Set Equal edge length
U
unkerjay
Sun, Dec 23, 2018 11:25 AM
I'm trying to marry equilateral triangles against the sides of a cubic plane.
ALL edges SHOULD be the same length if the base of the triangle, the length
of it's two sides and the cubic plane are all set to the same length.
The problem is, I'm not exactly sure how to go about that.
What would be the easiest way to do that?
I'm trying to marry equilateral triangles against the sides of a cubic plane. ALL edges SHOULD be the same length if the base of the triangle, the length of it's two sides and the cubic plane are all set to the same length. The problem is, I'm not exactly sure how to go about that. What would be the easiest way to do that? -- Sent from: http://forum.openscad.org/
