize=1024,768 --colorscheme=DeepOcean # Slic3r binary and options SLIC3R=/opt/Slic3r/latest/slic3r SLIC3R_INI=slic3r.ini SLIC3R_OPTIONS=--load $(SLIC3R_INI) --print-center 125,105 # Name of OpenSCAD model file PREFIX=splendor # ----- Everything after this should not need modification # Names of parts to build PARTS=$(shell grep 'PART == ' $(PREFIX).scad | cut -d'"' -f2) STL=stl IMAGE=png GCODE=gcode MODELS=$(patsubst %,$(STL)/$(PREFIX)-%.$(STL),$(PARTS)) IMAGES=$(patsubst %,$(IMAGE)/$(PREFIX)-%.$(IMAGE),$(PARTS)) GCODES=$(patsubst %,$(GCODE)/$(PREFIX)-%.$(GCODE),$(PARTS)) all: models gcodes images directories: @mkdir -p $(STL) $(IMAGE) $(GCODE) models: directories $(MODELS) gcodes: directories $(GCODES) images: directories $(IMAGES) clean: rm -rf $(STL) $(GCODE) $(IMAGE) # Dependencies for models $(MODELS) : $(STL)/$(PREFIX)-%.$(STL) : $(PREFIX).scad $(OPENSCAD) $(OPENSCAD_OPTIONS) -o $@ -DPART=\"$(subst $(PREFIX)-,,$(subst .$(STL),,$(@F)))\" $< # Dependencies for images $(IMAGES) : $(IMAGE)/$(PREFIX)-%.$(IMAGE) : $(PREFIX).scad $(OPENSCAD) $(OPENSCAD_OPTIONS) -o $@ -DPART=\"$(subst $(PREFIX)-,,$(subst .$(IMAGE),,$(@F)))\" $(IMAGE_OPTIONS) $< # Dependencies for slicing $(GCODES) : $(GCODE)/%.$(GCODE) : $(STL)/%.$(STL) $(SLIC3R_INI) $(SLIC3R) -o $@ $(SLIC3R_OPTIONS) $< When I want to add this Makefile to an existing project, all I usually have to do is set the PREFIX variable in the Makefile, and then add the switch block at the bottom of the OpenSCAD source file. You can find source code examples on GitHub: https://github.com/wcraigtrader/game-parts/blob/master/splendor/Makefile https://github.com/wcraigtrader/game-parts/blob/master/splendor/splendor.scad Feedback is always appreciated. - Craig -
O
oystein.krog
Sat, Sep 30, 2017 8:34 AM
This is my version of an automatic makefile:
https://github.com/oysteinkrog/thing_spool_stand/blob/master/Makefile
It lets you define your parts as modules in your scad files then
automatically detects them (searches all .scad files) and generates stl
files.
It is also clever in that it will only rebuild parts if any of the dependent
files are modified.
Here is an example:
https://github.com/oysteinkrog/thing_spool_stand/blob/master/spool-stand.scad
The makefile is fully automatic and can just be dropped into any project
without changes.
This is my version of an automatic makefile: https://github.com/oysteinkrog/thing_spool_stand/blob/master/Makefile It lets you define your parts as modules in your scad files then automatically detects them (searches all .scad files) and generates stl files. It is also clever in that it will only rebuild parts if any of the dependent files are modified. Here is an example: https://github.com/oysteinkrog/thing_spool_stand/blob/master/spool-stand.scad The makefile is fully automatic and can just be dropped into any project without changes. -- Sent from: http://forum.openscad.org/
